R6 VS R3 Which camera is better?
Started Dec 15, 2021 | Discussions
wr_photography
wr_photography Regular Member • Posts: 127
Re: R6 VS R3 Which camera is better?
It depends...do you want a camera now or do you want a camera in 2023? That's really all it boils down to.
 wr_photography's gear list:wr_photography's gear list
Sony a7C Sony a7 IV Sigma 105mm F1.4 DG HSM Art Sony FE 24mm F1.4 GM Sony FE 50mm F1.2 GM +1 more
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
Ephemeris wrote:
We regularly extract images from video. Shutter speed needs to be selected (or t least benefits) with that in mind.
This enables image selection from 120fps which isn't otherwise possible but we nornally are extracting from 8k ( primary reason to purchase).
So I think it links to what you have said about it's really down to the shooter to understand what they need and also what they may like (which may not be a need).
I'd love to see what you are getting by extracting frames from video.
I tried shooting fast moving subjects using the technique you describe and got poor IQ and motion blur with low resolution. If you've got it working,
Joe
Hoka Hey
Ephemeris wrote:
Hoka Hey wrote:
Ephemeris wrote:
I haven't read the compatibility list of EF lenses with the R3 but for the R5 (and 6) a good number are 20fps compatible. Maybe have a read what Canon say is able to give the full compliance.
FWIW, with fast action, the R6 is limited to 12 FPS because you have to use the MS due to significant rolling shutter on the R6. Then, H+ is limited even further on the R6 due to a narrower set of older lenses that support H+. On the other hand, the R3 gets 30 FPS in ES with virtually the same rolling shutter as MS mode and Canon has not listed any lenses that would cause the 30 FPS to be limited.
We are shooting R5s and use ES for some set ups, mainly rotating machinery.
You are using the R5 which has much faster read rates than the R6 and thus much less rolling shutter. However, the R5 still has rolling shutter effect.
Joe
photographer daniel
OP photographer daniel Forum Member • Posts: 88
Hoka Hey wrote:
photographer daniel wrote:
No one really needs 30FPS,
No. It depends on what you are shooting. 30 FPS gives you the in-between frames. You may not need it, but just because you don't need it doesn't mean that others might not find it useful.
True, this depends on the subject of photography, but in any subject you need to know when to click.
After that let's tell the truth, it's not worth it, the photographer is not really doing work to capture the moment
just need to know when to shoot and be fast.
No. Knowing when to shoot with 30 FPS will get you more keepers than knowing when to shoot at 12 FPS.
With 30FPS and above, I could shoot video and take out any image I want
No. Extracting frames from video does not give you the same IQ. Also, there are issues with motion blur when extracting frames from video.
Does R3 have heating issues, it heats up during massive use?
No. Not in stills mode.
There are some time limits in video mode that are documented in the manual.
--photographer___daniel--
 photographer daniel's gear list:photographer daniel's gear list
Canon 6D Mark II Canon EF 17-40mm f/4.0L USM Canon EF 70-200mm f/2.8L IS USM Canon EF 100-400mm f/4.5-5.6L IS USM Canon EF 100mm f/2.8 Macro USM +1 more
photographer daniel
I think 30 FPS is needed when you want to capture 30 FPS. We have to remember, especially in photography that just because technology is new and people got by with less before, should not mean it is not needed. If that was the case than why need a camera? You can just sketch what you saw. My example might be silly but I back up the need argument. Now does that mean the OP needs 30 FPS to shoot gymnastics? Idk thats for him to decide.
In sports, especially pro high level stuff, I imagine you need as many FPS as you can get. The R3 is a pro camera aimed at pro needs. Its only a luxury to well off enthusiest.
30 FPS lets you capture more images.
But after that from a set of 50 pictures you make, you choose only one picture.
So you just have to know how to read the subject and know when to take a picture
photographer daniel
why 2023?
Ephemeris
Ephemeris Senior Member • Posts: 1,186
The resolution is set by which video mode you are using.
So typically if we are taking images and video of say an updated part to a machine (some recent have been to agricultural machines) then these would be images (usually using ES) and the 8k video used to compliment that. Shutter speeds for the video reduced which doesn't make for a great video but does allow frames to be used.
On occasion we may have a rotating fan or fans which are of reasonable diameter (maybe 32" or so) and the ES can cause some distortion. Here a few MS shots would be taken in case those images are needed later on.
Some 120fps video is taken for some jobs which help to show operation that we may not see if shooting at sub 25fps. Stills have be used from this also. If usable data can be pulled form video then we would.
R2D2 Forum Pro • Posts: 26,539
Hoka Hey wrote:
davev8 wrote:
i say the R6 is "more likely" to have more FPS etc as we do not know what EF lenses the OP has and its a bit early for many real world tests with the R3 and EF vs RF glass but the general consensus with the R5/6 is they are better with RF glass than EF glass but EF glass works better on the R5/6 than on a DSLR..
All true and the EF glass I have worked even better on the R3. I will be surprised if there is any EF glass that works better on the R5/6. Based on the MS H+ speeds being limited on the R5/6 with some EF glass, but not on the R3, it appears that Canon has made an effort to make the R3 even more compatible with older lenses.
Just tested the EF 70-200 f/2.8 ii with 2x iii converter on the R3. It is really snappy when going from close to far focus and does Eye Af with ease. As stated previously, the EF 500 f/4 ii has quicker AF and the glass moves faster on the R3.
i think you are going to find some EF lenses that are hardware limited and no matter what body you have are not going to make them AF any faster..and any difference between body to body are probably not noticed in real life
There is a significant difference IRL in AF lock-and tracking between the cameras with the lenses mentioned above.
i would have to put my 5Dmki from 2005 side by side with the R6 to see if my EF85mmF1,8 af is any faster..it seemed instant on the 5D
you have to remember the OP is coming from a 6Dmkii with 5 fps and only the center AF point rated only to -3.5EV compared to -6 to 7 EV for ALL points for the R3/6 (this is not twice as good but 3 times better) only 45AF points clumped in the middle vs 4000+ over most of the frame, eye AF and tracking that will seam on another planet
so the R6 is a massive upgrade its huge over the 6Dii
so is the R3 but to realize any extra advantage of the R3 will be in extreme cases
The advantage will be significant in competitions which is what the OP says that he is getting the camera to shoot. Not only is the AF faster and stickier, but you get 30 FPS vs 12 FPS. So, you get more in-between shots.
the % of extra upgrades is slim for double the money for the OP use
It depends on how important getting THE shot is to OP. The R5 and R6 are fantastic cameras, bu the R3 is significantly better for fast action.
BUT the advantage still goes to the R6 with affording RF glass
RF Glass is better, but OP has EF glass that he can use now and convert to RF glass as his needs evole.
1 you always have AF over the full-frame with RF glass not always the case with EF glass
No. The RF 600 and 800 f11s do not allow full-frame coverage. What EF lenses are you saying offer less than full-frame AF points? I have full-frame AF points on all my EF glass.
2 its reported that IS/IBIS works better with RF glass
It does, but it is incremental.
3 RF glass is often sharper than the equiv EF glass
It depends on the lens.
4 often other advantages with RF glass like the aforementioned 70-200 its the most compact 70-200F2.8 available
Bu the EF 70-200 2.8 ii is close in IQ and that's a lot to spend for a smaller lens.
5 no adaptor to mess with and /increase size
Not a big deal.
6 i have already seen EF lenses drop in second-hand value (in UK) now would be a good time to change them..i imagine the decline will be faster when RF availability is back to normal
To the OP, you need to listen to what Hoka Hey is saying.  Virtually all of the information you need in order to make a decision is found in his posts.
Pay especially close attention to what is said about the extra stop of usable ISO, because that of course translates into being able to double your shutter speed!
Pay especially close attention to what is said about improved autofocus (not just acquisition and stickiness, but also speed), because that too will greatly affect your keeper rate.
Pay especially close attention to what is said about rolling shutter effects, because you will want to use eShutter for all you shoot once you start using it.
You are looking for professional-level results, shooting some of the most demanding subjects in some of the most difficult conditions possible (I know because it’s stuff that I like to shoot too).
For these subjects, would I trade my R5 for the increased capabilities of an R3?  In a heartbeat (if one were available to me).
But one isn’t, so I did the next best thing and dropped my $7500 US on some new RF lenses.  I’ll maybe have to wait it out for the R1 now (or just say the heck with it and order an R3 anyway).  Because I know without hesitation what those increased capabilities will do for me!
Best of luck with your decision!
R2
Hoka Hey
That's correct. You have to know when to shoot. But there is more to it than that.
When shooting fast-moving subjects each of the frames will be a little or a lot different even at 30 FPS and there is usually one that is best. The more options you have, the more likely you are to get a great image.
Joe
Hoka Hey
Not a big deal.
R2
Thanks R2.
That's an excellent summary of Important things for OP to consider.
Joe
