manual control of aperture pixel 6 pro?
Started Dec 15, 2021 | Discussions
mfinley
mfinley Veteran Member • Posts: 7,066
Wondering if there is a way to control the aperture in the pixel 6 pro. It seems to always want to shoot wide open with a fast shutter speed. Specifically, I think it would be nice to increase the shallow depth of field when you want to.
 mfinley's gear list:mfinley's gear list
Olympus 7-14mm F2.8 Pro Olympus M.Zuiko 300mm F4 IS Pro Olympus 12-100mm F4.0
Patrick T. Kelly Veteran Member • Posts: 4,629
Re: manual control of aperture pixel 6 pro?
No. Fixed apertures are the rule.
Patrick T. Kelly
Oaxaca, Mexico
v30 Senior Member • Posts: 1,009
Is there much room for increase....ie, the small sensor even at f2 is probably equivalent to f12-13 on a full frame camera. I think in order to get shallow depth of field or bokeh, you have to shoot very very close. If you are getting shallow depth of field or bokeh with a cell phone camera its probably being "manufactured" by the camera.
PentaxNick Senior Member • Posts: 1,830
I very much doubt that any of the camera phones have a mechanical aperture control of any sort, which will be required to change depth of field. Exposure will be adjusted using shutter speed and gain (ISO), possibly in combination with ND filters.
Nick
 PentaxNick's gear list:PentaxNick's gear list
Ricoh GR Fujifilm X100T Olympus Tough TG-4 Ricoh GR III Olympus PEN-F +12 more
teemodk Senior Member • Posts: 1,457
My wife's S9+ have dual apertures: f/1.5-2.4, 26mm.
phouphou Contributing Member • Posts: 909
Re: No, theres no manual control of aperture in Pixel 6 Pro
The 1" Xperia Pro-I also offers variable aperture.
The Pixel 6 Pro not.
https://www.dpreview.com/news/1641689739/sony-just-packed-a-1-stacked-cmos-sensor-into-the-xperia-pro-i-but-there-s-a-catch
But i fail to see any advantages of variable apertures, because DoF is already large at the wide aperture (24mmf7 hyperfocal distance is 2.8m) and desirable effects of smaller apertures in a full frame lens for example (sharper, less abberations, sunstars) are not present or get lost because of diffraction @f14 equiv.
Here you can see the difference f2 vs f4 makes on the xperia:
https://www.dpreview.com/sample-galleries/1876772280/sony-xperia-pro-i-sample-gallery/0251416043
 phouphou's gear list:phouphou's gear list
Ricoh GR II Sony a7 II Sony a7R II Sony FE 85mm F1.8 Sony FE 24-105mm F4 +14 more
the flagships offer quite impressive equivalent apertures of around f7 on their main camera.
Check out the table i posted here
https://www.dpreview.com/forums/post/65928508
But like you pointed out, on a 24 or 26mm wideangle lens this doesnt exactly mean its easy to get blurry backgrounds unless youre close.
