Lens and Sensor Resolution
Started 8 months ago | Discussions
Rod McD Veteran Member • Posts: 8,146
Re: Lens and Sensor Resolution
Hi John,
I've seen some fabulously detailed prints from the Sony 24-70 f2.8 but it's a very expensive zoom and moreover a very heavy one - the lens weighs nearly a kilo and if one is doing multi-night hikes, that and the camera and tripod make for quite an addition to the pack. The Sony 24-70 f4 isn't reported to be that good. I think if I do try an A7R4, I'll be opting for just a few of the small primes that seem to be coming out in FE mount these days. They're far easier to handle when making fine adjustments on a ball head.
Enjoy whatever you decide.  if you do try an A7R4, I'd be interested to hear your thoughts....
Cheers, Rod
 Rod McD's gear list:Rod McD's gear list
Canon PowerShot G1 X Olympus Tough TG-4 Fujifilm X-T4 Voigtlander 90mm F3.5 APO-Lanthar SL II Fujifilm XF 35mm F1.4 R +18 more
OP John Carson Veteran Member • Posts: 4,287
Hi Rod,
If I went with Sony, I would get the 24-105mm f4, which is generally well regarded, albeit it is a G lens rather than a G Master.
john carson
 John Carson's gear list:John Carson's gear list
Fujifilm X-E2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS
robert1955 Veteran Member • Posts: 6,743
TukTuk wrote:
robert1955 wrote:
TukTuk wrote:
robert1955 wrote:
TukTuk wrote:
Tom Schum wrote:
TukTuk wrote:
John Carson wrote:
There is talk that the new Fuji sensor could be around 40 megapixels. I have the 18-55 mm and the 55-200 mm zooms. Does anyone know if they can resolve 40 megapixels, or would I need new lenses with greater resolving power?
they can't "resolve" even 16mp sensor... but more mp will never result in less details even behind the worst lens in the universe !
Do you have a link to test data that shows this?
just go to any test site like lenstip or opticallimis ... those lenses were tested
So you cannot back up your claim as the chart tests never compare between sensor resolutions
dude - I will help you to comprehend the evident
there still is no comparison between tests with two resolutions.
Grasping at straws you are for everybody to see
again - lenses were tested on the same camera so test results are perfectly comparable
You still [refuse to]/ [do not] understand. Same lens would to be tested on cameras with different resolutions for this question.
Goodbye
 robert1955's gear list:robert1955's gear list
Fujifilm X-E3 Fujifilm 16-55mm F2.8R LM WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR
bastibe
bastibe Senior Member • Posts: 1,017
Here's my extremely simple method: if you can see aliasing, the lens has more resolution than the sensor.
All my lenses show aliasing. So all my lenses will benefit from a higher resolution sensor.
My eyes, on the other hand, will not.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +3 more
