NX Firmware
Started Dec 12, 2021 | Discussions
markyboy81 Veteran Member • Posts: 4,778
NX Firmware
Has anyone got any links for the latest firmware? There used to be a way to get this using the way back machine but it no longer works.
In particular I'm looking for the firmware for the 50-200m lens version 3.
I can share firmare for the 12-24mm, 16mm. 18-55mm and 50-150mm.
Many thanks.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
shutterbugnx
shutterbugnx Regular Member • Posts: 168
Re: NX Firmware
Someone appears to have re-uploaded them on this Korean site
https://blog.naver.com/lovesumii/222006052054
To download, click the downward arrow then the text with the yellow folder icon.
 shutterbugnx's gear list:shutterbugnx's gear list
Panasonic Lumix DMC-ZS60 Olympus PEN E-PM1 Sony Alpha NEX-7 Samsung NX2000 Fujifilm X-M1 +46 more
kypfer Contributing Member • Posts: 985
Re: NX Firmware
I grabbed a url off https://matteverglade.com/lenses/nx-firmware/ and pasted that into the Wayback machine. After a re-direct or two I ended up with a file … so there are some available. I've only got the one Samsung lens, which I have updated. As to whether there's anything there of use to you ...
Good luck
Haha … doubled with shutterbugnx
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
OP markyboy81 Veteran Member • Posts: 4,778
Re: NX Firmware
Thanks both, that other link is fantastic, downloaded them all in one go!
Not sure why the wayback machine didn't work for me!
Rudi Senior Member • Posts: 2,047
Re: NX Firmware
...been searching through all available WEB sites, but your lens is the final version III of the 50-200mm. It never got updated.
https://www.samsung.com/hk_en/support/model/EX-T50200CSB/
Rudi.
Re: NX Firmware
Thanks Rudi, but Matt Everglade's site says something different.
Re: NX Firmware
... well - I´m not sure Matt Everglade is up to date here. Samsung´s site has all the latest firmware files listed except for the 50-200 III. So maybe they realized some incompatibitility later on and did no longer publish it.
Rudi.
