Re: A really good and versatile prime lens
David Smith - Photographer wrote:
Because I was curious about this new lens, I compared my test photos from the OM System 20mm f/1.4 to those of a Mark II Panasonic 20mm f/1.7.
The OM System 20mm is optically superior, especially towards the edges of the image. It's sharper in the center too, but you have to pixel peep at 100% to see that. Also, it has better bokeh, weather sealing, it focusses very fast and it's nearly silent when focusing. I hoped the difference in corner sharpness would be less, because I like the Panasonic pancake, but it isn't. It is clearly visible.
I really like the Panasonic 20mm f/1.7 because it's so darn small and lightweight. It literally fits in your pocket, has good image quality and combined with a compact MFT body like the E-M5 and E-M10 series camera, it forms a inconspicuous compact and lightweight system.
However, this new OM Systems 20mm f/1.4 is not only slightly faster, it's also optically superior. Although it's significantly bigger and heavier than the Panasonic pancake, it's not as big and heavy as the f/1.2 primes or Pro zoom lenses. It fits somewhere between the compact primes and the faster Pro lenses.
There's a place for both type of lenses I think. The Panasonic pancake is great to keep the size and weight of your camera gear down. Take this pancake and a short fast tele with you to travel light. The OM Systems 20mm is perfect if you want the best possible image quality, weather sealing and/or fast autofocus in the smallest possible package. It's a great lens, albeit a bit expensive.
Thanks David for your review. I agree with most of it, the lens is very good, I have been using it for the last 2 weeks on my e-m5 iii. I haven't used the Panasonic lens. However I have to mention one major - to me - negative characteristic of the OM System 20mm f1.4 lens: purple fringing, a lot of it! I was very surprised to see it in most of high-contrast night shots. I know it can be solved in post but I don't like having to post, usually go for SOOC. I hope it can be improved soon with a firmware update. Two sample photos below (SOOC jpegs).
20mm, f1.4, 1/4sec, ISO 800 (fringing only on the street lamp, the dome light is a light projector)
20mm, f1.4, 1/8sec, ISO 500 (fringing on the street lamps)
Konstantinos - travels to shoot and shoots to travel.
“I believe there are two barriers: the technology barrier and the barrier of accepted wisdom. You can’t achieve anything until you break through both of these barriers.” – Yoshihisa Maitani
