X raw studio really slow
Started 7 months ago | Discussions
Zagor87 New Member • Posts: 14
Hi all, I am trying to use xraw studio to convert the raf files to different film simulation (also custom made).
The process of choosing the right film simulation scrolling throught the photos and changing every time the simulation is REALLY slow compared to let's say capture one when this is instant.
Is there a workaround or is it impossible to solve as the program use the built in camera processor and it's slow for that matter?
MaartenSFS Senior Member • Posts: 1,036
Re: X raw studio really slow
That's essentially why, yes. Still a powerful tool, though! Hopefully it will speed up with future updates!
- Cheers, Maarten Sebastiaan Franks Spijker
https://www.flickr.com/photos/maartensfs/albums
OP Zagor87 New Member • Posts: 14
I also noticed that C1 raw files are opened like the jpeg (i see no differences from the jpeg, they seem to have the same settings, film simulation, clarity, sharpening, grain etc). Does it mean that opening the raf file is like editing the jpeg but with the flexibility that raws give you?
VfxByArt Regular Member • Posts: 446
Same problem here.  I guess piping each thru the camera eats up processing time.
 VfxByArt's gear list:VfxByArt's gear list
Canon EOS M5 Fujifilm X-T3 Canon EOS R Canon EF 24mm f/1.4L II USM Canon EF 50mm F1.4 USM +10 more
bs1946
bs1946 Veteran Member • Posts: 7,533
Capture One, SilkyPix, and even the evil empire of Adobe have Fujifilm Simulations, but while they're close, they're not exactly the same.
X-Raw Studio is slow because you are starting with RAFs that have already been downloaded to your computer. Then X-Raw Studio establishes a connection back to your camera via a USB cable and when you select the RAF you want work on, X-Raw Studio uploads the RAF back to your camera, opens it in the in-camera raw converter and lets you use your mouse and keyboard to control the in-camera raw converter. Then when you save the jpeg, X-Raw Studio downloads the RAF and JPEG back over the same USB connection.
Long before someone at Fuji came us with X-Raw Studio, I would hook X-E1 to my monitor with an HDMI cable. As soon as I select Preview, the LCD output is rerouted to my monitor and the LCD goes black. I then select an image and use the in-camera raw converter to create and save the jpegs I want. Still have to use the camera's controls for everything but its a lot faster than using X-Raw Studio or a third-party raw converter.
Or just use the custom settings and shoot jpegs; fastest of all...
Bill S.
www.flickr.com/photos/wrs1946
“Blend in with the people and have as little equipment as possible”
- Alfred Eisenstaedt -
 bs1946's gear list:bs1946's gear list
Leica M Typ 240 Voigtlander 35mm F2.5 Color Skopar Voigtlander 50mm F1.5 Nokton Apple iPhone 12 Pro Max Carl Zeiss Planar T* 2/50 ZM
Michael Floyd Contributing Member • Posts: 829
I believe it is film sim only, which is applied as a base curve - not clarity, sharpening, grain etc etc...  You could set up a custom style to be applied on import though that would bring in a set of other adjustments as you please.
Regardless it is a very useful staring point if that is a path that appeals.  To my thinking, using CO in this way gives a great deal of the ease of the Film Sims while also allowing the flexibility of working from the RAF's.
baobob
baobob Forum Pro • Posts: 17,251
IMO it is slow as it uses the processor of the camera.RFC EX3 is fast as is Raw Therapee 5.x and of course the major editors
Sony RX100 Olympus Tough TG-4 Panasonic ZS200 Fujifilm X-H1 Fujifilm X-T3 +10 more
I don't know, to me they seem to be no differences..
Take a photo with some obvious in camera settings, say strong large grain, import that into CO and see how you go.
bowportes Veteran Member • Posts: 4,218
XRaw Studio enables you to set pretty much any JPEG setting that the camera will do, not just the film Sims. Its speed is greatly impacted by the speed of your USB port/cable
 bowportes's gear list:bowportes's gear list
Panasonic Lumix DMC-G5 Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-Pro2 Panasonic Lumix G 20mm F1.7 ASPH +13 more
Look carefully. Especially when there is water or reflections.
CrashTestHuman Regular Member • Posts: 162
Capture One by default implements some amount of sharpening and noise reduction, so what you're adding to the photos may not be much different than what Capture One would have done anyway.
 CrashTestHuman's gear list:CrashTestHuman's gear list
Fujifilm X-S10 Fujifilm XF 27mm F2.8 Fujifilm 50mm F2 R WR Fujifilm XF 16-80mm F4
rla1022 Contributing Member • Posts: 524
Just wanted to say…. That this is a really cool idea.
 rla1022's gear list:rla1022's gear list
Sony Cyber-shot DSC-WX9 Fujifilm X-Pro3 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 35mm F2 R WR Fujifilm XF 16-80mm F4
No, the raw opened in capture one is definately different then the jpeg.
there should be a button that left you MANUALLY update an image... so if I know I have to change the EV, shadow tone curve and change the WB to 4800 K, I should be able to do the changes WITHOUT the image needing to update, and THEN hit the update button.  That way the image make the round trip to the camera ONCE for those three changes rather than EVERY TIME I touch a control!!!!
