For those who don't like the X100's...
Started Dec 4, 2021 | Discussions
Leicalika Regular Member • Posts: 365
Re: For those who don't like the X100's...
brokenhat wrote:
Are you baiting us? X100V is the best of its kind under $4000. The end 😂
you funny
bastibe
OP bastibe Senior Member • Posts: 1,236
Re: I don’t get it, OP
Jeff Biscuits wrote:
liggy wrote:
You dislike the OVF, ignore the perfectly fine EVF and then go on to say you’re fine without a viewfinder at all a la GR. Makes no sense whatsoever.
I can see some sense in it, though it may initially seem obscure.
As you say, you certainly can use the X100 as an EVF camera. It just constantly reminds you that, in its opinion, you’re not using it properly 😉 Which the GR doesn’t.
Thank you, Jeff, for expressing my thoughts more clearly than I could.
At the time, I had the X-T2, the X100T, and the Ricoh GR. I had bought the X100T mostly for its OVF. But seeing that the OVF experience was not what I had hoped for, I found the X-T2 a better EVF camera and the GR a better noVF camera.
 bastibe's gear list:bastibe's gear list
Ricoh GR III Fujifilm X-Pro2 Fujifilm X-T3 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro +5 more
j tokarz Senior Member • Posts: 1,387
I have just sold my X100V. The most beautiful camera i have ever owned. BUT, i just couldn't jell with it. Now my X-H1, while not as beautiful fits me like a glove. And i love it. The X100s as great as they are are not for meveryone. Funny really, but i did have the original X100, loved it and kept it till it died.
Ringwraith69
Ringwraith69 Veteran Member • Posts: 3,407
I can totally follow your reasoning. I've shot film with rangefinder cameras (including Soviet FED and Zorki cameras to the wonderful Voigtländer Bessa R-models) and then moved on to a digital Epson R-D1, which I still own and use. I entered the world of Fuji with the original X100 (which I still own and use, too), then got an X-Pro1 which I replaced with an X-Pro2 last year.
As you say, the focussing spot in a 'true' rangefinder, like the R-D1 is a unique feature that the focussing box of the X100's just cannot match. The OVF on an X100 is wonderful, but it just doesn't offer you the same experience as a more classic OVF. That's why, even though I did get used to the Fuji X100 and X-Pro's and wouldn't want to part with that concept, I still take out the ancient, antiquated R-D1 from time to time. Just simply for that real, classic, unadulterated OVF-experience.
It's all personal taste and preference, no right or wrong here. And to me your choice and the reasons for it do make sense.
Just wondering how you like the Sony. I find it a fascinating camera, but is it worth the, well, let's be nice, rather steep price?
(We are only immortal for a limited time)
 Ringwraith69's gear list:Ringwraith69's gear list
Sigma DP1 Fujifilm FinePix X100 Fujifilm X-S1 Sony RX10 II Sony RX10 IV +42 more
bastibe
Well, the price is not that bad any more now that the camera is almost ten years old. I got mine for €650. Which is still a lot of money, but roughly on par with, say, a used X100T or X100F.
Being ten years old, the sensor is no longer state-of-the-art. I would rate the dynamic range and high-ISO performance roughly similar to the X-Trans III in my X-T2. The "full frame advantage" having been compensated by sensor technology advances.
Autofocus performance was never stellar, but I don't find it particularly troublesome. I would judge it similar to the X100T, but not nearly as fast as the X-T2 with a modern lens. It's good enough for pictures of my kids, though, which is honestly all I care about. (Faster than the X-T2 with the XF 60 f/2.4, that is).
But the interesting thing is, how does it feel in use? Now that it's winter, I like to carry it in my coat pocket. Interestingly, it fits in sideways instead of flush. This makes it important to put it in the pocket with the lens pointing forwards if you want to be able to pull it out quickly, a consideration I was not used to from other cameras.
Actually, it is almost too big for a coat pocket. But for now it works for me. About as comfortable to carry on my pocket as the thinner-but-bigger X100, I would say.
It switches on quickly and is ready to shoot almost instantaneously. This is something I value highly. Since the lens does not move when switching on, I usually switch it on while pulling it out of my pocket, and it is ready when I have raised it to shooting height.
The camera is almost too heavy for one handed use. A bigger grip would definitely help. Perhaps I'll look into that some day. But it works well in one-handed mode. Exposure compensation and program shift are easily accessible to the right hand. Aperture control or manual focusing needs the second hand.
Its small shape and one-handed use makes it a very unassuming thing that easily goes unnoticed. This is something I enjoy, as it allows me stealthy shots before my kids have time to react.
I must say I would tremendously enjoy a viewfinder on this little thing. Alas, the add-on one is too bulky and expensive, and the RX1R II with the integrated viewfinder is out of my price range.
When it comes to editing, I am not particularly experienced in Sony files. Colors often have a bit of a cast by default, but that's easy to correct. Detail and flexibility is similar to my X-T2. (I don't particularly care about pixel-level sharpness, so I can't comment on that).
The rendering is quite wonderful, however, and different from my other lenses. Even though my XF 35 f/1.4 should have a similar depth of field (slightly narrower, actually), somehow the RX1 seems to throw things out of focus more strongly. Perhaps because the wider angle facilitates a closer subject distance. I am a big fan of the RX1's rendering, with a very smooth and pleasing focus transition.
These things are subjective of course. But to my eye, I would even put the RX1's rendering slightly before the XF 35 f/1.4. But then I am not very experienced with wide-angle, large-aperture primes, so this might still be the thrill of novelty.
It is of course a very limited camera. No AF-C, no viewfinder, somewhat big, uninteresting video. But it works well for my use, and is a lot of fun, and a bit of a challenge (in a good way)!
But that's only from a few weeks of experience so far. It's still in my "fun experiment" category, and hasn't earned a permanent place in my gear yet.
