Is anyone using a Pentax 300mm f4 Star lens with the Pentax k to micro four thirds?
Started Dec 4, 2021 | Discussions
John Cal
John Cal Regular Member • Posts: 465
Just wondering if anyone has tried this particular set up? I already use a Concept adapter to use my Pentax glass on my Fujifilm  cameras and it works great.  So I thought why not use why not take  advantage of thr crop factor with my GX8  & GX7 to get some great long distance shots.  I would appreciate any info if others have tried this out.  Cheers in advance 👍
 John Cal's gear list:John Cal's gear list
Panasonic Lumix DMC-TS1 Pentax K10D Pentax K-7 Pentax Q Pentax K-01 +18 more
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX8
JimH123 Veteran Member • Posts: 3,886
Re: Is anyone using a Pentax 300mm f4 Star lens with the Pentax k to micro four thirds?
Not sure which Pentax 300mm f4 lens you are referring to. I have the Asahi Pentax Takumar 300mm f4, and I have used it with m4/3 and it worked well. I can get some CA if shooting wide open. I also have the Olympus 75-300mm f4.8-6.7. Not yet sure if it is sharper than the older Takumar 300mm f4, but it sure is smaller and lighter.
Also have the Asahi Pentax Takumar 400mm f5.6 used here with an Olympus EM1. Example of a Scrub Jay at a farther than optimum distance, but it shows what the results can be.  I used a tripod and found focus to be easy to accomplish.
400mm Asahi Pentax Takumar - Original with Topaz AI Clear
The next image is from the same image, but I used Gigapixel AI at 4x to zoom in on the Scrub Jay. Considering the 800mm with crop factor, the resizing by 4x, the reach is in the ballpark with the Nikon P1000 super bridge camera, but with a somewhat larger sensor.
4x crop with Topaz Gigapixel AI
 JimH123's gear list:JimH123's gear list
Nikon Coolpix P1000 Sony RX100 VII Olympus E-M5 II Sony a6300 Olympus E-M1 II +2 more
robgendreau Forum Pro • Posts: 10,931
I used one on an IR converted PL-8. Not ideal; no aperture ring and of course manual focus, which is tricky on a 600mm equivalent prime lens except for a static subjects. But otherwise it's a great lens, worth a try.
 robgendreau's gear list:robgendreau's gear list
Pentax 645Z
RSTP14 Veteran Member • Posts: 6,370
If you are talking about the DA*, then you'll need an adaptor with aperture control otherwise the lens aperture will remain shut at f22 (whatever the min is).
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
John Cal
OP John Cal Regular Member • Posts: 465
Hi Roger, I'm aware of that and ordered the adapter with the aperture contol, the same as my Pk to Fujifilm adapter which works well on my Fujifilm bodies.
Cheers
John
John Cal
Wow that looks great. I have DA star f4 300mm so it looks like it may be a winner 🏆 thanks for sharing your photos much appreciated.
Kind regards
John
Kind regards
John
You will need to develop a feel for how much to stop down that lens to get good results. Wide open on these older lenses is usually not nearly as good. The adapter you will be using is not likely calibrated in true f-stops. In that case, just make note of how far you have to go to get the best results. The lens will likely have a sweet spot were it is the best.
And use Aperture Priority Mode so that shutter speed can vary, and it is best to choose Auto ISO.
And I turn off shake reduction when on a tripod and I use a remote shutter release.
Good luck using this lens.
John Cal
Thanks mate I post some pics when I get the adapter.
John Cal
Yes I guess it will take a while to fine tune the best settings I post some images when I get the adapter. Thanks for the advice 🙏
Mike Micro 43 Regular Member • Posts: 131
Hi,
Yes I use the Pentax-A 645 300mm Green Star with 2x teleconvertor for moon shots. It works really well with my Olympus EM-1 mkII, although focussing is a bit tricky!
I've recently tried it with both the 2x teleconvertor and the 1.4x teleconvertor (2nd shot) and this seems to work pretty well too. I think it's great the way you can stack teleconvertors...
Actually the Pentax 645 2 x teleconvertor is really good - super sharp. It works well with my Pentax 645 120mm F/4 Macro well too.
Mike.
Oly EM-1 mkII + Pentax-A 645 Green Star 300mm F/4 at F/5.6 + 2 x Teleconvertor
Oly EM-1 mkII + Pentax-A 645 Green Star 300mm F/4 at F/5.6 + 2 * Teleconvertor + 1.4 x Teleconvertor
And here's another shot with the 300mm and 2 x TC:
Oly EM-1 mkII with Pentax-A 645 Green Star 300mm F/4 + 2 x Teleconvertor
Mike Micro 43 wrote:
Hi,
Mike.
John Cal
Hi,
Mike.
Awesome shots Mike 👏.  I'm looking forward to getting my adapter, moon shots are one of the reasons for buying it. I hope I can do it justice your shots are excellent 👌
