Aperture on Tele-Xenar 4/135 does not open all the way - why?
xtam667 Regular Member • Posts: 221
I have got this vintage Schneider-Kreuznach lens in DKL mount. I push the aperture lever to the max but the aperture does not open all the way like in any other lens I have seen:
This is supposed to be the f4 max aperture on a 135mm lens
What is with this lens? It is near mint and the aperture lever and focusing ring work fine. Another thing I noticed is that it closes to a much smaller opening at f22 compared to another 4/135.  A mystery to me given how good the condition of the lens is and apparently working as intended.
Lightshow
Lightshow Veteran Member • Posts: 7,722
Re: Aperture on Tele-Xenar 4/135 does not open all the way - why?
Sounds like the aperture mechanism has slipped somewhere, either the aperture ring, or most likely the aperture basket has either set screws or a jam ring that has become loose the basket has shifted.
A Manual Focus Junky...
One photographers junk lens is an artists favorite tool.
http://www.flickr.com/photos/lightshow-photography/
[My Lens list](http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow)
####Where's my FF NEX-7 ?????
https://c1.staticflickr.com/1/447/31518420576_7916966b11_b.jpg
https://c2.staticflickr.com/2/1962/31024497798_85526ac8ca_b.jpg
Firmware request:
-A button map for toggling the EVF & LCD
-Still waiting for the minimum shutter speed with auto ISO for my NEX-7 and A7r. I know it will never happen.
-Customize the display screen layout, I'd love to have both Histogram and level at the same time.
-More peaking options, being able to set peaking sensitivity and a threshold level.
-An RGB overlay on the histogram https://c1.staticflickr.com/1/602/20236258313_c604dd9522_n.jpg
-An option to return the focus assist zoom to one button press
-An option to return to how the NEX-7 handled playback, ie. center button to zoom, then you could use the control dial to zoom in and out, then center button to exit the zoom mode.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Leica Elmarit-M 24mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +20 more
OP xtam667 Regular Member • Posts: 221
Thanks. Is this complicated / costly to repair?
Rol Lei Nut Veteran Member • Posts: 5,889
DKL mount lenses have two aperture levers (one isn't so obviously visible). One sets the aperture and one opens and closes the diaphragm when the shutter is released (when used on its original bodies). It could be that the aperture setting one is set to closed down a bit.
