Maxxum 9000 Focusing Deep
Started Dec 3, 2021 | Discussions
Guitarsam New Member • Posts: 2
So, Ive got a brain bender for you today. Ive got a 9000 that Ive shot 2 rolls that came out where the focus was really deep and out from the subject. Sometimes on a subject 2-3 meters away and It was focused on trees in the background. I know the lens is good because ive used it on my 7000 for a long time with no issues. I put the lens on both cameras locking in the focus ring with some tape and it seems in the VF the focus is the same across the cameras. The only thing I could think is that the flange distance is off or something. I got a tape measure and found that the flange on the 9000 is around 1mm farther away from the film plane from the 7000. What makes no sense is if that was the case and there was an issue here you would think the distance being longer would make the focus be closer not farther, Looking for some advice on things I could check or do to adjust a distance and get my photos in focus!
Thanks in advance,
Sam
neilt3
neilt3 Veteran Member • Posts: 3,008
Re: Maxxum 9000 Focusing Deep
Even with shims between the body and mount , there isn't enough used for it to be 1mm out .
Just a few thou .
Is the pressure plate on the back missing ?
That would account for that difference .
If you can manual focus , and the pictures come out fine , then the focus screen is in correctly rather than being upside down .
The AF unit being out of whack would also cause focus issues , but it's the 1mm registration distance you mention that's the bit that's odd .
Check the back while it's open .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
MikeInOr
MikeInOr Senior Member • Posts: 1,630
Do you have another lens you can try?  If a different lens shoots without focus issues then I would suspect the original lens as the problem.  If a different lens has the same issue I would then suspect the 9000 body.
 MikeInOr's gear list:MikeInOr's gear list
Sony SLT-A55 Sony a7R IV Sony 20mm F2.8 Sony 100mm F2.8 Macro Sony FE 12-24mm F4 +11 more
