Shinobi Atmos + G9
Started Dec 2, 2021 | Discussions
DH007 Regular Member • Posts: 220
Shinobi Atmos + G9
Anyone using these two together?
I'm looking for a monitor so I can see focus points a little better in the studio but be mobile enough to take on location for video.
I remember with he G7 it would black out an external monitor when it was recording :/ Can anyone confirm when you record with this that you can see what is being recorded and any  comment on input lag etc.
Thanks!
 DH007's gear list:DH007's gear list
Panasonic Lumix DMC-G7 Panasonic GX850 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS +10 more
Panasonic Lumix DC-G9 Panasonic Lumix DMC-G7
say_doyster Regular Member • Posts: 147
Re: Shinobi Atmos + G9
It does not black out the external monitor while recording (in fact, both monitors are active - Shinobi and G9 back screen).
Bill
 say_doyster's gear list:say_doyster's gear list
Canon EOS 5D Mark III Canon EOS 5DS Panasonic Lumix DMC-GX8 Panasonic GH5 Panasonic Lumix DC-G9 +1 more
OP DH007 Regular Member • Posts: 220
Bill
Thanks Bill!
Any lag / delay?
DaveTheAffable Contributing Member • Posts: 565
Thanks!
I use the Shinobi on my GH5 for stills and video. I like it ALOT.
Be sure to use a HDMI cable clamp to support the cable where it meets the G9. As with any camera, a good bump on the cable can sometimes damage the HDMI port.
Dave
 DaveTheAffable's gear list:DaveTheAffable's gear list
Nikon D700 Nikon D750 Panasonic GH5 Panasonic Lumix DC-GH6 +2 more
DH007 wrote:
Bill
Thanks Bill!
Any lag / delay?
GH5, GH5S and G9 all have a bit of HDMI output lag. How many frames, I don't know, but some folks on the DVXuser forum who manually pull focus complain it is enough to make pulling focus a bit of a challenge when it needs to be timed precisely using an external monitor.
I have not tested it that way, but when recording audio directly to a Ninja Inferno or Ninja V (not recording audio to the camera), the audio requires a delay of between 3-5 frames to match up. YMMV
Bill
Interceptor121 Veteran Member • Posts: 8,691
I use a Ninja that takes 4K input while the shinobi only accepts HD
the lag on all lumix is 3-4 frames so if you shoot 60fps you don’t notice it. If instead you shoot 24fps is pretty bad. Consider that even the LCD has 1 frame of lag
One thing to consider is that the atomos products expect a legalised output so the exposure tools may be off compared to the camera make sure you are using the 64-940 output not the full output
this is the reason why I have kept a SWIT monitor and unless it is bright this is what I use so I do not need to mess around with the levels
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Thanks for the input. I'm more worried about lag I would see that would be almost half a second or more which I saw was pretty common on some other external monitors when I researched it a couple of years ago.
A few frames I can handle the stuff I do isn't terrible precision just the eyes are getting a bit on so having something bigger will help.
Appreciate all the insight.
