Would you take just an fp L and 20-60mm?
Started Nov 26, 2021 | Discussions
Scottelly
Scottelly Forum Pro • Posts: 18,026
I was reading in this thread:
https://www.dpreview.com/forums/post/65669891
I have been traveling by car (SUV actually), and I keep thinking about how I could reduce the weight and bulk of my kit, which currently doesn't even fit in my big backpack. Next year I hope to fly to a few places, like the U.K. and Vietnam. I just can't take all my cameras and lenses, so I've been thinking I might get a versatile camera, one zoom, and a nice prime, but I figured I would get a Sony A7r IV. The problem with that idea is I just can't get what I'd consider a great all-around lens for it.
I like how wide the Panasonic 20-60 can go. I've been thinking I might get that lens and a Sigma fp L.
I do still plan to get a Sony A7r IV and Zeiss 40mm f2 Batis first, and I will use my Sigma Art lenses on that with my MC-11 adapter. (14-24mm f2.8 Art and 24-70mm f2.8 OS Art, plus my 50mm f1.4 Art). That is really not a particularly carryable set-up though. I was thinking about getting a couple of small primes to go with the Sony camera that I'll have with the 40mm lens, such as the new Sigma 24mm f2 I (16mm shorter focal length) and the new Sigma 65mm f2 I (25mm longer focal length). Three lenses just seems like a lot though, and not only would it be bigger and heavier than the fp L with a Panasonic 20-60mm f3.5-5.6, but it would cost more to replace, if it gets stolen too.
I wonder if I'm crazy to even think it might make sense to take just one lens and camera though. Would you take just an fp L and a 20-60mm lens on a photo trip?
Maybe I should consider "enhancing" that kit with Sigma's new 90mm f2.8, which Marco has recently used, and posted photos from. Still, I wonder if I will miss my 100-400, which I used extensively on my SD1 Merrill to photograph some wildlife on my trip so far (shooting a coyote, some bison, prairie dogs, prong horn antelope, and long horn sheep). I even shot some distant mountains with that long lens, though most of the time I just used my Nikon with the 24-135mm lens at the long end, rather than swapping lenses on my SD1 Merrill. I remember using my long lens several times down in Chile, shooting wild animals again (flamingos and vicunyas), so maybe it would make sense to at least take the 100-400 along, "just in case."
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Sigma SD1 Sigma SD1 Merrill Sony a7 Sony a7R
xpatUSA
xpatUSA Forum Pro • Posts: 23,016
Re: Would you take just an fp L and 20-60mm?
Thinking of the Sony+24-70mm versus fp L+20-60mm, taken from the plethora of alternatives mentioned above:
At the long end, the Sony+70mm gets you 7008 pixels wide and a horizontal angle of about 29deg. For those same 7008 pixels, i.e. cropping the 9520pixel width, the fp L+60mm will give you a horizontal angle of about 25deg ... where less is more "reach" for the same resolution.
At the wide end, the Sony+24mm gives you a horizontal angle of about 74deg. The fp L+20mm will give you a horizontal angle of about 84deg at a higher spatial resolution.
Looks like the fp L+20-60mm wins: 25-84deg versus 29-74deg ...
Just interested in the technology.
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Mike2019 Contributing Member • Posts: 897
I have had an fp L with the 20-60 for more than 6 months now, and am thrilled with the results that I get when travelling!
I have been using it in the 21:9 ratio only, and have gotten amazing pictures!
fp L is a very exciting camera, which is just amazing with the 20-60!
amweber21 Regular Member • Posts: 227
I also have the fp L and 20-60mm. For traveling, and in good light, it's a great setup. Even cropping in 1.53-2x for 90-120mm works for me in a pinch.
For some the Sigma 28-70mm might work better, but I like the extra width and smaller/lighter footprint.
I bring a single prime, the 35mm f2, if I'm worried about lower light, but can do mostly all I need with the 20-60mm.
 amweber21's gear list:amweber21's gear list
Sony a7R II Panasonic S1 Sigma fp L Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 +14 more
Scottelly
OP Scottelly Forum Pro • Posts: 18,026
Interesting. Thanks for your comment Mike!
Scottelly
Your comment and Mike's make me think maybe I'm not crazy. Thank you.
Scottelly
Yes, and I think it would be much lighter than my 24-70mm f2.8 OS Art on the Sony A7r IV. It almost seems like I ought to get the fp L and that 20-60 just to try it, if nothing else. I guess I could use the Sony A7r IV with my Art lenses and my 100-400 normally, but take the fp L with that lens as a backup camera and what I can take ou when I'm going on a long hike or something like that, and if I get an MC-21 to use my Art lenses on the fp L the fp L can be an all-around backup camera too. It might even make sense to get an 85mm f1.4 Art in SA mount too.
I also have a Sony A7Riv, but almost do not use it since I bought the fp L with the 20-60.
The fp L is really a very exciting camera to work with.
Try it, and you will see!
frankonian Regular Member • Posts: 294
Thank you for the food for thought in the direction of Panasonic.
I will get this lens for the fp L and test whether it is okay for me.
The compactness of the combination appeals to me a lot, even if I believe that the quality of my Sigma Art lenses cannot be matched.
Scottelly
Wow! That's even more interesting Mike! What lenses do you have for your Sony?
Scottelly
On my cross-country trip I've found that when I go walking/hiking I normally take my SD1 Merrill with an 8-16mm lens, giving me 12-24mm equivalent, and my Nikon D810 with a 24-135mm on my tripod. Sometimes though I take just one camera with a zoom lens on it. That is sometimes my SD1 Merrill with my 24-70mm f2.8 OS Art, but usually it is my Nikon with the 24-135mm lens. That leads me to believe a single lens solution is probably what I should seek. I don't know if 20mm will be wide enough or if 60mm will be long enough, but I plan to get the Sony with a 10mm lens, and I will have that for super-wide shots, and I guess I could take that with me. I could see myself taking that with a 90mm f2.8 I along with an fp L and the 20-60. I think the 90mm lens will fit in my pocket, and of course I can take a small backpack with a longer lens too, like my 100-400 OS C, with my MC-11 and MC-21 adapters, so I can use it on either camera. I guess if I'm taking a small backpack though, I could take my 14-24mm f2.8 Art and 24-70mm f2.8 OS Art along too. Then I would have the most versatile kit, without taking all my gear.
I got one for a little over 300 euros.
If it's not as good as hoped, I can even sell it again for a profit.
I have 3 Batis lenses, as well as Sony Zeiss 24-70, Sony Zeiss 16-35, the 24-105, and 70-200 f4, Sony Zeiss 50mm 1.4, and Sony Zeiss 35mm 1.4
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
Yes, I would take a fp L and the Panny 20-60 lens.  Was strongly attracted to the lens when I bought my fp L, but instead I went with the Sigma 45mm F2.8 DG DN, another great all around lens.  The Sigma 45 is plenty sharp enough to crop, but that Panny 20-60 is nice!
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
Scottelly
Whoa! Nice set of lenses! How does the Sony with the 24-70 compare with the fp L and the 20-60? From your list I would guess that's the closest match.
I wonder if you have the same issue as me . . . lens overkill. At least I guess that's the name for it. I still find myself wanting even more lenses too!
Scottelly
Thanks for your comment Tom. I'm seriously wondering if I shouldn't just sell all my gear and just get that combo and the new 90mm f2.8 I. I think that might just be a little bit too crazy though.
Tom Schum
I like the 20-60 very much because of the 20mm wide end.
I was never happy with 24mm for travel and hiking.
20mm makes possible many wide shots in nature and cities, which are impossible with 24mm.
I do not care that much for the 60-70mm end.
xpatUSA
For what's worth, Scott, I don't think it's too crazy.
Think of el famoso Henri Cartier-Bresson. I've read that he shot with one camera and just a 50mm prime ...
I myself am down to just (!) four cameras - each having a specific purpose.
a point-and-shoot that fits in the pocket
a top-of-the-line u4/3 with all the options needed for my shaky hands, lack of limber and poor eyesight. (IBIS w/dual I; fully-articulating LCD; magnified manual focus with peaking).
an older u4/3 modified for full-spectrum shots
an original Sigma/Foveon which makes me work for a good shot
Tom Schum
You have to consider what subject matter you shoot, and so on.  Lack of a mechanical shutter might be a show stopper.
Tom Schum
Ha Pham Contributing Member • Posts: 552
Hi Scott,
My suggestion: Sony A7r IV, Tamron 28-200, Sigma MC-11 adapter for your wide lenses. The Tamron 28-200's image quality is very favorably reviewed.
For my next trip to Vietnam, I will take my Sony A7c, Tamron 28-200, and the Sigma DP1. Attached is a picture of the Sony A7c with the Tamron 28-200.
Ha
Indian Wells Tennis Tournament 2021
 Ha Pham's gear list:Ha Pham's gear list
Sigma DP1 Sigma SD15 Sony a7R IV Sony a7C
