Redmi Note 4 - Update OS
Started Nov 23, 2021 | Discussions
atom14
atom14 Veteran Member • Posts: 3,299
Hi All.
I have a Xiaomi Redmi Note 4. The OS was u0dated once some years to to the present:
"Android version ... 6.0 MRA58K"
Can I get it to update to a later Android version? It doesn't matter if it's an involved process, as I'm starting to get non-compatibility messages when trying to install apps. It's quite a suitable phone in all other ways, so I don't want to just go and get a new one - and face the same problem again later
Thanks,
atom14.
Adoubeur
Adoubeur Regular Member • Posts: 110
Re: Redmi Note 4 - Update OS
Hello,
Yes you can, I did it with my Redmi Note 4 two years ago.
You cannot do it in an official way, you have to root the phone and install a "rom" (this is how Operating Systems are called in the smartphone nerds world ;-)).
The steps are :
1 - Unlocking the bootloader. You will find many tutos on the web for that. I don't remember precisely how I did it, but you need to ask Xiaomi to unlock it, and it can take 2 weeks before it's done.
2 - Once the bootloader is unlocked, you need to install an alternative recovery program called TWRP. Lots of tutos are available for this too.
3 - Now, you have to boot on TWRP and install a custom ROM you previously downloaded on internet.
There are tons of custom ROMS available, some are based on Android 7, some on Android 8, etc.
I tried several roms and my advice is to stay on Android 7 based roms for the Redmi Note 4, they work better and are more fluid.
All this can be done very easily by using XiaoMiTool :
https://www.xiaomitool.com/V2/
Custom Roms for Xiaomi Redmi Note 4 can be found on this website :
https://forum.xda-developers.com/f/xiaomi-redmi-note-4-snapdragon-roms-kernels-re.6145/#romList
 Adoubeur's gear list:Adoubeur's gear list
Sony ZV-1 Fujifilm X-T30 Fujifilm X-T4 Fujifilm XF 18mm F2 R Fujifilm XF 35mm F1.4 R +9 more
atom14
OP atom14 Veteran Member • Posts: 3,299
Adoubeur wrote:
Hello,
The steps are :
Thanks for your comprehensive reply, Adoubeur. I will consider doing this.
atom14.
