Panasonic G9 or a 100-400 lens
Started Nov 23, 2021 | Discussions
Eightace Regular Member • Posts: 370
I currently have a GX9 and the 100-300ii.
I'm massively into wildlife photography and i thought both the lens and G9 would improve that, even if not by a huge amount.
I've toyed with apsc or full frame but i have realized that i will never enjoy carrying 6 or 7lbs around or enjoy holding it up for 200 or so photo's
I really want both but i just hate spending so much at once I will probably end up with both so i should just get them now. But i won't.
I'm usually cropping with 600mm. I'll still be cropping with 800. But a 2x crop with 800mm is a fair distance right.
I went out yesterday and out of about 5 birds i tried to photograph, only 1 i was happy with.And even then i think that extra bit of range would have made all the difference. It was just one of those days when you can't get close enough.
I know i'll be happy with the 100-400 but i'm not sure if the G9 will be more beneficial than i'm giving it credit for too?
Is the animal detect helpful. Will my keeper rate improve. Is it a total waste of money.
I have been after a new camera for a while.Sometimes its just easier, especially on a windy day or at short notice, to have a 2nd camera ready to go. I know i'll probably be upping the weight but still saving at least 1kg over say a nikon apsc setup and the gx9 in my backpack with a small lens , i won't know its there.
I had a tz90 but i gave that to my daughter and tbh i did want a bit better quality.
So i thought a G9 would be nice to have for two reasons.
But then 800mm. That would be nice too
Anybody had experience of going from GX9 to G9 or the 300mm to the 400mm?
Skeeterbytes Forum Pro • Posts: 23,182
Re: Panasonic G9 or a 100-400 lens
Strictly from an IQ perspective the 100-400 will give you an instant improvement--it's a better lens in every way. The camera upgrade will give more customization and probably more in-focus keepers, but IQ won't budge so less of an upgrade.
Budget and time will accommodate a camera update when the time comes, and perhaps when you're ready there will at last be a G9 replacement.
Good luck!
Rick
JasonTheBirder
JasonTheBirder Senior Member • Posts: 3,967
6
Lens first, always. The 100-400 will improve your photography much more than the G9. 300 on a 20mp micro four thirds is too short in my opinion and the 100-300 is weak at 300.
With birding there is no way around getting a long lens. However, I really do suggest you post the shots you don't like for evaluation because there may also be some basic technique that could be improved also.
My personal (noncommercial) website: https://jpolak.org/
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Olympus M.Zuiko Digital ED 60mm F2.8 Macro +1 more
OP Eightace Regular Member • Posts: 370
The reason yesterday was just small birds too far away. I was being a bit optimistic as opportunities were scarce. The nearest i got was a yellow hammer but as usual i'd got fed up and camera was switched off to save the relatively short battery. Soon as its in my sights, its off
One i could crop to something reasonable but a few more mm and i wouldn't have had to crop so much.
I suppose keeping my focus point on such a small object is always going to have some element of hit and miss. Just wondered if the G9 might help eliminate more of those occasions.
unhappymeal Senior Member • Posts: 2,624
I think there are occasionally exceptions to lens first. Something like the R5/R6 bird eye AF.
JasonTheBirder
....would not be at all impressive with a low end 300mm. A 5dIV with a proper lens would still smoke the R5 with a 100-300 zoom in almost every case.
CruisinonRt66
CruisinonRt66 Regular Member • Posts: 162
Hi there,
I have had both and I can say, I do not regret getting the PL100-400mm, it was a huge improvement over the 100-300. The quality of the pictures are just delightfull.
The GX9 is a great camera but not very suitable for wildlife and long lenses IMHO. I struggled with its small tiltable evf that also would always move up as I put my eye to it as I use glasses and also not having a decent grip. So the evf on the G9 is truly superb and  the grip is too. I do not have the G9 anymore (which I regret) as I wanted something less pro and smaller, and  I now use the G95 which is a bit more compact, but the image quality, the viewfinder and the grip are very good too and better than the GX9.
So a G95 and a PL 100-400mm is what i used most for wildlife and am completly happy with that.  I combine that with my FZ1000.2 for wider field of view instead of switching lenses.
Hope this helps. Cheers
 CruisinonRt66's gear list:CruisinonRt66's gear list
Panasonic Lumix DC-FZ1000 II Panasonic LX100 II Panasonic GX850 Panasonic Lumix DMC-GX85 Panasonic Lumix DMC-GF8 +8 more
john isaacs Veteran Member • Posts: 8,440
If you want to shoot wildlife/sports/action, get both.  You will eventually, and every day you wait is a day you aren't getting the shots.
Martin Ocando
MOD Martin Ocando Veteran Member • Posts: 6,720
I have both the G9 and the GX9, and the 100-300ii, and while is definitively a huge difference in handling and responsiveness, af, speed, etc. Nothing will get you any closer than the 100-400mm. I'm considering one myself, but a little bit farther away in the future, as I'm not really into wildlife just yet.
So I'd go with the lens first.
Martin
"One of the biggest mistakes a photographer can make is to look at the real world and cling to the vain hope that next time his film will somehow bear a closer resemblance to it" - Galen Rowell
 Martin Ocando's gear list:Martin Ocando's gear list
Panasonic Lumix DC-G9 Olympus 12-40mm F2.8 Pro Panasonic Lumix G X Vario 35-100mm F2.8 OIS Panasonic Leica DG Summilux 15mm F1.7 ASPH 7artisans 7.5mm F2.8 Fisheye +13 more
I'm happy with the GX9. I wanted a small body and thats why i bought that first.
I prefer articulating but not had any problems with the tilt-able even if i don't use it much at all.
I think i will find it fine with the 400mm.
But i've found myself doing wildlife photography more so the G9/400MM combo would work better.
Just wondered if i might be so impressed by the camera that it was worth buying first.
This is one i missed yesterday.
I think it was just my poor technique and it can happen with any camera but tbf it was like a spec of dust in the evf. Another thing that may help with the G9.
Would also have been a bit larger with the extra mm too , although probably not by much.
I need both really don't I
Trevor Carpenter
7
The 100-400 would not have helped.  A common thread on these forum has been I just bought a 100-400 and it's rubbish.  They then post a picture like that to prove it.  Remember a long lens is great at making close subjects even closer, it is not great at making good pictures from distant subjects
yeah i get you.
I do tend to get giddy. I have a B700 and i try and take photo's of things too far away quite often.
But i think if i could have focused on the bird it would have been a pretty reasonable photo with a small crop.
SteveY80 Senior Member • Posts: 2,087
In my opinion the G9's animal detect is pretty much worthless. My keeper rate when testing animal detect was significantly worse than when setting the focus point myself. There were too many shots where it detected the animal and highlighted it, only to actually focus on something else in the background/foreground.
On the other hand, G9 features like focus scope (zooming in while focusing) and near/far priority AF are genuinely useful. It also has much better C-AF for moving subjects, like birds when they're in flight, rather than on a stick. Not to mention a bigger buffer and faster dual SD cards for long bursts of shots. To me those are all nice to have when shooting wildlife.
I use a GX9 and G9 with my 100-400mm. If I had to choose between the G9 and 100-400mm then keeping the lens would be an easy choice. The G9's features and C-AF are nice, but I actually prefer the size and handling of the GX9 even when using a relatively large lens like the 100-400mm. Outside of shooting birds in flight, I'd definitely miss the extra reach more than I missed the higher end camera body.
 SteveY80's gear list:SteveY80's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM1 Sony a77 II Fujifilm X-M1 Nikon 1 J1 +1 more
Yeah i think the lens is my first choice.
I need to start getting closer though.
I don't always want to fill the frame but often i find 600mm just that little bit too little.
UrbanHobbit
UrbanHobbit Contributing Member • Posts: 997
Whatever you do, wait a few days for the sales!!!
 UrbanHobbit's gear list:UrbanHobbit's gear list
Olympus Stylus 1 Panasonic Lumix DMC-GM5 OM-1 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +15 more
jalywol
jalywol Forum Pro • Posts: 12,301
Get the lens
5
Cameras come and go, but glass is the constant.
I have a GX9 (and GX8, and GM5). I've had both generations of the 100-300mm, and two of the PL 100-400mm lenses (sold my original one when I did a system switch, missed it a lot when I came back to M43, so bought another one ).
The 100-400mm is, far and away, my most used M43 lens. It works very well on the GX9, and its output is terrific.
As with the 100-300mm, remember, holding technique matters, and you have to be aware of atmospheric distortion out at the long end, but once you get the hang of using this lens, it's just great.
One suggestion: get one of the hand grips for the GX9, and it makes the camera handle very nicely with the 100-400mm. I have the Panasonic one, but there is also an aftermarket one that people like a lot (and which has the advantage of not needing to be unscrewed to get the battery out, like the Panasonic version)
Remember, the GX9 and G9 have 20MP sensors with the current image processors, so your output from both is going to be almost identical. Keep the camera, get the lens.....and if Panasonic does update the camera/sensor technology down the road, THAT's the time to consider a body swap, not right now.
-J
steveg_777 Regular Member • Posts: 123
Yes
evetsf Senior Member • Posts: 1,707
If your budget will support it, both would good. I have both the G9 and GX9, and the G9 always gets the nod if I'm going out for some bird photos.
This photo clearly shows that the grasses behind the bird are in sharp focus, so the camera chose the wrong subject.
The G9 has AF tools, such as near & far focus, that would make it easier to ensure that the subject you want is what's in focus. The bigger EVF helps a lot too.
Of course, the extra reach of the 100-400 in that sort of situation helps too.
Steve
- The Hierarchy Approves -
All rights reserved for any images in my Gallery or included in a message. Specific exceptions may be granted upon request.
 evetsf's gear list:evetsf's gear list
Panasonic Lumix DC-GX9 Panasonic Lumix DC-G9 Panasonic Leica DG 50-200mm F2.8-4 Panasonic 12-60mm F3.5-5.6 OIS Panasonic Lumix G 20mm F1.7 ASPH +3 more
DH007 Regular Member • Posts: 220
The G9 is a much better camera than the GX9 IMHO.
I have the GX9 and the 100-300 II. You can not hit at distance with the same accuracy as you can on the G9.
Program the scope button to the front you can hit a subject at distance, exactly where you want with much better certainty. The GX9 I can hit a rough area but the G9 you can zero in and once you program that muscle memory you can scope something super quick and hit the eyes, make sure the autofocus isn't hitting the background etc.
I bought another G9 since i split between an long and short zoom / prime for my work. The GX9 is good for street photography since it is small but it isn't a great camera. The G9 is a great camera.
Then get the 100-400.
That scope can be set to 10x magnification so I'm able to to pick out a street sign from serious distance away and hit it.
 DH007's gear list:DH007's gear list
Panasonic Lumix DMC-G7 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic GX850 Panasonic Leica DG Summilux 15mm F1.7 ASPH +10 more
