Turn your DP1M into a DP0M !!!
Started Nov 23, 2021 | Discussions
rick decker
MOD rick decker Forum Pro • Posts: 19,097
12
Here are some samples.  The add-on lens is the ricoh .75x GW-3
M
Q
M
Q
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
Sigma DP1 Merrill
DavidWright2010 Veteran Member • Posts: 3,733
Re: Turn your DP1M into a DP0M !!!
Wow!
I think my DP1M is going to awaken from it's slumber and start a new life.
David
 DavidWright2010's gear list:DavidWright2010's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Merrill Pentax K-1 +1 more
Human Elements
Human Elements Senior Member • Posts: 1,051
Oh hey, you bought one, nice example images! Great little addition to the bag, isn't it?
 Human Elements's gear list:Human Elements's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Fujifilm X-T4 Fujifilm XF 35mm F1.4 R +2 more
rick decker
OP MOD rick decker Forum Pro • Posts: 19,097
I think it is.  Although  not equal to the DP0, it is quite a bit better than I expected. I have ordered step-up  (DP1/2/S/X) and step-down (Quattro) rings.  I tried it on the DP2M and there was major issues as regards sharpness.  I will try the DP3M.  If it works on the DP3M I could carry the 1 and 3 and cover the same range as the DP Quattros.
SigmaChrome Forum Pro • Posts: 15,728
Looks like really nice lens, Rick.
It's a pity I don't have a DP1 Merrill.
Vitée
Capture all the light and colour!
http://www.pbase.com/vitee/galleries
 SigmaChrome's gear list:SigmaChrome's gear list
Sigma DP1 Sigma DP2 Merrill Sigma DP3 Merrill Sigma dp0 Quattro Sigma SD14 +42 more
docmaas
docmaas Veteran Member • Posts: 7,061
There is a newer albeit heavier converter the gw-4. It's tested here on a dp1Q:
https://www.dpreview.com/forums/thread/4463882#forum-post-63591687
Mike
"Laoma shitu" "An old horse knows the road" Chinese Proverb "Dao ke dao, fei chang dao. Ming ke ming, fei chang ming" Laozi
"At every crossroads on the path that leads to the future, tradition has placed 10,000 men to guard the past."
Maurice Maeterlinck
Priscilla Turner
Priscilla Turner Senior Member • Posts: 1,957
I still use my DP1 with my Nikon converter for lovely relatively WA results. Just use f/8 or smaller and you're fine.
'To see, not with, but through the eye.' [William Blake]
'The only thing necessary for the triumph of evil is for good men to do nothing.' [Edmund Burke]
'Power tends to corrupt; absolute power corrupts absolutely.' [Lord Acton]
http://www.flickr.com/photos/22905474@N06/
http://priscillaturner.imagekind.com/store/
 Priscilla Turner's gear list:Priscilla Turner's gear list
Pentax K-3 II Sigma 10-20mm F4-5.6 EX DC HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 12-24mm F4.0 ED AL (IF) Tamron SP AF 90mm F/2.8 Di Macro +5 more
rick decker
One More Sample DP0M vs DP1M
DP0M
DP1M
quma
quma Forum Member • Posts: 67
Re: One More Sample DP0M vs DP1M
I am quite impressed by the image quality, considering that the corners of the DP1m are not that sharp to begin with.
CA is relatively pronounced, but fixable for sure.
 quma's gear list:quma's gear list
Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill Sigma SD1 Canon EOS R +9 more
rick decker
Thanks for the input..I will take a shot at the CA later today
