Jared Polin tests A1 vs R3 AF
Started Nov 23, 2021 | Discussions
And-roid
And-roid Senior Member • Posts: 3,201
Re: The R3 af is working differently to the R5?
Tr3v420 wrote:
Hoka Hey wrote:
And-roid wrote:
Anyone else notice that he's using expand spot/area and it's picking out faces and tracking?
aftab wrote:
Slight edge to R3, according to him.
I saw that when he posted his RAWs from the R3. Wonder why he is not using Human Eye AF?
He is. The R3 allows face/eye detect in any focus mode.
Yes, R5 should allow this too!!
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
You may well be right, but that's not what it looks like when you review the RAW files in DPP4. The focus squares are large blocks on the face rather than small blocks on an eye.
Joe
And-roid
Correct, I didn't see eye detect going on, only face!
Mike Engles Senior Member • Posts: 2,573
Quite right!, Will it get it, yes, in the R52
George1958 Senior Member • Posts: 1,475
Re: Jared Polin tests A1 vs R3 AF
So what ever your choice might be it’s hard to go wrong .
 George1958's gear list:George1958's gear list
Sigma DP1s Sigma SD15 Olympus PEN E-P3 Sigma sd Quattro Olympus E-M1 II +6 more
The problem is that it wastes time and does go wrong if you you use 2 button focus, as they are not linked and we fool ourselves if we think they are.
There should be just one focus button, with modifiers for spot size and turning of face and eye for more general tracking.
And-roid
Well, the R3 looks to be much better, the A1 doesn't select faces here, its all subject based, so it's actually quite random, R3 looks as if its far more repeatable and dependable!
dmanthree
dmanthree Forum Pro • Posts: 10,302
pawn wrote:
Thanks aftab
As a R5 user, I am hoping some of that AF will be available in the upcoming firmware upgrade.
Maybe. Some features are being added, but follow focus like that require added processing power. Not sure the R5 has the same AF hardware as the R3.
---on the cutting edge---
It’s always nice that things work in a way that seems most effective for our photography . I mind that issue less then yourself Mike, it would not deter me in itself
Hoka Hey
dmanthree wrote:
pawn wrote:
Thanks aftab
I thought that the R3 was using the same processor as the R5. Does the the BSI stacked sensor or lower resolution require less processing power that can be diverted to follow focus?
Joe
ProDude Senior Member • Posts: 4,851
Hoka Hey wrote:
dmanthree wrote:
pawn wrote:
Thanks aftab
I don't believe that the processor in the R3 is different. It's entirely the sensor, which provides it's speed mainly. That's why I believe the focus update should give us very similar results. We'll find out next week. Can't wait!
Name the gear and I've probably owned it and used it.
dmanthree
ProDude wrote:
Hoka Hey wrote:
dmanthree wrote:
pawn wrote:
Thanks aftab
I'd be very surprised if a high-res non-BSI/Stacked sensor can keep up with the sensor in the R3.
KLO82 Senior Member • Posts: 1,527
From R6 user manual:
 KLO82's gear list:KLO82's gear list
Canon EOS RP Canon EF 50mm F1.4 USM Canon EF 85mm F1.8 USM Canon EF 24-70mm F2.8L II USM Canon RF 35mm F1.8 IS STM Macro
Hoka Hey
I'm not sure what your point is here.
Joe
AtmaWarna Regular Member • Posts: 119
yeah R3 AF seems more advance than the A1.  Altho ,in his recent instagram story he mentions that the R3 shown flickering artifact from electronic board like A9 did while Sony A1 don't.
maybe he will explain this in his next video.
 AtmaWarna's gear list:AtmaWarna's gear list
Canon EOS Rebel T6i Canon EOS R7 Canon EF 35mm F2 IS USM Canon EF-S 55-250mm f/4-5.6 IS STM Sigma 100-400mm F5-6.3
