Setting accurate focal length with the 18-55mm f2.8-4 R LM OIS Lens
Started Nov 21, 2021 | Questions
bs1946
bs1946 Veteran Member • Posts: 7,778
I just bought a used, but barely used, mint condition XF 18-55mm f2.8-4 R LM OIS lens. This is the second Fuji zoom I ever owned and the first was the kit lens that came with the XA1 that I briefly owned back in 2014 and remember little about.
Today I took the 18-55mm out for a test drive on my X-T1. If I set the zoom ring at 18mm or at 55mm, that is what the exif data showed after I downloaded the images. But with 23mm and 35mm marks focal lengths were slightly off the mark. I did some testing at home with the zoom ring settings at 23mm and 35mm and I couldn't get an accurate match; either fraction under or over. Plus anywhere between the four FL numbers would be a total guess. I did not see any indication in the EVF or the LCD telling me the FL setting and going through the menus, I couldn't find anything to turn on to display that. So, am I missing an option to turn on or is that just the way it goes with Fuji zooms?
Bill S.
www.flickr.com/photos/wrs1946
“Blend in with the people and have as little equipment as possible”
- Alfred Eisenstaedt -
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
Fujifilm X-A1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm X-T1
Martin_99 Veteran Member • Posts: 4,651
Re: Setting accurate focal length with the 18-55mm f2.8-4 R LM OIS Lens
It's the same with Sony cameras. You can see FL only after downloading in PC. Not sure why, camera surely have this information, but simply not display it. At the end it doesn't matter, but would be nice to see it.
 Martin_99's gear list:Martin_99's gear list
Sony a6400 Sony Carl Zeiss Sonnar T* E 24mm F1.8 ZA Sigma 56mm F1.4 DC DN | C (X-mount) Sony E 70-350mm F4.5-6.3 G OSS Tamron 150-500mm F5-6.7 Di III VC VXD +1 more
io_bg
io_bg Senior Member • Posts: 1,548
You can only view the focal length of a photo during playback. Hit the display button till you see the RGB histogram, then up twice and you'll see the EXIF details, including the focal length in mm.
I don't think it's possible to preview your focal length before taking a photo, but either way why would you need that? Just zoom for the framing you need. A couple of milimeters here or there won't make a significant difference
Best,
Yoan
 io_bg's gear list:io_bg's gear list
Fujifilm X-T30 Fujifilm XF 35mm F1.4 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +4 more
