T3I - images not downloading
Started Nov 21, 2021 | Questions
HRC2016 Veteran Member • Posts: 6,874
I'm trying to assist a friend with a Rebel T3i and could use some assistance.
He recently went on a trip to California and took several hundred pictures. Pictures from other trips were still on the SD card.
When viewing images on the camera everything seems fine.
When plugging the camera into the computer via the supplied USB cord, images from the California trip do not show up on the computer (using the default photo viewing software). Images from other trips do.
Same results on another computer, and when using a card reader instead of the cord.
No error messages or warnings are displayed.
Any thoughts?
The card is Sandisk bought from Adorama about a year ago. He's been able to view/download images prior, so I don't think the card itself is the problem.
Is there any Canon specific software that he should try (for downloading and viewing)?
Thanks in advance.
Satan loves the shadows - and the highlights.
 HRC2016's gear list:HRC2016's gear list
Panasonic Lumix G Vario 45-200mm F4-5.6 OIS Olympus M.Zuiko Digital ED 12-50mm 1:3.5-6.3 EZ Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Sigma 150-600mm F5-6.3 | C Olympus 12-100mm F4.0 +2 more
Canon EOS 1100D (EOS Rebel T3 / EOS Kiss X50) Canon EOS 600D (EOS Rebel T3i / EOS Kiss X5)
JPAlbert Senior Member • Posts: 1,296
Re: T3I - images not downloading
Have you checked the card (connected via a card reader) with a file manager, exploring and looking around?
Could the trip pics have been "nested" into a folder on the card someplace?
Also, I'd try a second card reader if one is available...
stevet1 Senior Member • Posts: 1,300
Any thoughts?
Thanks in advance.
HRC2016,
Were the pictures taken in in RAW format perhaps?
Can you tell if they are there by using Windows Explorer?
If they are RAW files instead of jpgs, you can try using Canon;s DPP4 software.
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
OP HRC2016 Veteran Member • Posts: 6,874
Solved:T3I - images not downloading
This has been solved.
We used a different card reader and different computer.
It was discovered most recent images, shot on the Canon, were showing up in the folder labeled for the Panasonic images taken prior (to using the Canon). I don't know if the Panasonic folder was checked previously.
All were downloaded successfully.
Thanks for the suggestions. I hope this helps others.
Original post:
No, JPEGS.
We're going to try a different card reader.
