Battle of Macros which one you like the most?
Started Nov 15, 2021 | Photos
Interceptor121 Veteran Member • Posts: 8,691
Playing with my new light box. I need a macro slide however this gives an idea
Here Panasonic 30mm (my favourite for small widget photography) Panasonic 45mm (my favourite for flowers and underwater) Zuiko 60mm my favourite for bees and moving things
Shots are 16 focus stacked in photoshop. Interesting to see the chromatic variations. White balance was set fixed on a whibal card and lighting and exposure settings identical
Framing not totally identical due to lack of hardware!
30mm
45mm
60mm
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Comment & critique:
JosephScha Veteran Member • Posts: 7,249
Re: Battle of Macros which one you like the most?
5
I've been looking for the chroma difference you claim to see.  I think the two Panasonic lenses are indistinguishable.  The Oly lens is slightly redder/warmer.
Honestly, the difference in focal length is much more obvious than any chroma difference, to me.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica DG Summilux 15mm F1.7 ASPH Panasonic Lumix G 42.5mm F1.7 +7 more
Simon97
Simon97 Veteran Member • Posts: 3,443
I have to go with the Pana 30mm as it's the only one I have. I bought it mainly for copy work since macros are usually well corrected and need minimal post work. It doesn't disappoint as it's the sharpest lens I own or have tried.
 Simon97's gear list:Simon97's gear list
Canon PowerShot ELPH 360 HS Panasonic Lumix DC-G100
edspen Regular Member • Posts: 310
I've had two 45's both excellent. Keep one on a G9, gave one to a friend who chucked the macro they had. Dual IS with the G9, but fun to pop it on my GX85 on some field trips. The light weight is great, compared to a 100mm IS canon macro on a canon body. And, comes with a lens hood, what will they think of next (free filters, LOL). I had the Olympus 60 macro which is very sharp, but the limit control on the side of the lens seem awkward. The speed of the Leica 45, its balance, and the free hood (again LOL) made it a keeper. Now here is question: with the 2x crop factor are we getting 1:1 or 2:1 or have I opened a can of worms ? (bag of snakes, last LOL).
OP Interceptor121 Veteran Member • Posts: 8,691
We are getting 1:1 i.e. a 17.3x13mm frame size which is the sensor size.
We do get 20.3 megapixels though which is equivalent to 81.2 megapixels that no full frame camera has but that does not make it 2:1
Can of worm just popped open!
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,435
6
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S +1 more
jalywol
jalywol Forum Pro • Posts: 12,301
45mm
It's the image that popped out at me as having the best color gradation of all of them (and no, I didn't look at which lens had shot each image until after I selected my favorite)
-J
Trevor Carpenter wrote:
As a dedicated non pixel peeper I can't tell them apart
They are focus stacked should not be major differences at 2.8
Resolution differences are more apparent on single shots and if you look at edges (my subjects are not at the edges)
Shots at f/11 reveal differences on that account however a lens may work different at f/11 than it did at say f/4
(unknown member) Senior Member • Posts: 1,941
None of your images have demonstrated why a photographer would use different focal lengths for different environmental inclusion.  for in the field bug shooting a zoom with close up filters is the best tool for that job.
Ds
The confusion starts when the scientists can't agree amongst themselves. Henry F
Ds
Wow amazing conclusion a shot in a light box does not show the background on top of that focus breathing almost annihilates those differences anyway
No comment on the generic statement about shooting a bug in the field with a long lens and a close up filter literally pearls of wisdom from an acclaimed photographer?
Pedagydusz Veteran Member • Posts: 6,027
With these lenses and subject I don't think there is any reason for preference, in between the 45 and 60. In fact, I own both, and I always have difficulty in deciding between them, just for perspective reasons. I end up deciding based on convenient distance, or which one is fitted to the camera! (bad reason, I know!)
The 30 mm definitely is not my preferred FL for macro. I already had this opinion when I was shooting FT.
 Pedagydusz's gear list:Pedagydusz's gear list
Sony Cyber-shot DSC-F707 Canon EOS 7D Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GX8 +3 more
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
I have been looking at the 45 lens several times, specifically for my GM cameras. But did not buy it because I did read somewhere that for macro the lens OIS is not providing a benefit. Since you had two 45's, can you confirm if this is indeed true?
The crop factor does not apply to reproduction ratio. Because the reproduction ratio is directly defined as the ratio of the subject size on the sensor plane to the actual subject size.
The high pixel density of smaller sensors actually gives m43 an advantage over the larger formats in macro photography.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
cba_melbourne
Overall, I am surprised how close the 3 pictures are.
I like the 60mm picture best overall, very closely followed by the 45. The 60 is a tad sharper, contrast is the same. The 30 seems a bit weaker.
It is hard to tell though, how much the choice of stacking spacing affects the end result. Single shots would be easier to compare.
At 1:1 the 45mm and 60mm are practically identical further away there is difference
30mm is different and only good for still life it is a nice lens though for close up work, macro you are hitting the subject with no room for lighting
Bassam Guy Veteran Member • Posts: 4,885
60 60 60 60 60! Unrealistic sample photos
Your sample photos are not realistic. There is no rain falling on the statue.
Which of these?
  • Is the best focal length (considering scaring insects and avoiding bee stings)?
  • Is weather sealed?
  • Has IQ that may be met but not surpassed?
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +8 more
f/2.8 vs f/11 Comparison
One very interesting thing once you take focus stacking out of the mix is that performance of the lenses changes at f/2.8 going to f/11
At 2.8 the Olympus has perhaps a little edge over the 30mm not possible to see much over the 45mm the depth of field is minimal
30/2.8
45/2.8
60/2.8
At f/11 though the 30mm and the 45mm both seem to do better than the 60mm
30/11
45/11
60/11
All lenses seem to have quite a bit of vignetting wide open with the Panasonic worse. I am using lightroom so vignetting is not corrected
In terms of chroma differences the Olympus lens seems to produce less luminance in the blues which in turn make the image look warmer than Panasonic whose blue are brighter so overall the image looks cooler. Difference in color temperature is 150K if that so nothing major
All in all the 45mm and 60mm are really close also due to the stronger focus breathing of the 60mm with subjects in the centre. Not part of this test is performance at the edges
Re: 60 60 60 60 60! Unrealistic sample photos
Which of these?
  1. None really the 60mm has lots of focus breathing at 1:1 and 1:2 the performance is almost identical to the 45mm working distance is 2 cm aside. 30mm is not for that. So you will scare them. The best option but is not macro is 50-200mm with 1.4 or 2x TC
  2. Only the 60mm but again shooting during rain is not what I do, drops tend to show and I usually have some form of light with me too
  3. The 60mm only does better at the edges and up to f/5.6 however when you are at f/11 there is no gap in fact things start going the opposite way. I shoot a lot at f/11 to have depth of field, things tend to move making stacking not practical
Finally I use those lenses not just outdoors but indoors and underwater, I have a nice housing watertight to 100m I do not worry about weather sealing lol!
I have had the 60mm for 7 years the 45mm from less than one year and the 30mm for less than one month all have pro and cons and specific use cases but would agree the 30mm is more a still life close up lens is not something to go after bugs
instagram http://instagram.com/interceptor121
My flickr sets http://www.flickr.com/photos/interceptor121/
Youtube channel http://www.youtube.com/interceptor121
Underwater Photo and Video Blog http://interceptor121.com
Deer Photography workshops https://interceptor121.com/2021/09/26/2021-22-deer-photography-workshops-in-woburn/
Single shots are in another branch interesting to see how things change from 2.8 (used for stacking) to f/11
RSTP14 Veteran Member • Posts: 6,368
Re: f/2.8 vs f/11 Comparison
I think that you are splitting hairs with this comparison, so unless you can come up with a more challenging subject, all I see are differences in Focal Length and minor chroma characteristics, which matter not in PP. If it were me I'd be more focused on the differences at closest focusing distance and infinity, and homogeneity acrosss the frame, which you can't demonstrate in your comparison.
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
Interesting I see no differences in focal length except between the 30mm and the rest the 45mm and the 60mm look almost identical which is the manifestation of the 60mm focus breathing
If for homogeneity across the frame you mean how it performs at the edges I do not shoot anything in the shape of a rectangle neither am looking at reproducing photos so what it does in the corners though academically interesting is not actually that important. In fact a bit of vignetting and less sharp corners may help in real life situations
The comparison objective is in fact to show that the differences are almost none when you shoot a widget which is what you do in real life
Next step am planning to shoot a set of legos or a flower not bugs this is a light box for still life
