flower shots with off camera flash
Started Nov 14, 2021 | Photos
chiti106 Forum Member • Posts: 71
14
I've recently picked up a Godox trigger and flash.  I also have a few cut flowers/plants around the house to practice some off camera hand held flash shots. I hope you enjoy. Comments welcome
 chiti106's gear list:chiti106's gear list
Canon EOS 600D Canon EOS M6 II Canon EF 50mm F1.8 II Canon EF 85mm F1.8 USM Canon EF 70-300mm f/4-5.6L IS USM +5 more
Comment & critique:
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Re: flower shots with off camera flash
Hello...
Beautiful photographs - thank you for sharing.
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
Marco Nero
Marco Nero Veteran Member • Posts: 7,582
Very nice results!
Marco Nero.
 Marco Nero's gear list:Marco Nero's gear list
Canon EOS M6 Canon EOS Ra Canon EOS R6 Canon EF-M 32mm F1.4 Canon RF 85mm F1.2L USM +20 more
Larawanista
Larawanista Veteran Member • Posts: 4,736
Nicely done!
My own preference for flowers and plants is using a combination of natural sunlight and a bit of strobe. They look more natural that way. I'd place them near a window that allows direct sunlight then balance lighting by positioning the flash accordingly. But your images aren't bad at all, thanks for sharing.
"Photography is therapeutic."
https://www.pbase.com/joshcruzphotos
 Larawanista's gear list:Larawanista's gear list
Canon EOS M3 Canon EOS R Canon EOS RP Canon EOS R6 Canon EF 100-400mm f/4.5-5.6L IS USM +10 more
OP chiti106 Forum Member • Posts: 71
Thanks for your reply. Would you use the strobe as the fill light or key light if you mix it with sun light? I'm still learning and experimenting with flash photography. Tia
Larawanista
No easy answer to these questions. I'd start with:
  • Depending on the overall "theme" or your shoot, you may use sunlight for background lighting and your flash for both key and fill.
  • If the subject for example is a pot of flowers by the window using the morning Sun, I'd use the flash to produce shadows and maximize sunshine as my main light hitting the petals and leaves, especially if the sunlight comes from a spot that's higher than where the pot of flowers are.
  • I do this "balancing" a lot on food photography as well and in photographing flowers, of course). Let me share examples below of how I blend sunlight with artificial light sources (fixed LED on top, angled at around 45 degrees and two strobes bounced to light up grains in the bottle without producing glare).
Hope this helps.
A few samples from my online portfolio (the last one was by the porch, which is almost always perfect for mixing sunlight and artificial light):
https://500px.com/photo/311702305/Youre-Blooming-by-Josh-Cruz/
https://500px.com/photo/1031705110/Nourished-by-Rain-by-Josh-Cruz/
https://500px.com/photo/1036553261/A-New-Day-by-Josh-Cruz/
R2D2 Forum Pro • Posts: 26,529
Nicely done.  Keep the light as diffused as possible!
R2
J Peters Contributing Member • Posts: 759
Very good shots! Don't overlook that with off-camera flash, you can place the flash behind the subject pointing back into the lens (although usually indirectly). I got some very interesting shots of leaves lit from behind so you can see the internal structure.
