Interesting K3III v K1 II
Started Nov 11, 2021 | Discussions
ozdean
ozdean Forum Pro • Posts: 28,665
https://www.youtube.com/watch?v=Nhjwei_mMak&ab_channel=%E3%82%AB%E3%83%A1%E3%83%A9%E3%81%AE%E3%82%AD%E3%82%BF%E3%83%A0%E3%83%A9
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
Pentax K-1 II
TBLF Senior Member • Posts: 1,390
Re: Interesting K3III v K1 II
Yes, quite interesting... only complaint is I wish English sub's were available.
The AF on the K1 II did a lot better than I imagined in such a test based on the hype, but gotta hand it to the K3 III , it did appear certainly faster to acquire the moving subject and was more sticky, and stayed locked onto the subject better. My question is this... did they ever do a similar compare to the K1 Mk I ?
The one that kinda was weird for me and seemed counterintuitive was the ISO performance... it wasn't a linear difference at all. I guess it has something to do with the NR engine... because it looked like the K3 III was lagging in keeping the noise down early on, but then surpassed the K1 II once it got up into the ISO stratosphere of where we would probably never use it. It looked to me like the K3 III was retaining enough of the image of those balcony windows to still be recognizable when the K1 II had finally given up and it was just a smear.
Thanks for sharing Dean!.
EricV
 TBLF's gear list:TBLF's gear list
Sony a7R V Sony FE 200-600 F5.6-6.3 Sony FE 55mm F1.8 Tamron 24mm F2.8 Di III OSD 70-200mm F2.8 GM II +1 more
ozdean
OP ozdean Forum Pro • Posts: 28,665
I agree with your conclusions Eric.
bob5050 Senior Member • Posts: 2,948
My immediate question was whether they normalized the shots by using the k-1 in crop mode, or used different focal lengths. The tracking tests looked like different focal lengths. That aside---
I think at low ISO what you're seeing is the full-frame advantage (more, larger pixels, so inherently less noisy), and at higher ISO the advantage of the improved NR engine.
bob5050
All pictures I post here are SOOC, downsized 50% unless specifically identified otherwise.
 bob5050's gear list:bob5050's gear list
Fujifilm XP130 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Sigma 17-50mm F2.8 EX DC OS HSM +6 more
ozdean
I suspect they didn't normalize the shots Bob.
belnan Forum Member • Posts: 63
AF on the K-3 III is clearly better... no surprise. Overall the K-1 II seems like much better value to me. If the K-3 III included the gps and the very cool flippy screen it would be even better, maybe even worth the price.
 belnan's gear list:belnan's gear list
Pentax K-5 Pentax K-3 Sigma 50mm F1.4 EX DG HSM Pentax smc DA* 16-50mm F2.8 ED AL (IF) SDM Pentax smc DA 55-300mm F4.0-5.8 ED +3 more
ozdean
I like the extra dof from APSc.
