Deciding between K1-ii and Panasonic S5 - (please no MILC vs DSLR)
Started Nov 11, 2021 | Questions
AviPro
AviPro Senior Member • Posts: 1,254
Have narrowed it down to the K1-ii and S5.
Weight and kit lens are in S5 favor..
Wondering what I would gain from K1ii
Primary use in priority
  • Compact, travel needs, has to be FF
  • DR, mostly do landscapes
  • IBIS
  • Occasional portraits indoors
-- ## Thanks!
 AviPro's gear list:AviPro's gear list
Pentax K-5 II Nikon Z5 Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR +1 more
Panasonic Lumix DC-S5
flektogon
flektogon Veteran Member • Posts: 6,226
Re: Deciding between K1-ii and Panasonic S5 - (please no MILC vs DSLR)
5
  • IBIS
I would go for S5 + the 20-60 kit lens. Both for the price of the K1 body. S5 takes great video as well.
Peter
iso rivolta Senior Member • Posts: 1,023
12
  • IBIS
What will you gain from K-1 II? More single shot resolution, use of your K-mount lenses, even APS-C ones. Mechanical manual focus on lenses. Then GPS and all the Pentax features: horizon correction and composition adjustment, Astrotracer, the multi-direction tilt screen, external LEDs for night use etc. Maybe better ergonomics, maybe better weather sealing (depends on lenses too). And OVF. You also gain weight :))
What will you gain from S5? Lighter, more compact, flip screen, better video, larger AF area coverage, live composite, focus bracketing, 96 MP with 8-shot pixel shift (but softer than the Pentax 36 MP with 4-shot pixel shift) and access to the latest Sigma lenses. You may also gain eye strain :))
EDIT. One more thing: Panasonic Lumix's future in the photography business is not looking necessarily brighter than Pentax's, just because they are making mirrorless. They may actually decide to focus on video from now on.
Also, please consider that Pentax K-1, the original, has probably the most recoverable shadows from all FF cameras ever. This should be useful for landscape photography.
 iso rivolta's gear list:iso rivolta's gear list
Pentax K200D Pentax K-3 II Pentax KP +3 more
alex_virt Veteran Member • Posts: 3,044
Panasonic, but make sure you're OK with EVF.
MaciekPruski Regular Member • Posts: 288
  • IBIS
K1 ii is a good or even great camera for such needs but it is big and heavy. However, there are very nice prime lenses for it that are really compact, so the whole kit doesn't necessarily have to be very big. I wouldn't go with the kit lens though- you'd probably be better off buying 2 prime lenses for wide angle and standard focal length and a 70-200 f 2.8 or f 4 zoom
 MaciekPruski's gear list:MaciekPruski's gear list
Pentax K-1 Pentax KP Pentax smc FA 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc DA 17-70mm F4.0 AL (IF) SDM +6 more
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
The 2 good things about the S5 are the ability to take video & much better face/eye detection, particularly for portraits. Outside of that, the K-1II is cheaper in the long run with legacy glass & current lenses. The L-mount stuff is really pricey.
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax 11-18mm F2.8 Pentax DA* 16-50mm F2.8 ED PLM AW Pentax K-50 +10 more
AviPro
OP AviPro Senior Member • Posts: 1,254
Yes, EVF is fine ..
-- ## Thanks!
AviPro
I agree.. with K1, there is almost infinite options in terms of high quality optics lenses on ebay
Might have to settle for 2 cameras  - one for travel like compact apsc one
-- ## Thanks!
miles green
miles green Veteran Member • Posts: 7,827
Pick a candidate K1ii system (=with lenses) and a candidate S5 system.
See what it weighs, what use and abuse it can take,how much it costs and most importantly how it fits your needs.
K1ii and limiteds is pretty compact!
But if you want video.... it's a no-contest.
Miles Green
Pentaxian since 1997!
Corfu, Greece
N.B. All my images are protected by Copyright
 miles green's gear list:miles green's gear list
Pentax K-1 Pentax K-1 II Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited Pentax smc FA 77mm 1.8 Limited +7 more
bob5050 Senior Member • Posts: 2,948
  • IBIS
If those are indeed in order, then S5. No one ever accused the K-1 of being high on the 'compactness' scale, and that's the first thing you mention.
If your gear list is accurate, then you only have one FA lens (the 100mm macro), and that's not going to cover you for landscape. The Pentax advantage there would only be being able to use whatever new lenses you buy on your current K-5. But plan on a new set of lenses either way. Lenses complicate/muddle the size and weight question, of course. Think about the whole system.
Why is IBIS a thing for you? I'd normally think of it-has-to-be-FF landscape shooting as more a tripod activity.
bob5050
All pictures I post here are SOOC, downsized 50% unless specifically identified otherwise.
 bob5050's gear list:bob5050's gear list
Fujifilm XP130 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Sigma 17-50mm F2.8 EX DC OS HSM +6 more
John McMillin Contributing Member • Posts: 738
Jhaakas wrote:
Yes, EVF is fine ..
The S5's EVF might seem fine to you now, but wait till you see the next model... and the next... and the next. Each new generation of mirrorless cameras is seeing improvements here... which means that the one you buy today is an immature technology. I wouldn't want to run in that kind of hamster wheel of constant upgrades and planned obsolescence. My K-1's OVF is a mature, perfected product... until they put a better one with the K3lll's glass inside!
 John McMillin's gear list:John McMillin's gear list
Panasonic Lumix DMC-GX8 Pentax K-1 Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Sigma 12-24mm F4.5-5.6 EX DG Aspherical HSM +5 more
This! I was about to tell you how three Limited lenses on a K-1 gives you five focal lengths: 22mm (DA 15 in crop mode), 31, 47 (FA in crop mode), 77, 115 (FA in crop mode). With each of these lenses in use, the total weight in your hands is  never more than 1200 grams, or 2.5 lbs. That's not much to carry, for the capability you get. You'd have to go towards  Panasonic MFT to reduce that weight by as much as a pound, maintaining versatility and quality.
In short, the K-1 isn't such a big  camera until you mount a fast pro zoom onto it. Landscape photogs don't need that.
Meta-comment
12
You know, for a forum often accused of blind faith and brand-fanaticism, the OP sure seems to be getting a lot of balanced responses. Well done, everyone.
bob5050
AviPro
  • IBIS
Thanks bob, great feedback..
IBIS is needed for my indoor photography
Yes, I dont have many Pentax lenses that I would worry about and wont be selling my K5ii as it is not going to fetch a lot of money
The size of S5 with the 20-60 kit lens is 980 gm vs 1165 gm for my present K5ii+18-135
And I gain in the FF sensor so seems win-win
Of course I lose on tele end but for my landscapes, I gain significantly in the wide end .
-- ## Thanks!
Holger Bargen Veteran Member • Posts: 4,911
  • IBIS
The 50 mm and also the 35 mm lens should work very good on your K1. These lightweight plastic-fantastic lenses are good performers also on FF. Thus, you would have 35 mm - 50 mm and also 100 mm. I would call it a good set for a start.
If you want to do landscape photography, a wide angle maybe more important than a tele lens. You can crop very good from K1 sensor and for this reason a lot of tele photos will be "inside" the photos from your 100 mm lens.
 Holger Bargen's gear list:Holger Bargen's gear list
Pentax K-5 Pentax K-S1 Pentax K-1 Pentax smc DA 55-300mm F4.0-5.8 ED Sigma 70mm F2.8 EX DG Macro +7 more
Okay.
For cross purposing your existing DA's if you decide on the K-1ii, see https://www.pentaxforums.com/articles/gear-guides/full-frame-coverage-of-da-lenses.html?src=hs
I can't verify reliability (don't own a FF), but it seems fairly comprehensive.
Did you mention real estate photography in another thread? Yes, 20mm on a FF is going to be wider than 18 (or even 16) on an APS-C, but from what I've seen even that might not cut it for real estate sales work.
bob5050
AviPro
Thanks Bob for the nice feedback!
-- ## Thanks!
bob5050 wrote:
Okay.
I've done RE work with the K-1 for years, and I wouldn't dream of going to a job without at least a 15mm lens. Many of my scenes are shot tighter, especially in larger homes and spaces, but there's no substitute for a wide lens when you need to depict a small bathroom or kitchen, and you might find in older homes. You can only back up so far.
For that, Panny offers a 16-35 zoom. I could work with that. Also an economical 15mm MF lens from Laowa. So it looks like the L-mount has that box checked.
I was looking a that. The Lumix S Pro 16-35mm F4 is $1498, vs the Pentax D-FA 15-30mm F2.8 at $1296 (both Amazon prices).
bob5050
There's actually a wide range of ultrawides for the L-mount, even a rectilinear 9mm! That's too wide for real estate!
