Will Pentax make a KP II?
Started Nov 9, 2021 | Discussions
MaciekPruski Regular Member • Posts: 288
What camera will Pentax make next?
The options are:
1. K1 III- take the K3 III and put in a FF sensor, pretty obvious choice for Pentax
2. K70 successor- unlikely, not much money to be made there
3. KP II- more midrange than K3 III, no dual card slots etc. I think they might go for a more retro-inspired camera so that it doesn't compete with K 3 III too much. Personally I'd buy one. However, given their pace in development we can expect it somewhere around 2027
 MaciekPruski's gear list:MaciekPruski's gear list
Pentax K-1 Pentax KP Pentax smc FA 50mm F1.4 Tamron SP AF 70-200mm F/2.8 Di LD (IF) MACRO Pentax smc DA 17-70mm F4.0 AL (IF) SDM +6 more
Pentax K-1 Pentax K-1 II Pentax K-7 Pentax K-70 Pentax KP
The Squirrel Mafia
The Squirrel Mafia Senior Member • Posts: 1,017
Re: Will Pentax make a KP II?
Who knows. The only rumor I've read is that there will be 2 cameras for APS-C & 2 cameras for FF. The K-3 & K-1 series being flagships & my guess is a consumer camera similar to the KP on the other end of both. Whether or not that will be true has yet to be seen. I guess we'll eventually see what Ricoh has in store for Pentax.
 The Squirrel Mafia's gear list:The Squirrel Mafia's gear list
Pentax K-3 II Pentax smc DA 21mm F3.2 AL Limited Pentax 11-18mm F2.8 Pentax DA* 16-50mm F2.8 ED PLM AW Pentax K-50 +10 more
Seahbc Regular Member • Posts: 145
I believe there will be another lower spec'd APS-C camera. But what it will be named is anybody's guess. Ricoh/Pentax is pretty inconsistent in naming its equipment.
 Seahbc's gear list:Seahbc's gear list
Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA* 60-250mm F4.0 ED (IF) SDM Pentax smc D-FA 100mm F2.8 Macro WR Pentax 16-85mm F3.5-5.6 WR
ozdean
ozdean Forum Pro • Posts: 28,665
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +14 more
RBIV Senior Member • Posts: 1,295
The options are:
I would consider a FF Pentax if it was the size and weight of the K3iii.  I'd be ok with a "midrange" model.  Don't need two card slots, GPS, Astrotracer,  no video.  Just want a reasonably priced basic but robust FF DSLR  that would be used with the three Amigos and maybe the new 21.   Think Nikon D750 / D780,  but in Pentax flavor.
If I wanted a high tech FF,  it would be Leica for short lenses,  and /or maybe Nikon Zs for both.  I'd have to see how I got along with the latest generation of EVFs, but I'm told they are much improved, and mirrorless clearly offers some advantages.
If they are making any money at all on the K70 then let why not let it continue as their low end model.
I'd be happy if they just brought back the original KP.  Why they discontinued it without a replacement is a mystery to me.
 RBIV's gear list:RBIV's gear list
Pentax K-5 Pentax KP Nikon Z fc Pentax smc DA 21mm F3.2 AL Limited Pentax smc DA 40mm F2.8 Limited +3 more
Jon Donahue Senior Member • Posts: 1,158
Marketing — you would definitely want a low-end APS-C model like my K-70, at a new price point of about $800 USD. Or $1,100 with a kit 18-135 WR. I would name it K-6. And you would want a high end APS-C model, let's call it the K-4, at a new retail price of $1,800. The feature set and sensor on the K-4 would always be one generation ahead of the K-6. The K-4 would be useful to many professionals, with built-in WiFi radio flash control and the best auto focus tracking Pentax could devise. To get started, the K-4 would be a quickly warmed-over version of the existing K-3 III. Add that articulating screen and onboard flash!
On the FF side, it might be that you would only need a single model, the K-1 top of the line, loaded with every possible feature. Premium, no cost-cutting. Retro styling, and priced at $2,499 without apologies or discounts.
To make things simpler for the consumer, successive variants of each model would be named -A, -B etc... like K-1C, K-6B, etc.
Make sense?
 Jon Donahue's gear list:Jon Donahue's gear list
Ricoh GR II Ricoh GR IIIx Pentax K-5 IIs Pentax K-70
PentUp
PentUp Veteran Member • Posts: 4,188
Depends if they see a FF or an ASP-C body as the next most requested body?
The options are:
If FF is next, then K-1iii is the most likely upgrade with necessary enhancements from the K-3iii (other than the fps). However, they MAY go a little left field and pull out a FF sensor in a body size & weight of the K-3iii (say a K2) ? - but I think K-1iii is the more likely of those two scenarios.
If APS-C is next, I think that this is the most likely scenario as K70 is still in production and all that it would require would be fresh innards by cannibalising what they can from the K-3iii upgrades and possibly something from the KP, all without having to do much redesign to the body - probably a K-70ii.
Always a possibility, but I think the least likely. The KP was an experiment to see if Pentax's APS-C base would accept it as a replacement for the K-3ii. The answer was clearly: No. But if there is an appreciable market for "retro" then a more retro than the KP APS-C body "may" be in the wind.
But if you think of DSLRs as a niche and Pentax as a niche within the DSLR niche, and APSC as a niche within that niche, then KP-Retro is probably a niche within a niche, within a niche, within a niche... And that may be going a niche too far.
If they wanted a mid range APS-C somewhere in between the K70 (or K-70ii) and the K-3iii, then I suggest that a K-5iii would be the perfect candidate.
 PentUp's gear list:PentUp's gear list
Panasonic Lumix DMC-FZ300 Canon G7 X II Pentax K-x Pentax K-5 II Pentax K-50 +12 more
PentUp
They are unlikely to use K4 as a name. "4" is the unluckiest number (and shunned) by the Chinese speaking population of the world. Some hotels in HK and Singapore don't even have a floor numbered 4.
Make sense?
MrB1 Contributing Member • Posts: 605
Seems unlikely, as the reason for discontinuing it is probably because the KP is just too good, therefore it is too strong a competitor for the K-3iii for anyone not requiring the latter's high-speed features for their style of photography.
It would seem likely that most of the interest in Pentax DSLRs is from existing Pentaxians, and we are literally a dying species so the market is shrinking. Plus, with the K-3iii, Pentax have exacerbated that by excluding several features which many of us find useful (e.g. tilt screen and fill-flash) and also they have priced many of us out of their market.
So one might wonder - are Ricoh-Pentax actually interested in attracting new users to the experience of their pentaprism DSLRs? If so, perhaps what is needed is an upgraded K-70 at a price level similar to that of the current K-70. Maybe it could (or should?) even include some of the on-board computational technology found in mobile phones along with Web connectivity.
Philip
left eye Veteran Member • Posts: 3,037
K1-S
A slimmed down and lighter-weight K1 would have my attention. A sleek body (but not mirrorless!) which I could mount my increasing collection of neat vintage glass to!
I for one am certainly not here for AF speed. In fact a body which had easily swappable VF screens - made by Pentax, would be even better. Build on strengths that we had, but have lost - yet want back!
kypfer Contributing Member • Posts: 985
I doubt there'll be a KPii.
I'm of the opinion that the KP was a design exercise, a good effort at making an (almost) grip-less camera and a test-bed for upcoming technologies. I seem to remember reading "somewhere" that the KP was discontinued, in part at least, due to component shortages.
I'd bet on the next APS-C being a K-70ii, maybe K-70p, effectively a K-70 body, with a flash, articulated screen and all, with a KP "innards" for the improved a/f and low-light performance.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
KPM2 Senior Member • Posts: 2,076
Hello MaciekPruski
A KP II with a bigger buffer would be nice.
In principle, I do not know which way Pentax will go.
For the patern recognition (like a face or eye or anything else), Pentax use the RGB sensor, and for focusing the Phase AF module.
Now the more resolution this RGB sensor has, the more it can recognice, but the Phase AF module must still has an AF point over the object, where the RGB sensor did recognise the object. So, Pentax could use more and more AF points in the cameras, combined with a high resolution RGB sensor - Or start to let the RGB sensor AF in regions, where the Phase AF modul has no AF point over the object. Maybe in the future, this RGB sensors are little own 'mobile' sensors.
Sony tried an other way, it use a little translucent mirror for to project the scene not to an RGB sensor, it used the APS-C itself sensor for it. Sony did give up this idea, and went to mirrorless.
Who knows, how fare Pentax can go with the getting better and better RGB sensors in the future. And that is, what I would like to see in new cameras, even when I had to wait for them.
best regards. KPM2
Phil A Martin
Phil A Martin Veteran Member • Posts: 8,363
The options are:
Given the negative response many have towards the KP, which IMHO is completely unwarranted, I highly doubt that we'll have some variation on that camera, a KPii so to speak, although I wouldn't rule out an update of the K70.
ogl
ogl Senior Member • Posts: 2,004
I think K-80 could be real....As for KPII - I doubt. K-1III - yes, some day...based on K-3III software and hardware...
 ogl's gear list:ogl's gear list
Pentax K-5 IIs Pentax smc FA 31mm F1.8 AL Limited Pentax smc FA 43mm F1.9 Limited
Adam007 Contributing Member • Posts: 805
The K-1iii seems the obvious logical choice.  With all the FF MILC options these days, Pentax is likely losing users in this segment, despite having captured them only 5 years ago.
I see no reason for the next K-1 to be significantly lighter.  I mean, the K-3iii is more compactly built,  but scaled up to FF, it still isn't a A7IV.  I don't think Pentaxians care about that as much as everyone the MILC world does.
As far as as an "entry level" FF, I don't buy it.  It's still going to be 2 grand, easily.  I don't see the market for a stripped down version of the best Pentax can do.
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax K-3 Mark III Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited +7 more
Phil A Martin
The most important part of a camera is not the weight but the handling and ergonomics, and on that score the K1 is excellent. I'd rather that than some of the lighter and poorly designed MILC cameras. Besides you lose any advantage of low weight when you attach many of the huge lenses designed for these cameras. I think we know who I'm talking about.
henricoo Regular Member • Posts: 177
I do hope there will be a KP successor. I do hope there will be:
  1. A K1iii; full loaded flag ship FF with K3iii steroids
  2. The K3iii; it's already there as the flagship APS-C
  3. A KPii; a compact APS-C
  4. A new 645 with 100 MP
I own the KP besides the K1ii and it is a lovely compact solid performer. I use it as a Point & Shoot with the M20, M28 and XS40 and for tele work with the K135 2.5 and K200 4. At their sweet spot apertures these serve the 24 Mp sensor well.
 henricoo's gear list:henricoo's gear list
Sony Cyber-shot DSC-R1 Pentax K-01 Pentax KP Pentax K-1 II
bob5050 Senior Member • Posts: 2,948
The options are:
IMHO--
Re Thread title: if they do, they still won't call it that.
Opt 1 is still the most likely next thing.
I still rather believe asahi man's projection of 2 APSCs, 2FF
For the lower end APS-C, you have to remember the Japanese  market (the market they made all those wild colored KS~ models for). There is money to be made there.
bob5050
All pictures I post here are SOOC, downsized 50% unless specifically identified otherwise.
 bob5050's gear list:bob5050's gear list
Fujifilm XP130 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Sigma 17-50mm F2.8 EX DC OS HSM +6 more
xmeda
xmeda Senior Member • Posts: 1,899
No. That production line is occupied by K3III.
But they need to develop some K70 succesor. That camera is too old now and needs modern replacement. With current pricing strategy it will reach into KP price range anyway.
We can probably expect plastic sealed body, articulating screen, KP sensor, improved DNR processor, tuned KP autofocus, new UI, better video. And price in roughly $1200-1300 USD range.
 xmeda's gear list:xmeda's gear list
Casio QV-R40 Casio Exilim EX-Z110 Olympus XZ-1 Pentax X-5 Olympus XZ-2 iHS +42 more
I think a K-1miii is a given. The only thing that might stand in the way of it being the next out the gate is scaling the K-3miii innovations to FF. An updated lower-end APS-C might be much easier technically, because there you're only figuring out what/how to cut, not blazing new ground. So if they're working on both, then the APS-C team could finish faster.
On the other hand, whether the next entry APS-C should look more like a KP, or more like a K-70 (or K-5) could take a while to sort out, and has serious technical implications. It's not just a marketing decision. Two obvious issues: the sensor mount in the K-3miii is thicker--figure out how to shrink it more? Or give up the KP's compactness? And if you go with compactness, that probably means the lower capacity battery--no hope of standardizing up on the Li90 battery. So figuring out the design goals and working within those constraints might be as hard as producing a FF flagship.
Finally, I think the 645 has left the building.
bob5050
