OP
RLight
Re: Maybe, but not for the reasons you state.
picktherighttoolforthejob wrote:
...from earlier in this thread:
DIGICX I've heard is a dual DIGIC8, and thus twice the potential peak power draw. PowerShots use smaller batteries. That doesn't work so well obviously.
Rlight, your thread here really stands the test of time--talk of battery life, DIGIC8 vs DIGICX etc. is a worthy discussion.
I'm considering a small zoom and naturally tend to think of Canon first.
If Canon were to build and sell a successor to the 740 today...I wonder what it would look like, what its specs would be...and how well it would sell.
Great thread...why I read DPR!
Turns out they can throw a DIGICX into a body with an LP-E17 (R10), so it's possible they throw a DIGIC X together into a M6 II body. Slap the G1X III lens on it. It can be done. Will they? Maybe. $1299, starting price though... In this market? Tough.
I doubt we'll see DIGICX in a G7X form factor, though. Heat needs to go somewhere, needs power, too. I think what I'm describing is the most likely thing, if, it comes to pass.
The big players of macroeconomics are at play now, this may all be mute as inflation is tapping discretionary spending for most of late.
Thinking about this, it may be a M50 II / R10 sensor; they probably won't throw an IBIS sensor in that small a form factor, especially when they already have an IS lens in mind. The could do a different lens, but that's more cost to produce. That said, just having access to UHS-II SD, and DIGIC X AF, on a G1X III, with R10 4K, that's not a bad gig at all. However, it does compete with the R10 market segment to a degree. Canon-balism, is something Canon is keen to avoid right about now. We'll see. I don't see a path forward for the G7X III though, without a APS-C sensor from Canon that is (DPAF, 4K for those vloggers). This marries both the G7X and G1X segments into a single body... And provides a portable solution, which the R10, and even the R100 coming, isn't (RF-S lenses are too big, still; and M6 II + 15-45 is much larger than a G1X III; the RF flange is even deeper making the possible R100 + RF 18-45, larger than that). The R10 itself though, is so similar to this, not sure I see it happening. Similar price point, options, and only a bit smaller. Dunno folks.
