Re: R5, Error 70, EF to R Lens Adapter
Here's some information that you may find interesting, but won't necessarily help you.
I shoot Timelapse's professionally so I rack up a lot of images per session and when using the Canon EF to RF adapter I will get the ERROR 70 during almost every Timelapse I shoot - BUT this doesn't happen if I shoot with the aperture of the lens wide open. I have repeated this problem time and time again with a variety of lenses (Canon EF 50mm F/1.4, Sigma EF 20mm f/1.8, Rokinon EF 14mm F/2.8 AF, Sigma EF 150-600mm Contemporary lens) and with Canon batteries (LP-E6NH, LP-E6N) and a variety of media (SDXC from SanDisk and Transcend - and CF Express 2.0 Type B from Sony and Delkin).
It usually takes 170+ frames before the error 70 occurs and sometimes doesn't happen until a much higher frame count (240, 310, etc) - but if I let the camera keep shooting sequentially (Timelapse mode) it WILL happen every time.
There seems to be a communication issue between the camera, adapter and camera when it comes to the opening and closing of the aperture. Once the camera gives an error 70 it hasn't actually died. If I keep the camera on (remember, it's in Timelapse mode), it will continue to shoot but it takes 36 seconds for it to do so between shot once the error 70 happens. Despite Canon's claim that the ERR 70 is a read/write issue. All images written to the card even after the ERR 70 appears are all written to the card without issue.
So in this scenario, I have the camera set up to shoot an image every 2 seconds. Every thing is fine until it's not - but once the ERR 70 appears - the camera waits 36 seconds and continues to shoot another frame. The ERR 70 will now appear after each shot (since the camera wasn't restarted) and will continue to shoot every 36 seconds until I shut the camera off.
Initially I thought maybe as the battery drains it has less power to give to the adapter, but I don't believe this is the case because if I shut the camera off and turn it back on again - the camera will once again shoot a Timelapse without any issues until about 170-180 frames or higher.
The reason it dawned on me that this doesn't happen when shooting wide open is because I do a lot of astrolapses where I always shoot wide open - and never has the camera locked up. So I did many tests and sure enough if I shoot at the lens's maximum aperture (f/1.8, 2.8, etc) the camera will never give me the ERR 70.
Okay, so maybe a bad adapter. So I ordered a new Canon EF to RF adapter as well as ordered a native RF lens (I didn't own one until now). I first tested the camera with the native RF lens and the ERR 70 NEVER appeared regardless of aperture setting. Next I ran a series of tests using the new EF to RF adapter and Sure enough it exhibited the same problem as my original EF to RF adapter. Eventual ERR 70 when using a stopped down aperture setting and no ERR 70 when shooting wide open.
This also might explain the randomness of ERR70 for some photographers and not others. Many photographers that use burst mode are often shooting wildlife - are often shooting at the wide aperture setting in order to let in enough light. Plus you need to shoot enough images before it shows up.
I have noticed one thing that "may" indicate something isn't right and that's when turning on the EOS R5. If I have an EF lens and adapter connected to the camera when turning the camera on - it sometimes takes 3-4 seconds before the camera actually turns on. When this happens it's a guarantee that the ERR 70 will appear during my Timelapse. If the camera turns on immediately after moving the switch to ON - then I used to think the ERR 70 won't appear - but I'm not so sure about that now.
