Canon RF 24-105mm f/4L IS USM soft?
Started Nov 7, 2021 | Questions
Roman Dreyer
Roman Dreyer Junior Member • Posts: 43
Hi all,
I bought R5 and RF 24-105 f/4. All is great. The R5 is amazing.
Just one thing bothers me, when I shoot at 105mm f/4, there is some softness, even in the center.
My question here is to those who also own R5 and RF 24-105 f/4. Do you see such softness too?
Thank you.
105 f/4 full photo
100% crop 105mm f/4. notice the softness. Is it ok? do you have it too?
100% crop 105mm f/6.3 perfect sharpness
Please tell me if you have same effect/quality?
Thank you.
 Roman Dreyer's gear list:Roman Dreyer's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 70-200 F4 L Canon EF 50mm F1.4 USM Canon EF-S 24mm F2.8 STM +2 more
axlotl Senior Member • Posts: 2,273
Re: Canon RF 24-105mm f/4L IS USM soft?
Roman Dreyer wrote:
Hi all,
Thank you.
105 f/4 full photo
Thank you.
HI Roman. The framing is different and also probably the focus point. But it looks like a depth of field issue. I see your listed camera gear is small sensor compacts and crop sensor DSLR. Full frame gives shallower depth of field at any aperture.
Andrew
tkbslc Forum Pro • Posts: 17,522
I suspect this may have more to do with the fact that your test is near MFD. try again outdoors with a more distant target.
but no, the lens Is not as good at 105mm as it is at 50mm when used at f4. I would not call it soft, though.
bigshledge Contributing Member • Posts: 596
If you're at MFD or close to it, optical performance of most lenses tend to fall apart.
 bigshledge's gear list:bigshledge's gear list
Canon EOS R6 Canon EF 100mm f/2.8 Macro USM Canon EF 8-15mm f/4L Fisheye USM Canon EF 100-400mm F4.5-5.6L IS II Canon RF 28-70mm F2L USM +1 more
BobbyJam New Member • Posts: 3
I too have the R5 and 24-105 f4L
i have noticed that the lens is a little soft at 105mm than it is elsewhere in the range
nothing too much, but definitely noticeable
Roman Dreyer
OP Roman Dreyer Junior Member • Posts: 43
105mm but what appertures? focus distances?
Roman Dreyer
It is not relevant what other cameras I use.
Here is a 100% crop with FF R5 and EF-S 17-55mm. no "vapor" effects. The bokeh looks great.
I do agree there are few pixels of that soft "vapor" effect but here I really need to look for it. While on my RF 24-105 f/4 @ R5 the vapor effect very noticable
EF-S 17-55mm f/2.8 @ EOS R5
Roman Dreyer
I never saw such degradation in optics for minimum focus distance.
Here is a photo I took at 0.65m focus distance. This is not MFD.
The halo/vapor/softness effect is still noticable.
Roman Dreyer
Roman Dreyer
I searched for other samples of this lens and it looks like it is "OK" effect and that is how this lens renders images.
Here are some examples:
https://img.photographyblog.com/reviews/canon_rf_24_105mm_f4_l_is/sample_images/canon_rf_24_105mm_f4_l_is_05.jpg
https://www.flickr.com/photos/anvoto/51546422784/
https://www.flickr.com/photos/pgauti/51022441643/
This one can be closed.
Thanks all who tried to help.
0.65m is still pretty close to MFD. Again, optical quality of a lot of lenses degrade when you focus this close.
Christopher Frost specifically checks lenses at MFD for this reason:
https://youtu.be/dYaPpqmkZms?t=447
imagenes_vivas Regular Member • Posts: 132
I have the same lens (RF 24-105mm F4L IS) with the R5 and, at its minimum focusing distance, at 105mm and at maximum aperture f4, the quality is really soft. It's a problem of this lens only in these circumstances: 105mm, MFD and F4.
Otherwise is a perfect L high quality lens.
 imagenes_vivas's gear list:imagenes_vivas's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon EOS 5D Mark IV Canon EF 28mm f/1.8 USM Canon EF 500mm f/4.0L IS USM +7 more
Ronnysuyanto New Member • Posts: 17
I think this is normal for zoom lens. I have 28-70mm f2, it also not really sharp wide open @70mm at MFD. Zoom lenses are not optimized troughout focus range. Even some primes also soft and exhibit focus shift at near MFD. That's why good prime lenses usualy designed with floating elements to minimize MFD abberations.
unhappymeal Senior Member • Posts: 2,620
Ehhh, I don't think that's the case these days. Quite a few m4/3 are very sharp at MFD.
Dan W Senior Member • Posts: 1,154
Roman Dreyer wrote:
Hi all,
Thank you.
105 f/4 full photo
Thank you.
You shot these at 1/40? Was you tripod mounted? Where is the focus point?
At 1/40th of sec can allow shutter shock even on a tripod. Could be a DOF issue too, I'm looking at the background. Hard to tell but the background looks sharp?
I have that lens and my copy is very sharp. I scratch my head when I hear folks complain about the sharpness. When doing portraits I can count the eyelashes, that's all the sharpness I need.
 Dan W's gear list:Dan W's gear list
Canon EOS R5 Canon RF 50mm F1.2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4L IS USM Canon RF 70-200mm F2.8L IS USM +3 more
It pretty much is the case for most lenses - some are better at handling it than others, but most do suffer to varying degrees at MFD. If you watch any lens review, it's a pretty common thing that can be observed even in high-end lenses.
The likes macro lenses are usually the opposite, which are designed to be at their sharpest at MFD. Some are super sharp throughout, but these are the exception rather than the norm.
BlueRay2 Forum Pro • Posts: 14,816
Roman, your lens is just fine, i don't see anything wrong with it. go out and have fun with it--this is the best time of the year and take some beautiful shots with it, i wouldn't waste my time shooting toothpicks
Nature is under no obligation to make sense to us!!!
SonyX
SonyX Senior Member • Posts: 1,238
Thank you.
mine was like this
 SonyX's gear list:SonyX's gear list
Nikon D4 Sony a7R II Panasonic Lumix DC-G9 Sony a7 III Nikon AF-S Nikkor 24-70mm f/2.8G ED +10 more
Phylloxera Regular Member • Posts: 256
Seems to be focused on the front edge of the foremost petal of the foremost flower and the focus depth at f4 near MFD is tiny
 Phylloxera's gear list:Phylloxera's gear list
PTGui Pro
Yeah mine is a bit dreamy for f4 closeups at 105mm, too.  But I wouldn't use f4 for closeups on FF due to DOF, so I'm not too worried.
