Next Lens For G9 - Zooms
Started Nov 7, 2021 | Discussions
Mwh624 New Member • Posts: 21
Hi all,
I'm debating about the next lens for my G9. I currently run the Panny 12-35 f2.8 and the 45-150 f4-5.6.
Looking for a more do all lens when outdoors with the kids. I've narrowed it down to 3 options below. Looking back at my pictures with the 45-150, it seems I shoot a lot at 45mm (which tells me I could use something wider) to 90mm.
The lenses I'm considering are :
Panasonic 14-140mm II
Oly 12-100 f4
Panasonic 35-100 f2.8
The 14-140mm is definitely actractive for size, weight and cost. How's the image quality stack up with the other 2?
The 35-100 seems like a good fit next to my 12-35 and has f2.8 going for it. It does have the smallest focal range though.
12-100 is kind of sandwiched in the middle as far as focal length goes, is probably the best build quality but is the largest in size and weight. How's the Panasonic DFD focus work on the olympus glass?
Gotta love having options, but darn all these options. Any body gone through a similar decision? Any thoughts or ideas are welcome.
Nikon Df Panasonic Lumix DC-G9 Panasonic Lumix G 14mm F2.5 II ASPH
Trolleyman Senior Member • Posts: 1,048
Re: Next Lens For G9 - Zooms
12-100 focuses very quickly on the G9 and the lens stabilisation is impressive too.
 Trolleyman's gear list:Trolleyman's gear list
Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Olympus 12-45mm F4 Pro Olympus 12-100mm F4.0 Panasonic 8-18mm F2.8-4 +3 more
Marko_Finland
Marko_Finland Senior Member • Posts: 1,940
Mwh624 wrote:
Hi all,
Oly 12-100 f4
I used to have the 35-100mm that I coupled with the Oly 12-45mm mainly when traveling in Finland. It definitely is a nice lens but I ended getting a bit fed up with constantly changing lenses and got the 14-140mm instead. I really like the flexibility and also don't have complaints about the IQ. I mostly shoot outside so the relative slowness of the lens is not really an issue.
Marko
 Marko_Finland's gear list:Marko_Finland's gear list
OM-1 Panasonic Leica 100-400mm F4.0-6.3 ASPH Olympus M.Zuiko 300mm F4 IS Pro Panasonic 14-140mm F3.5-5.6 II Olympus 25mm F1.2 +2 more
Skeeterbytes Forum Pro • Posts: 23,186
Have only the 12-100 from your list. It's very impressive and after more than a year's use I have not run into any "gotchas" WRT weak parts of the zoom range--impressive for an 8X zoom--and it does not need stopping down to be sharp.
You will need to rely on OIS only and while AF-S will be indistinguishable from S-AF on an Oly body, I expect the two continuous AF systems (DfD/PDAF) will behave a little differently, so the subject and setting may expose differences (I sometimes use it for sports). Folks using it on the G9 seem happy with them.
Rick
kcdogger Veteran Member • Posts: 4,356
Mwh624 wrote:
Hi all,
Oly 12-100 f4
I order, I would rate the14-140 - a good all a rounder for descent light, lightest of the combos listed, IQ food but least of the ones listed, slowest lens here and not a constant aperture, but no lens changes out to 140mm, the 12-100 - works good on G, best IQ of the bunch and again a good all a rounder, heaviest of the bunch, and no lens changing out to 100mm (Best IQ of all the ones you mentioned and constant aperture.), the 12-35 and 35-100 combination - very good IQ, and constant aperture - faster by one stop over the 12-100 (could be better in low light), but constantly changing lenses could be a pita.
PS - I have them all. Mostly I use the 12-100, the 35-100 for concerts where I'm in the audience and not the photo pit - the P42.5 if in the pit (or, the 14-140 for travel, plus a fast prime.
Peace.
John
 kcdogger's gear list:kcdogger's gear list
Olympus TG-6 Panasonic ZS100 Olympus Stylus 1 Sony RX100 VII Panasonic Lumix DC-ZS80 +37 more
JosephScha Veteran Member • Posts: 7,249
Only you know what you really want, but I have the 14-140 and it is the lens that lives on my G9 unless I have a rather special need for a fast prime lens.  It is a surprisingly excellent lens for a 10x zoom.
js
 JosephScha's gear list:JosephScha's gear list
Panasonic Lumix DC-G9 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic 100-300mm F4-5.6 II Panasonic Lumix G 42.5mm F1.7 +7 more
(unknown member) Senior Member • Posts: 1,452
14-140 II is a great sharp lens. Awesome for travel.
tammons Veteran Member • Posts: 8,142
The Oly 12-100mm is one of the best lenses I have ever owned.
Pete Berry Veteran Member • Posts: 4,322
With your penchant for longer FL shooting, I'd go for the 14-140. I've had the 12-100 for everyday use several years on my G9, as well as the 12-35 and 35-100 which I use mainly for video. But on a recent European river trip I resurrected my old, heavy but excellent adapted 4/3 P-L 14-150 as my walk-around. The extra 50mm on the top definitely trumped the -2mm bottom! The very good Oly 4/3 9-18 was my only other lens, mainly for cathedral interiors.
14-150 extremes: from a Bucharest Steampunk bar to an artist with his hair-on-fire:
UrbanHobbit
UrbanHobbit Contributing Member • Posts: 998
I had the prior version of this lens (non-weather-sealed) and with it took some of my best shots of my kindergartner running around with friends. Quite sharp, good contrast. Its image stabilizer helped a lot with my GM5. Definitely best in outdoor/sunny/bright conditions; in case we went to more dimly-lit environs I usually brought along the Panasonic 20mm f/1.7. The whole kit fit inside a large jacket pocket, and a big part of success was having that setup with me almost everywhere we went. Easy to carry alongside all the kid gear.
For a while I also had the sibling variable aperture 12-32 and 35-100 set that I believe were designed for the GM5. Optically great, maybe a bit more character than the 14-140 I. But, both needed to be extended before shooting, and the combined hassle of that and switching lenses ultimately lost out to the convenience and longer range of the latter. I appreciated being able to fill the frame with my fast-moving subject at long distances, which (with the stabilization) was sometimes easier than shooting fast movements than at closer range.
 UrbanHobbit's gear list:UrbanHobbit's gear list
Olympus Stylus 1 Panasonic Lumix DMC-GM5 OM-1 Panasonic Lumix G 20mm F1.7 ASPH Olympus Zuiko Digital ED 50-200mm 1:2.8-3.5 SWD +15 more
steppenwolfer Senior Member • Posts: 1,153
I had 35-100 2.8 and 14-140. I sold both and was happy with 12-100 on G9.
If you are happy with size/weight, I would vote for 12-100.  I personally found that combo quiet large and prefer Leica 12-60 on Olympus E-M5 mk3.
 steppenwolfer's gear list:steppenwolfer's gear list
Sony RX100 V Nikon Z7 Nikon Z fc Nikon Z 14-30mm F4 Nikon Z 24-70mm F4 +8 more
Atho
Atho Senior Member • Posts: 1,207
Mwh624 wrote:
Hi all,
Oly 12-100 f4
I have owned (albeit briefly) all these lenses in the past year while I searched for my best walk around finally plumping for the 40150 f2.8 of which my main reservation is weight.
As an oly shooter I obviously prefer my lenses to go the same way but that said the Pany 35100 f2.8 is a good lightweight alternative that is not overly expensive either used or new however it has a poor macro performance, as well as closest focus distance, can’t focus stack with Olympus cameras and won’t take a teleconverter.
The 12-100 is a fine lens but I found it overly heavy and again it won’t take a tc.
I had the 14-140 at the same time as an oly 14150 and did not arrive at the conclusion that it had a better IQ than the oly and sold both before purchasing the 35100 f2.8
Here are two photos; the nut hatch is one of my favourite photos of the year and taken with the Pany 35100 while the Canadian Goose was taken with the oly 12100.
Albert Valentino Veteran Member • Posts: 9,770
If you don’t mind the size and weight, the 12-100 is best for both range and IQ. I sold my 12-40 and 40-150 Pro lenses after getting this over two years ago. This lens, along with my PL 8-18 are essentially all I use (sold my little Oly 9-18 after getting the 8-18)
Truth never fears scrutiny.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 Panasonic 8-18mm F2.8-4 +10 more
Old Timer63
Old Timer63 Veteran Member • Posts: 6,018
The Oly 12-100 pro is on my camera nearly all the time (G9) I love it and the images are great. 24-200 in 35mm terms is a superb handy range.
 Old Timer63's gear list:Old Timer63's gear list
Fujifilm X-H1 Fujifilm XF 14mm F2.8 R Panasonic Leica Summilux DG 25mm F1.4 Fujifilm X-T10 Panasonic Lumix DMC-G7 +20 more
OP Mwh624 New Member • Posts: 21
Thanks for all the input
spike29 Senior Member • Posts: 2,471
What did you choose?
I am in the same boat so let me tell you my road to new lens.
I am just purchage a secondhand 35-100mm 2.8 mkii.
Owning a good set this is a luxuary buy.
Pl15mm f1.7 (inside and low light) great little lens excelent sharpness and rendering.
Pl12-60mm f2.8-4.0 (my first choise lens) fantastic landscape lens and city's. Balances great on the g80, nice sharpnes and contrast rendering.
Lumix 14-140mm f3.5-5.6, first lens i bought stil very nice to have works also great with extendertubes. Walking around in good light great lens to have mounted and no need to swap often. Sharp enough. Closest in macro kind ratio, the magnification factor and closest AF distance of my set except maybe the 15mm but try to shoot a dragonfly with 15mm... 😁
Lumix 100-300mm mkii, my "bird lens" rather specialised but couldn't affort a pl50-200mm nor the 100-400mm and the 45-200mm was rubbisch. Not my lens.
The minimum 100mm causes a swap often , that often that a second body would be nice. Still very nice lens in dual is2, sharp enough.
I was missing a f2.8 at a longer reach then 14mm. Inside musea or buildings i think the 35-100mm does helpout to pair with the 15mm f1.7.
Sins it's covered on hole focallenght i need it to be better then the lenses i have. IQ wise, weatherwise outdoors, speed wise.
And every review is telling it's a greatlens small, sharp, fast. So i folded. 😣
I hope it's a great indoors sportslens. The 12-60 was not fast enough zoomed in.
I am telling myself this is the missing link... Worth buying evendoh i have the focal lenght covered in one other and still on bothsides mm left.
Fitting on a g80 the 14-140mm is the only lens which isn't rainproof.
This one is rain, freeze proof and internal zoom so no pumping. (pl12-60mm does extend so could draw moist.)
Am i stupid or sensable in my selection reasoning? 😬
Design is reasonalbe old, same age as the 45-200mm i think.
knowledge is addictive, every time i get some i want more.....
When i see a animal or insect i aim, shoot ...several times... take it home process it and hang it on the wall..... so he or she can live on freely where it belong wile i enjoy his presentation of live.
 spike29's gear list:spike29's gear list
Panasonic Lumix DMC-FZ200 Fujifilm FinePix F70EXR Panasonic G85 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Panasonic Leica 12-60mm F2.8-4.0 ASPH +2 more
Pete_W
Pete_W Senior Member • Posts: 2,838
Oly 12-100 f4
The two lenses I have used the most over the past 4-5 years were the Panasonic 12-60mm f/3.5-5.6 and the 45-150mm f/4-5.6.
This year I purchased both the Panasonic 12-35mm f/2.8 and the 35-100mm f/2.8 and they have become my primary shooting lenses.
From my experience, the thing you will get with the Panasonic 35-100mm f/2.8 is the ability for better subject separation, so if you are shooting the kids outdoors this would be a good choice.
If landscape is more your thing with lots of depth of field, then one of the other slower lenses may suit you better.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
A Jay New Member • Posts: 23
Having had both the 140-140 and 35-100 at one pint, I'm inclined to steer you toward the 35-100. It is a great compliment to your 12-35. Another option you might consider is the 12-60, either the Panny or the PL depending on your budget. My understanding is neither will be a let down from an image quality perspective. This is a very useful range in my experience, really limits lens switching if that's an objective.
The issue I have with the Olympus glass is you lose dual IS, and the focusing isn't quite as quick.
Cheers.
 A Jay's gear list:A Jay's gear list
Panasonic Lumix DC-G9 Panasonic Lumix G 25mm F1.7 ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4
DH007 Regular Member • Posts: 220
Prob way better than it has any right to be. I borrowed this lens from time to time from a friend and if I didn't already have the 12-60 PL it would be on my radar.
 DH007's gear list:DH007's gear list
Panasonic Lumix DMC-G7 Panasonic Lumix DC-G9 Panasonic Lumix DC-GX9 Panasonic GX850 Panasonic Leica DG Summilux 15mm F1.7 ASPH +10 more
Heinrik New Member • Posts: 21
that is not an easy choice to make. Here is my own experience with two of the lenses: I had the Pany 35-100mm f2.8 II for 3 or 4 years and was happy with the robustness of the lens body and the great quality of the pics but recently sold it as I rarely used it. The Leica 12-60 f2.8-4.0 sits on my G9 most of the time. To replace the 35-100 I just ordered the Pany 14-140mm f3.5-5.6 II on a Black Friday deal. I had the 1st version of that lens but gave it to my son when I purchased the G9 Leica 12-60mm combination. I was quite happy with the sharpness of the 14-140mm and really enjoyed the 10x zoom when I had it but it was not water sealed and I generally use it outdoors all the time. I do either landscape (mostly 12-60) or wildlife photography (Leica 200mm). Rarely used the 30-100 for wildlife photography or landscape. The 14-140mm II will be perfect for hiking trips when I want to save weight but may encounter wildlife.
Your choice should really depend on how you will be using the lens. I think for taking pictures of your kids, the 30-100mm f2.8 will be the better lens as it is faster and has better background separation at fully open aperture. You will get better quality outdoor pics of the kids to enjoy for years to come. Since it is faster than the other lenses you can also use it for sport or indoor photography when they get older. Our son has left the house so I rarely need the lens for that purpose. On recent hiking trips I had the 35-100 on my camera for its tele function and used my iPhone for wide angle shots. If you don‘t want to keep swapping lenses when outdoors with the kids you could do the same…
Enjoy your photography.
