Sigma 24MM F2.8 help
Started Nov 6, 2021 | Questions
jim yeats Contributing Member • Posts: 724
I just got a sigma 24mm f2.8 lens pentax k lens and it doesn't fit my k50 or kp, what am I doing wrong?
Pentax K-50 Pentax KP
flektogon
flektogon Veteran Member • Posts: 6,226
Re: Sigma 24MM F2.8 help
Make sure that the lens is really equipped with the Pentax K mount! If yes, then it HAS to fit!
Peter
OP jim yeats Contributing Member • Posts: 724
Just above the mount is stamped pentax k, red dots lined up and won't seat.
flektogon
Compare it (visually) with a genuine Pentax lens, which works on your camera. Look for damages/deformations, but it is really weird.
Peter
iTrax
iTrax Senior Member • Posts: 1,125
How old is the lens?
I have a number of Sigma 24 & 28 mm lenses and have no problem with using them on my Pentax cameras.
Perhaps take a picture of the lens and upload it.
 iTrax's gear list:iTrax's gear list
Pentax MX-1 Fujifilm X100V Pentax K10D Pentax Q Pentax K-01 +116 more
Ari Aikomus
Ari Aikomus Veteran Member • Posts: 9,643
pictures...
I have Sigma 24/2.8 for Pentax K (really nice little lens, BTW), and mine looks like this:
This is "A" version (manual focus)
If your lens is really Pentax K version, then its mount is damaged, check bayonet flanges...For example, it is possible that the lens has dropped and the flange is bent.
Ari
- Ari Aikomus -
'Why should I feel lonely ? is not our planet in the Milky way?'
 Ari Aikomus's gear list:Ari Aikomus's gear list
Sony a5100 Sony a7R II Pentax K-1 Panasonic GH5 Fujifilm X-A5
Re: pictures...
this doesn't look like my other pk lens mounts
AlainCo Regular Member • Posts: 382
Re: pictures...
This looks like an old Ricoh PK mount to me. Caution:  do not force mount it on your body! The lens pin is liable to get stuck, and you might be unable to unmount the lens.
AlainCo
Beauty is in the eye of the photographer
 AlainCo's gear list:AlainCo's gear list
Fujifilm X100F Pentax K10D Pentax K-5 Pentax smc DA* 50-135mm F2.8 ED (IF) SDM Pentax smc FA 43mm F1.9 Limited +2 more
iTrax
Re: pictures...
Yes , all my old Sigmas look very different.
The , both , pin ( link ) and protector are differently shaped , and the protector is located just next to the link.
I had similar problem on some old PK mount lenses.
I had to remove the protector , in my cases it was just too big , see attached photos on my old Vivitar.
Some people just trim the link and protector with some kind of timing tool , like Dremel.
Vivitar Series 1 70-210mm f/3.5 (Version 2) - made by Tokina
Re: pictures...
Thanks for the photos iTrax. I got it on ebay and if they won't try it back I'll do that.
Re: pictures...
Not surprising but the ebay seller won't take it back, I don't know why I still buy things from rbay.
Heritage Cameras
Heritage Cameras Senior Member • Posts: 2,301
Another option
I've seen this problem on quite a few independent PK lenses. In many cases the black ring at the rear which the diaphragm lever protector is attached to can be taken off entirely after removing the black screws.
Here's an example of such a lens that we sold some time ago with more explanation and pictures. This one had a second sleeve that came out as well, but this isn't always the case:
https://www.heritagecameras.co.uk/75-200mm-mc-zoom-lens-with-macro-for-pentax-k-m-pk-35mm-film-slrs-ka-easily-modified-for-af-digital-2835-p.asp
Ring removed from PK lens for compatibility with Pentax AF and digital SLRs
Dave, HCL
 Heritage Cameras's gear list:Heritage Cameras's gear list
Canon EOS 5D Sony a7 Canon EF 24-85mm f/3.5-4.5 USM Canon EF 100-300mm f/4.5-5.6 USM +2 more
