NX500: Anyone have a workaround for Capture One?
Started Nov 6, 2021 | Discussions
Nate8833
Nate8833 Contributing Member • Posts: 557
Hello!  So, I use Capture One for my photo editing software.  It does a great job with NX1 raw images, however it does not support NX500 raw sadly.  I believe there may be a workaround out there somewhere, does anyone use Capture One for their NX500 images?  I do have RawTherapee, which is nice but I definitely prefer the user experience with Capture One.  Thanks!
 Nate8833's gear list:Nate8833's gear list
Samsung NX500 Leica SL (Typ 601) Sigma sd Quattro Sigma fp L Samsung NX 30mm F2 Pancake +8 more
Samsung NX1 Samsung NX500
kypfer Contributing Member • Posts: 985
Re: NX500: Anyone have a workaround for Capture One?
No direct help, I'm afraid, but if your chosen software can import anything other than a RAW format, maybe you could use the Samsung RAW Converter to handle your files initially, then export to TIFF for further editing.
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Nate8833
OP Nate8833 Contributing Member • Posts: 557
Would you happen to know where you can download the RAW converter?  I'm following the steps to download iLauncher through the NX500 but the download fails.
Here you go https://www.samsung.com/uk/support/model/EV-NX1000BABTR/… genuine Samsung download
Make sure you get the correct version, there's separate Mac and Windows versions.
Nate8833
Thanks!  Sadly it looks as if the NX500 files are not supported by that version of the converter.  haha
Nate8833
I'm going to try Raw Therapee batch save to Tiff using the queue feature to see if I like the output to Capture One.
shutterbugnx
shutterbugnx Regular Member • Posts: 168
I suggest contacting Capture One.
Something else you could try is using exiftool on an NX500 raw to change the camera model to NX1.
 shutterbugnx's gear list:shutterbugnx's gear list
Panasonic Lumix DMC-ZS60 Olympus PEN E-PM1 Sony Alpha NEX-7 Samsung NX2000 Fujifilm X-M1 +46 more
shutterbugnx
https://web.archive.org/web/20201011003845/https://samsungnx.herokuapp.com/software
This version of the converter should work with NX500.
rapick
rapick Veteran Member • Posts: 5,475
Re: Workaround for Capture One? My way
C1 doesn't support my NX3000 RAW files either.
I first convert them to .DNG using the free Adobe DNG converter.
Then open the .DNG files in C1. No problem. (I can't say if any subtle nuances get lost).
Rapick
Visit my galleries at: http://rapick.jalbum.net/
'Nikon D700 / the legend' fb group member
 rapick's gear list:rapick's gear list
Samsung NX3000 Nikon Coolpix 995 Nikon D200 Nikon D700 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +6 more
Nate8833
Thanks for the replies so far!  The NX Converter works, but the program doesn't play too well with Windows 10.  The Adobe converter is the best so far, but it does something to the colors that I'm not thrilled about.  It will work though!
mauni Regular Member • Posts: 158
This is excactly what I'm doing with my NX500-RAW Files - not for C1 but for lightroom 5.7.1. It works perfectly.
