SD1M - What's In The Box...?
Started Nov 1, 2021 | Questions
atom14
OP atom14 Veteran Member • Posts: 3,301
Yoo-Hoo...!
Have you seen this:
atom14 wrote:
Since the output of the SAC-4 adapter is 9V, 3A, do you think that, for the purposes of maintaining a bit of power for a few moments of battery change over, I could use an adapted 9V battery (or a few in parallel)?
atom14.
So, what do you think - a 9V battery as a stop-gap?
atom14. < him again.
atom14
BUMP --- Last Question - True...!
Again: A 9V battery with proper plug direct into DC-In of SD1M?
atom14 wrote:
Have you seen this:
atom14.
atom14
OK, what about this...?
I'm sure it will have the right size plug out of the 7 it sports:
https://www.jaycar.com.au/9v-dc-3a-power-supply-7dc-plugs/p/MP3496
9V 3A DC - and cheaper than the Sigma one.
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
Re: OK, what about this...?
atom 14,
That should do it, just make sure to insert the connecter pins to the correct polarity.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
atom14
UPDATE - SUCCESS...!
Guys, the following pictures speak for themselves - if you read the captions aloud
Best of all, it was a cheap solution, and so appealed to a cheapskate* like myself.
* Cheapskate - one who fails utterly to see the value of being ripped off.
1. Powerpack with flat battery in camera...
2. Powerpack only...
3. Running on charged battery only...
Now I'm going to make up a 9V battery version for field use, but first...
- I'm off to find a banana peel to slip on
Thanks to all.
atom14.
Ceistinne
Re: UPDATE - SUCCESS...!
atom14,
Well done.
S
atom14
Ceistinne wrote:
atom14,
Well done.
S
Ta, S.
I'll contact the local Sigma distro, and if they still repair the SD1M I'll send it off (to Japan) again, this time with a plain message of expectation that their next repair last longer than a mere 18 months!!! I mean to say, just how many are there like that? This would have to be one of the most well-treated cameras out there, and yet...!!!
atom14.
