SD1M - What's In The Box...?
Started Nov 1, 2021 | Questions
atom14
atom14 Veteran Member • Posts: 3,301
Guys, it's been a while since I saw the box, and I'm trying to remember if there was supposed to be a cable to connect the camera to the power supply.
Ta.
atom14.
Sigma SD1 Merrill
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Re: SD1M - What's In The Box...?
Nope, sorry to disappoint. It's an accessory, SAC-4 - if I recall correctly.
Just interested in the technology.
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
atom14
OP atom14 Veteran Member • Posts: 3,301
Ta, Ted. That was fast.
I looked it up:
https://www.bhphotovideo.com/c/product/1023875-REG/sigma_eya024_sac_4_ac_adapter_for.html
and balked at the price - AUD or USD it's still ALOT.
I had some notion that "they included" some flat, battery-shaped gizmo that slid onto the battery charger and which had a cable that plugged the camera... - But that must have been for some other device.
Well, I'll see what the local Crake's have got.
If you're wondering why, it's to maintain power to the camera to retain date/time/other settings while swapping out the battery. Yes..., it loses all that again - alas! It'll be another trip to Japan in the new year - alack!
at m14.
PS: I found it fast, too:
https://crkphotoimaging.com.au/products/eya022
K...! HORRIBLE J KE...!
xpatUSA
I looked it up:
Yes, I had an SD14 that did that, quite irritating ...
Good grief, dude, I threw one in with an SD15 that I sold recently, duh!
Scottelly
Scottelly Forum Pro • Posts: 18,028
I looked it up:
How much should it cost? Have you seen the price of Sigma batteries for the SD1 Merrill?
at m14.
LOL
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
Ceistinne
Ceistinne Veteran Member • Posts: 3,256
I looked it up:
at m14.
atom14,
With the PG-21 battery pack attached I swap out one battery at a time with my old SD15 & that holds the time, date etc.  You could do the same with the PG-31 on the SD1M.
S
 Ceistinne's gear list:Ceistinne's gear list
Sigma SD1 Merrill Sigma dp2 Quattro Sigma SD9 Sigma SD10 Sigma SD14 +5 more
atom14
Ta, guys...
Scotty, I'd be ier if it cost in AUD the face value of the USD price, but I'm saying it's just a power-pack.
S. That is a good idea, especially for in the field. Sure it would add bulk to the system, but... For about-the house/town use I think the power supply would be handy as well. So, that says I should look to getting both.
Now at some stage I guess I'll have to send it off to Sigma Japan again. - The 2nd time in about 2 years. It's a cheap enough repair at about 110 AUD, but only 2 years???!!! - A let-down, TBS! And it was a 2 month turn-around then, so who knows now...
Idea: look into some cheaper power-supply option from the local electronics store. It's just the pin configuration I'm not sure of.
atom14.
xpatUSA
Re: Ta, guys...
Maybe someone here can measure their SAC-4 pin diameter and take a macro shot? And measure the voltage to find out the pin polarity but remember that the open circuit voltage could be considerably higher than the on-load voltage. It's unlikely that the SAC-4 has the best regulated voltage on the planet especially if the camera has a regulator inside.
I myself would be leery of taking any advice from the local electronics store. People like Tom Schum here can help much better, I reckon.
An alternative is to get another fully functional camera and keep this one as a back-up, as I have done with the SD9 so as to have two battery carriers ...
atom14
Could Somebody please do this...
As xpatUSA wrote, and which I highlighted below:
Both good points, Ted. The output voltage and current is listed on the specs of the product, but the pin dimensions are not. - And from looking at the camera, it's a veritable* pinhole in size.
Ta in advance to any obligers.
atom14.
* What is popularly meant when "virtual/ly" is wrongly substituted
adrianashoots Forum Member • Posts: 66
I paid 29 USD new from Sigma. If I would sell it for 70 USD I would feel not good.
 adrianashoots's gear list:adrianashoots's gear list
Sigma DP1 Sigma DP1s Sigma DP2s Sigma DP2 Merrill Sigma DP3 Merrill +7 more
Ceistinne
Re: Ta, guys...
atom14.
atom14,
I reckon any power supply with an Input of 100-240V, 50-60 Hz  and an output of 9V......3A would be ok.  The connector is a standard 3.5mm with a centre of 1mm.  The centre is Positive (+).
S
xpatUSA
Re: Ta, guys...
atom14.
atom14,
S
Great job, S, but a slight caveat.
At 9V, the in-camera regulator would get warmer than with the Sigma SAC, especially significant if the regulator is of the analog type and not pulse-width modulated.
Boring Ted-numbers for, say, 1A @ 5V after the regulator:
((9-5)*1)/((7.5-5)*1)=over double the heat dissipated=over double the temperature-rise ...
atom14
Re: Ta, guys: adrianashoots, S, and Ted.
S, it seemed to my eyes that the socket on the SD1M was much smaller than 3.5mm. I do not have my camera as I am away for a week, but I'll have a good look when I get back.
atom14.
Ceistinne
atom14.
It is exactly the same size as the one that was used on the SD9 / SD10. I measured the sizes and that is waht they are.
S
Ceistinne
Re: Ta, guys...
atom14.
atom14,
S
Ted,
The image here is the SAC-4  and  the specs I quoted is what's printed on it.
S
Scottelly
Re: Ta, guys...
atom14.
atom14,
S
Ted,
S
I think I'd just get the Sigma model. I think it's worth the extra money to be sure you don't fry your expensive camera with a cheap power adapter that you plug into a wall outlet, which can output a lot of power. I've seen cheap, junky electronics do really bad things. Sigma has pretty strict quality control. I wouldn't be surprised if they test the power output of all their power adapters, when they get a shipment from the factory in China. Will you do that? Will the cheaper power adapter you buy continue to output the right amount of power through the years?
Ceistinne
Re: Ta, guys...
Scottelly wrote:
atom14.
atom14,
S
Ted,
S
Scott,
I would test the output of such a device. I would get the "real thing" if avaiable at a reasonable price if I wanted one, which I do not. I did have ones for the SD 9  &  10 which I use occasionally to power them up up. Nostalgic use.
S
atom14
Ceistinne wrote:
atom14.
S
Ta for taking the extra trouble, S.
Ceistinne
atom14 wrote:
Ceistinne wrote:
atom14.
S
atom 14,
No problem.
S
atom14
Guys, I just had a thought...
Well, make that "the other day", but it was fleeting and it got lost in the subsequent information:
Since the output of the SAC-4 adapter is 9V, 3A, do you think that, for the purposes of maintaining a bit of power for a few moments of battery change over, I could use an adapted 9V battery (or a few in parallel)?
atom14.
