Olympus E-P5 started consistently overexposing photos in full sunlight... help?
Started Oct 30, 2021 | Discussions
starcrossing New Member • Posts: 6
Hi everyone!
I bought a used Olympus E-P5 a couple years ago and it's served me just fine until recently. I'm a baginner/casual photographer, and I mainly shoot in P (because I like to change the white balance).
A few months ago the camera started overexposing photos in full sunlight to a level I'd never seen before...see below
Specs for this photo:
f/9
1/400
ISO 200
No exposure bias (0)
Metering mode: digital esp metering
The photos become halfway decent when i set the exposure compensation somewhere around -7...
Compare the before and after photos below:
Specs for photo 1:
f/9
1/400
ISO 200
Specs for photo 2:
f/9
1/500
ISO 200
exposure -0.7
Shooting in iAuto doesn't make a difference. Weirder still, sometimes turning the camera on and off will solve the issue. Sometimes it doesn't. I already tried a full reset to no avail. It seems to be getting worse (?).
Did I accidentally mess up something? Is my camera broken? I'm quite fond of it and don't have the budget to buy a new one :/
Thank you in advance to anyone who can give some advice!
Simona
Olympus PEN E-P5
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
Re: Olympus E-P5 started consistently overexposing photos in full sunlight... help?
5
Try going into A [Aperture priority] mode, and shooting at your lens' widest aperture.
I suspect the internal "blades" inside the lens aren't closing down consistently - either going wrong mechanically, or maybe due to an electrical fault (perhaps a poor or broken connection re the ribbon cable inside the lens?)
Alternatively, do you have another lens, or a friend with one, with which you could try shooting "normally"?
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
Rich K
Rich K Senior Member • Posts: 1,006
Peter
Yes, I second that.  Try a different lens to at least eliminate that as the problem.
Rich in Reno
 Rich K's gear list:Rich K's gear list
Sony RX100 III Olympus PEN E-P5 Olympus E-M5 II Olympus M.Zuiko Digital ED 12mm 1:2 Panasonic 12-35mm F2.8 +5 more
Atho
Atho Senior Member • Posts: 1,207
Seems like an SD card failure to me.
Bob Carstens Senior Member • Posts: 1,005
Interesting, I’m finding my EM10ii appears to be overexposing lately. Hadn’t considered this as a solution.
Bob Carstens
 Bob Carstens's gear list:Bob Carstens's gear list
Olympus E-500 Olympus OM-D E-M10 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Olympus Zuiko Digital ED 40-150mm 1:4.0-5.6 Olympus Zuiko Digital 35mm 1:3.5 Macro +3 more
Rich K
How would you conclude that it's the SD card?  Not challenging, just curious as to the logic?
Rich in Reno
Atho
No logic involved just my experience and if I’m wrong it won’t have cost anything.
Henry Falkner
Henry Falkner Forum Pro • Posts: 15,901
I got an over-exposure problem with my SH-2 pocket zoom, with data retained similar to yours, when the mechanical shutter was failing, after one heavy summer shower too many.
The same SH-2 pocket zoom exposed stills correctly during video, when the electronic shutter was used.
Can you do exposures with mechanical and electronic shutter of the same scene?
Henry
Henry Falkner - E-M10 Mark II and Mark IV, SH-1, SH-50
http://www.pbase.com/hfalkner
 Henry Falkner's gear list:Henry Falkner's gear list
Olympus SP-570 UZ Olympus SH-50 Olympus Stylus SH-1 Olympus OM-D E-M10 II Olympus OM-D E-M10 IV +1 more
Pete Berry Veteran Member • Posts: 4,322
Peter
Yes, particularly since the repeat photo appears underexposed on my monitor, with the only difference being a minor (-0.25 EV) change, with SS from 1/400 to 1/500.
alcelc
alcelc Forum Pro • Posts: 19,006
Did you see the same lightness condition in Live View? If so, it should have told you the in-camera metering had been fooled by the scene (very often) and at that point, we should adjust the setting until the Live View looking good to us.
BTW, avoid to use slower than f/8 on M43 since diffraction might soften your image. I shall use f/9 etc only for specific requirement.
I would try with A mode, set the f/stop (usually wide open or a stop stopping down) to the sharpness of your lens (check reviews), and let the camera to set shutter speed and ISO for you. Use Exposure Compensation to adjust the lightness until it looks good to you. You can have far more control on the setting for a result you are happy with.
My 2 cents.
Albert
** Please forgive my typo error.
** Please feel free to download my image and edit it as you like **
Frank Jones Regular Member • Posts: 190
Peter
I had an intermittent but similar problem on my G95, but only with my 7-14mm lens. I tried cleaning the lens contacts but no luck.
In a previous post in this forum the consensus was also sticky aperture blades.
For the odd few times it happened, I removed the lens and tapped it on my knee! This made the problem go away for the short term.
Chas J Contributing Member • Posts: 956
What !.  Would you care to justify that statement ?.
Do Not Listen to What I Say ... Listen to What I Mean !.
 Chas J's gear list:Chas J's gear list
Nikon D700 Panasonic Lumix DMC-GH3 Olympus E-M1 Nikon D610 Nikon D810 +30 more
Atho
Not really.
Michael Meissner
Michael Meissner Forum Pro • Posts: 28,013
I had a similar issue with my E-m1 mark I when I shot with high telephoto lenses. What was happening was the shutter was sticking when you got to the faster speeds. So while the camera thought it was keeping the shutter open for 1/500 of a second, it actually was keeping it open for something like 1/125 second, which lets in a lot more light.
The reason I only saw it at high telephoto is that I shoot in P-mode, and when I shoot at 300mm focal length, the camera tries to raise the shutter speed to at least 1/600. I imagine if I was shooting in very bright light, I would have seen it with my wide angle lenses.
Fortunately, I had purchased the extended warranty and Olympus fixed it for free. Since the E-P5 was announced in 2013, I suspect if you send it in, that Olympus will say it is too old. There might be an independent repair shop that would fix it, but I suspect it would probably be cheaper to buy a newer camera on the used market.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus TG-5 Olympus E-M5 III OM-1 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +13 more
Michael Meissner
I believe the E-P5 came out before Olympus started offering electronic shutter (that Olympus calls silent mode).
Henry Falkner
Thanks for the clarification. I should have kept my trap shut on this one.
Henry
OP starcrossing New Member • Posts: 6
Thanks for the reply! I tried but it was not the SD card. I think it's the problem Isola Verde mentioned above ( the internal "blades" inside the lens aren't closing down consistently)
Atho
Fair enough.
Peter
I think it is indeed this issue. Removing the lens and tapping it didn't solve the issue, but shooting in aperture priority at the camera's widest aperture seems to have improved the photos.
Henry
Yes, unfortunately my camera doesn't have electronic shutter. It was a good idea, though!
