Your opinion: sell 35 or 85?
Started Oct 30, 2021 | Polls
R5D4
R5D4 Contributing Member • Posts: 968
So I need to cull the herd a little bit, and am kind of undecided. First, a little background:
I'm a wedding photographer, and before the switch to the R5 I used to haul 7 or 8 lenses around in a giant Pelican case that weighed 18lbs empty. Those days are long gone thankfully, as I have been enjoying just 5 lenses in a Think Tank Airport Navigator (the half sized one) and it has been so nice. Not only is 5 the number that fit well in the case along with other gear I need, but it has been so nice to just simplify some things and not always be juggling so many lenses. The other day I bought the RF 14-35 f/4 and am loving it so far. My lineup did not include a UWA before now, which I desperately needed. So here are the 6 I now have:
EF 35mm f/1.4L II
RF 50mm f/1.2L
EF 85mm f/14L IS
RF 14-35mm f/4L IS
RF 24-70mm f/2.8L IS
RF 70-200 f/2.8L IS
One of the EF lenses should go, both to cover my purchase of the 14-35 and to help facilitate my gradual move to 100% RF. The question is, 35 or 85?
I initially intended to sell the 35. That focal length is currently covered by 3 lenses, while the 85 is covered by 2. That is the most practical thinking I believe.
But I am thinking of selling the 85 instead. What are your thoughts? I think the idea of letting go of the 85 is easier than letting go of the 35 for me.
I welcome your opinions. I realize that lens choice is ultimately down to personal preference, uses and habits, which would be impossible to convey here to strangers. But I would welcome your thoughts and anything I haven't really thought of here.
 R5D4's gear list:R5D4's gear list
Canon EOS R5 Fujifilm X-T3 Canon EOS R6 Canon EF 35mm F1.4L II USM Fujifilm XF 35mm F2 R WR +9 more
POLL
Sell the EF 85mm f/1.4L IS
50.0% 12  votes
Sell the EF 35mm f/1.4L II
37.5% 9  votes
Neither...
12.5% 3  votes
  Show results
Canon EOS R5
(unknown member) Regular Member • Posts: 333
Re: Your opinion: sell 35 or 85?
Personally I would keep the 35 1.4Lii and get rid of the 85mm 1.4L.
The 35 is still quite special and holds up fairly well against modern RF lenses. The 85mm 1.4L was useful because of Its stabilisation… but image quality was always fairly average. You could replace it with the RF85mm F2 macro at a later date if you miss having a prime at that focal length. The RF 85 f2 I found to be sharper and more versatile than when I had the EF85 1.4L…
Good luck!
Larawanista
Larawanista Veteran Member • Posts: 4,736
Sell your 35mm to me 😁
"Photography is therapeutic."
https://www.pbase.com/joshcruzphotos
 Larawanista's gear list:Larawanista's gear list
Canon EOS M3 Canon EOS R Canon EOS RP Canon EOS R6 Canon EF 100-400mm f/4.5-5.6L IS USM +10 more
sobrien
sobrien Senior Member • Posts: 1,756
Why is it impossible to convey these things? Some people use a 35 and 85 exclusively and value the unique look of f/1.4 over the convenience of zoom. Sounds like that’s not you? Some people use zooms and take out the fast primes for certain shots where they know they’ll need or want f/1.4. I guess that might be you? If so then you’ll already know that f/2.8 is not a complete replacement for f/1.4 and your new f/4 UW is certainly not a replacement for your 35 f/1.4. Completely different lens in fact.
My thoughts are that a 14-35 f/4 UW has very little to do with either a fast 35 or 85 lens so your question doesn’t make that much sense. You already have 2.8 zooms and fast primes - do you still use and value the primes? If the answer to either is “yes” then that won’t change with the addition of a f/4 UW.
If it was me, however, and I absolutely had to lose one or the other, I’d sooner use the magnificent RF 70-200 f/2.8 for my telephoto needs and hang on to the 35 for narrow DOF environmental portraits and extreme low light.
"The simple things are also the most extraordinary things and only the wise can see them."
https://www.flickr.com/photos/135843555@N03/
 sobrien's gear list:sobrien's gear list
Canon EOS R Canon EOS R5 Canon EF 85mm F1.8 USM Canon EF 135mm F2L USM Canon Extender EF 2x III +16 more
thunder storm Forum Pro • Posts: 10,139
EF 35mm f/1.4L II
RF 50mm f/1.2L
EF 85mm f/14L IS
RF 14-35mm f/4L IS
RF 70-200 f/2.8L IS
I don't understand why you would need a wide angle zoom for weddings, but that's probably just me as I'm just an amateur.
In my opinion the 50mm f/1.2 (step a bit closer) and 70-200mm f/2.8 (for compression) together cover largely what the 85mm f/1.4 can do. The 50mm is also the better lens compared to the 85mm....
A 35mm f/1.4 is not the most sexy lens, but when the light is low it can be your most important lens as it covers the basic needs. Basic needs are more important sometimes than the most sexy lenses.
The wide angle zoom covers 24mm. This might allow you to sell the 35mm, 85mm and 24-70mm f/2.8 and get the RF 28-70mm f/2.0. Together with the wide angle zoom, the 50mm  and the 70-200mm that's just 4 lenses. Downside: the f/2.0 zoom is heavy.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
Hoka Hey
Hoka Hey Senior Member • Posts: 2,991
If you do any nightscapes, keep the 35. It has a special coating that brings out the colors of the night sky and the stars and nebulas. You can shoot beautiful panos with it. The only other lens that I'm aware of that has this coating is the RF 85 1.2 (and maybe some of the super expensive lenses, but I haven't checked personally).
Sell the 85 1.4 and get the RF 85 1.2 if you like that focal length. I think that it may exceed the EF 85 1.4 in various categories including focus speed and low light focusing although I have not tested either lens. It also has that special coating which makes it useful for deep sky astro work. (Marco did an excellent thread about this.).
Joe
higheronymous
higheronymous Regular Member • Posts: 271
EF 35mm f/1.4L II
RF 50mm f/1.2L
EF 85mm f/14L IS
RF 14-35mm f/4L IS
RF 70-200 f/2.8L IS
What if you just leave them at home and see which one you end up missing the most?
R2D2 Forum Pro • Posts: 26,531
^ This ^
Know thyself!
Knowing my own preferences, I’d lose the 35, as I’d have it covered by the 24-70 (at a wedding).
R2
BlueRay2 Forum Pro • Posts: 14,816
EF 35mm f/1.4L II
RF 50mm f/1.2L
EF 85mm f/14L IS
RF 14-35mm f/4L IS
RF 70-200 f/2.8L IS
i'd sell both and and keep the R 24-70 f2.8 IS. i have the EF mk2 version of this lens that has rendered my primes in that range, redundant. it does look like you have several lens that cover 24mm-85mm range. 24-70 is very critical because it covers very useful range for weddings or what have you.
good luck.
Nature is under no obligation to make sense to us!!!
Eddie Rizk Senior Member • Posts: 1,224
I like photographing low light events with a 35 and an 85.  I rarely, if ever, miss having anything else.  I need every stop of light gathering I can get, in those situations.  I also like the DOF control for portraits.  I would never give up either of those lenses, unless I was buying a superior RF version.
Most people are happy with an F2.8 or even and F4 zoom.  I'm weird.  I just like my zooms in the daylight or on a tripod.
That's my opinion, and it's worth what you paid for it.
Eddie Rizk
The race is not always to the swift nor the battle to the strong, but that's the way to bet.
Formerly "Ed Rizk"
My email was hacked and unrecoverable along with all associated accounts, so I got permission to create a new one.
 Eddie Rizk's gear list:Eddie Rizk's gear list
Canon EOS R Canon EOS RP Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +3 more
noncho
noncho Regular Member • Posts: 348
Sell both.
35 1.4 is a great lens, but big and in the most cases you won't see the difference with smaller, lighter, cheaper RF 35 1.8.
85 1.4 is a great lens, but you have RF50 1.2 and 70-200 2.8.
Personally I use RF35 1.8 and RF 85 + 85 1.2L II.
www.NonchoILiev.com
 noncho's gear list:noncho's gear list
Canon EOS-1D X Samsung NX1 Samsung NX500 Canon EF 85mm F1.2L II USM Samsung NX 30mm F2 Pancake +11 more
