X-pro 1 EVF VS X-E2 EVF
Started Oct 29, 2021 | Questions
EOS GUY
EOS GUY Senior Member • Posts: 5,342
Main camera is an X-T2.
Am buying the Meike 35mm F1.7 as a 2nd fun / walkabout lens (looks pretty good actually for an insanely low price)
And was thinking of a cheap 2nd body to pop it on
One of the major draws of the X-T2 was the large 100% 0.77 mag EVF
Which is the larger EVF - the X-pro 1 or X-E2?
I can get a decent used version of either for £200 so it will all hinge on the EVF7
I read the X-Pro 1 evf is a tiny 0.37 mag but I don't think it can be that small...?
cheers
My Instagram - https://www.instagram.com/photonicstreetdreams/
The earth laughs in flowers.
-Ralph Waldo Emmerson
Before you say (or post in our context) = THINK.
Is what you're going to say - True. Helpful. Important (or Inspiring.) Necessary. Kind.
I have G.A.S, - gear avoidance syndrome.
 EOS GUY's gear list:EOS GUY's gear list
Panasonic LX100 Canon EOS Rebel SL1 Fujifilm X-T2 Fujifilm XF 18-55mm F2.8-4 R LM OIS Canon EF-S 24mm F2.8 STM +6 more
Fujifilm X-E2 Fujifilm X-T2
Aoi Usagi Veteran Member • Posts: 3,223
Re: X-pro 1 EVF VS X-E2 EVF
cheers
X-Pro1 EVF mag is 0.60X compared to 0.64X for the X-E2.  Refresh rate is probably better on the X-E2 as well.  More importantly, focus peaking on the X-Pro1 is abysmal and only in white color.  I find it completely useless.
(unknown member) Forum Pro • Posts: 16,732
cheers
XE2 is a generation better in terms of functions and operational speed, AF, etc. Closer to XT2.
VF is slightly better but without optical finder of course. Still not great, but it does have dioptre correction. Pro1 does not and corrective lenses are hard to find.
Nice to have a compact option as well. It is considerably smaller that the Pro1, which can be handy when you want to be discreet.
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away." Antoine de Saint-Exupery
EOS GUY
OP EOS GUY Senior Member • Posts: 5,342
I don'y use peaking for manual focus I use digital split image and then just press the rear wheel to zoom in for critical check
Of course I could get an X-T1 for same price too and get large EVF but plan is one cam with 23mm F2 and other with Meike 35mm F1.4, so would prefer for one to be lighter...
EOS GUY
Speed not matter as for manual focus lens, but diopter is important and smaller size
Actually as speed not matter I can get same condition X-E1 for £125....  very tempting idea as would get camera and Meike 35mm F1.7 for same price as jus an X-E2
thanks.
Phil BH Senior Member • Posts: 1,043
thanks.
Diopters are easy to get for the XPro-1. Buy the diopters that fit the Nikon FM2. Plenty out there and available. B&H carries them.
Phil
Threaded Veteran Member • Posts: 4,180
If the EVF is important to you, as opposed to the OVF, then don’t buy the X-Pro1.  It has literally the worst EVF of any X series camera, being the lowest resolution, dimmest, slowest refreshing, and poorest colour accuracy or contrast (mostly because it’s an LCD panel rather than OLED).
The X-Pro1 has many nice qualities, but the EVF specifically is not one of them.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
uniball Veteran Member • Posts: 3,075
Had and shot both during the same few year period. E2 is a much nicer evf to live with.
You probably already know this, but the X-Pro1 does not have Digital Split Image.  It does have magnification.
I switched from a X-Pro1 to XT-1 for adapting and never looked back.  The X-Pro1 lives happily with a XF27 mounted to it all the time now.
thanks.
XE1 is very much a gen1 product as well. If you can swing for the XE2, I would recommend it. It got a mid-life upgrade to XE2S spec, and was like a new camera with greatly improved manual focusing aids and viewfinder info.
I'm still using mine as a backup to my Xpro2. 7 years and counting.
EOS GUY
I hear ya.  I might just keep the one body. I'm doing too much internet window shopping at the moment....  But yeah a T1 or E2 seems to perform better than the first pro
DarnGoodPhotos Forum Pro • Posts: 11,881
Both those EVFs are small, why not a used X-T1.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
EOS GUY
Yup that's my line of thought too. Same price and iq and lovely large evf
