Is the 14mm f/2.8 an overkill for the X-T200 or will it make the difference?
Started Oct 28, 2021 | Questions
Photography Raptor
Photography Raptor Regular Member • Posts: 236
I love the compactness and lightness of the X-T200 while still having a comfortable grip to hold the camera with my thumb and fingers compared to the X-E4 for instance that would need too add an extra grip for comfort.
Said that, I was wondering if the 14mm would give me sensible better IQ than the 15-45mm on the wide end in this bayer sensor. Has anybody paired this camera and lens?
 Photography Raptor's gear list:Photography Raptor's gear list
Fujifilm X-S10 Fujifilm 16-50mm F3.5-5.6 II Fujifilm 50-230mm II Fujifilm 50mm F2 R WR +1 more
FTOG Senior Member • Posts: 1,359
Re: Is the 14mm f/2.8 an overkill for the X-T200 or will it make the difference?
I have both 15-45 and 14/2.8, but haven't bothered to do a 'shootout' just yet.
The question is what you want to gain. The faster aperture will make the biggest difference, imho, in terms of what the 14/2.8 will enable you to shoot that the 15-45 might not. The physical aperture ring and manual focus with clutch mechanism change how you handle the lens, but make little difference to what you can shoot.
Is the 15-45 your only current lens? If so, I would consider if the faster aperture makes a meaningful difference to you. Because unless 14/15mm is a key FOV for you, you might want to look at expanding your focal range or aperture, rather than doubling up on the wide end. E.g. a tele zoom or f1.4 prime are also options to add to your capabilities.
With all that said, the 14/2.8 is a fantastic lens. If 14/15mm is a FOV you find yourself shooting frequently, it is a very capable and rewarding lens to use.
 FTOG's gear list:FTOG's gear list
Fujifilm X-E3 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR +2 more
JayPhizzt Senior Member • Posts: 2,374
No, it's definitely not going to be "overkill". If anything it'll be better than most of Fuji's other cameras since it has a bayer sensor instead of X-trans. Else what camera you put a lens on doesn't matter much.
When it comes to the lenses the 14/2.8 will be better than the 15-45mm, but you might not always notice a huge difference between them.
Photography Raptor
OP Photography Raptor Regular Member • Posts: 236
I like that focal lenght to do landscape. The 15-45mm at 15mm is very sharp but the corners are bad due to the lens distortion (on the other hand the lens is stabilized and has really close focus distance).
I think on the newest X-Trans 26MP sensor with almost one more stop of dynamic range than the 24MP bayer sensor in the X-T200 the upgrade is worth it given the photos I was able to see in flickr. The thing is that I haven't found photos of the 14mm combined with the bayer sensor.
My idea is to pair the 14mm with the 50-230mm forgetting about the intermediate focal lenghts for hiking as lightweight as possible.
The 14/2.8 certainly handles distortion extremely well, and if this is a FOV you gravitate towards, it's a lens that will make you very happy.
The lens won't behave differently on a different type of sensor. Any differences will be differences from sensor to sensor.
As for judging a lens by photos on flickr or elsewhere: Not knowing the degree of post applied to any photo online, I'd take what you see with a grain of salt always.
In the past, I've often carried 14mm, 23mm and 50mm. Recently I've acquired 15-45 and 50-230. I can certainly see potential in carrying the 14mm with the 50-230, but it is quite a substantial gap between 14mm and 50mm. I'd personally carry at a prime between those two focal lengths as well, or bring the 15-45 for focal length "emergencies". Luckily the latter is extremely light.
From my own quiver, a minimalist setup for landscape would be either the 15-45 and 50-230, or 14mm, 23mm and 50-230. I've recently experimented with a minimalist kit, and considering zooms where I am normally a prime shooter.
notchy
notchy Contributing Member • Posts: 713
The following review was originally published in 2015 and doesn't use a camera with a Bayer sensor, but you might find the discussion and field of view comparisons interesting:
https://www.fujivsfuji.com/wide-angle-primes-14mm-f2pt8-vs-16mm-f1pt4-vs-18mm-f2
As for distortion (as FTOG points out above), one of the stand-out features of the 14mm is its excellent performance with regard to this property:
https://www.opticallimits.com/fuji_x/807-fuji14f28?start=1
https://www.lenstip.com/387.6-Lens_review-Fujifilm_Fujinon_XF_14_mm_f_2.8_R_Distortion.html
https://www.imaging-resource.com/lenses/fujinon/xf-14mm-f2.8-r/review/
[Edited]
 notchy's gear list:notchy's gear list
Fujifilm X100V Fujifilm X-H1 Fujifilm X-T3 Fujifilm X-Pro3
Erik Baumgartner Senior Member • Posts: 6,893
The X-T200 may come up a bit short in the feature/user interface departments, but it’s capable of outstanding image quality - at least as good (or better) than any X-Trans Fuji. No lens is overkill for it.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
