Editing DNG exported from DXO in Capture One
vartik New Member • Posts: 11
I'm trying the trial version of the new DXO Photolab 5 for my Fuji RAW files and I have a problem.
My primary RAW editor is Capture One and I want to use the DXO for noise reduction only. If I export my Fuji RAF file from DXO as a DNG with only Deep PRIME and optical corrections applied and then import it to Capture One, I'm not able to apply Fuji color profiles. The choice under the Colors tab is there, but every color profile looks the same - very flat and underexposed. Am I doing something wrong? Is there a workaround for this, so I can apply the color profiles ?
BTW. the color profiles could be applied to these files in Adobe Lightroom without a problem. Only Capture One has the problem.
IanYorke Veteran Member • Posts: 4,772
Re: Editing DNG exported from DXO in Capture One
In the same way as LR produces a DNG for hdr or panos, the DNG from DXO is a linear DNG. DNG is a container format that can conta raw or demosaiced jpg or tif, data. A linear DNG is effectively a tif file without a white point assigned.
Now DXO supports Fuji can't you apply the profile in DXO?
C1 profiles are designed for Fuji raw files, not Tifs.
Ian
