Panasonic S5 image stabilisation half press setting question?
sootyvrs Contributing Member • Posts: 639
Looking at the options there is an option to have image stabilisation on all the time and during half press which is the setting I normally use.
Curious if image stabilisation set to half press whether image stabilisation is in operation whilst taking stills if you just press the shutter button fully without the half press?
Also if it works if set to timer?
 sootyvrs's gear list:sootyvrs's gear list
Canon G3 X Sony RX100 VI Sigma fp Panasonic Lumix DC-S5 Sigma fp L +10 more
SeanR1987 Regular Member • Posts: 101
Re: Panasonic S5 image stabilisation half press setting question?
Thats pretty much exactly how it works.
Always on = always visibly stabilizing regardless of what you're doing with the camera.
Half Press = only shows the stabilization effect when you have the shutter pressed halfway.
When set to self timer, you won't see the stabilization effect unless you're halfpressing the shutter if it's set in that mode. When the photo is taken, the stabilization is active.
 SeanR1987's gear list:SeanR1987's gear list
Panasonic FZ1000 Panasonic LX100 Panasonic Lumix DMC-FZ300 Panasonic ZS100 Panasonic Lumix DMC-GH4 +15 more
