LC Cartridge Problem Epsom 3880 Printer
camerashy Veteran Member • Posts: 3,505
Hope someone could help me please with an issue I have with my Epson 3880 printer and the Light Cyan cartridge
For some reason when I do a Nozzle Check it is not showing any printed  lines in the print out……all the other colours are fine.
I have done 2 Head Cleaning procedures but there is no improvement
any ideas would be greatly appreciated
thanks
pbase supporter at www.pbase.com/dav4184
for equipment see profile
 camerashy's gear list:camerashy's gear list
Nikon D800
Craftsman70 Contributing Member • Posts: 633
Re: LC Cartridge Problem Epsom 3880 Printer
Have you ever done any cleaning to your printer? And no, I don't mean the nozzle checks nor the head cleaning procedures. I mean actually wiping the various parts of the printer head and other parts with some cleaning fluid and a no-lint cloth.
If not, I recommend that you do so. Here's a thread on the subject - https://www.dpreview.com/forums/thread/4403888. You can use Windex as a cleaning fluid or make up your own using the formula contained in this thread - https://www.printerknowledge.com/threads/cleaning-solution-the-ultimate-test.5296/
 Craftsman70's gear list:Craftsman70's gear list
Nikon D200 Nikon D7000 Nikon D7200 Nikon D780 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +10 more
Vernon D Rainwater Forum Pro • Posts: 14,632
thanks
Have you printed any of the test prints that print a narrow strip for each color.  If you have, does the Light Cyan print with the normal density for that color.
If you have not, suggest you do this and report back.  These type test prints are available on the internet.  If you don't find, send me a PM with your email and I will email the correct one to you.
I have the 3880 (for many years) and have not had any type issues. I have not even had a clogged nozzle.
Vernon...
OP camerashy Veteran Member • Posts: 3,505
Thanks Guys appreciate your kind help never done any head cleaning or test prints so will look into it and report back
for the test prints on individual colours is that found in the printer software??
thanks again
Nikon D800
thanks again
As stated in my previous post: " These type test prints are available on the internet. "
Vernon...
