Safari Camera & Lens Advice & Beyond
Started Oct 26, 2021 | Questions
cculp New Member • Posts: 2
I am going on safari to Rwanda and Kenya and to see the gorillas.  I currently own a Canon 6D and looking at the Canon R6 for my new camera.  Any advice on lenses?  Beyond the safari I would like to lighten my load that I carry.  Any thoughts on the new 100-400 rf lens and the 600 or 800 rf f11 lens?  I will take my 6D body as a backup with my 28-70 L 2.8 lens.  Would I be better off buying a used 100 -300L lens with image stabilization with my 1.4 ii teleconverter than the new rf lens?  Do the adapters work well with the EF lenses?
 cculp's gear list:cculp's gear list
Canon EOS 6D Canon EF 16-35mm F2.8L II USM Canon EF 70-200mm F4L USM Canon Extender EF 1.4x II Canon EF 24-70mm F2.8L II USM
Canon EOS R6 Canon RF 100-400mm F5.6-8 IS USM Canon RF 600mm F11 IS STM
Myrgjorf Regular Member • Posts: 464
Re: Safari Camera & Lens Advice & Beyond
You need a sealed lens to avoid dust into the lens and camera. E.g. the RF 100-500.
 Myrgjorf's gear list:Myrgjorf's gear list
Sony RX100 Olympus TG-5 Canon EOS-1D X Mark II Canon EOS M50 Canon EOS R5 +20 more
WildImages
WildImages Contributing Member • Posts: 741
It is my understanding that the 100-300L will not take telextenders.
Don't spend the money for a safari, then poor boy it on equipment.  Go for the R6, the RF100-500 and RF 800 and use your 6D for your short stuff.  Of course this is two different systems with no backup primary camera which is not wise.
 WildImages's gear list:WildImages's gear list
Sony RX10 IV Nikon 1 AW1 Sony a9 Canon EOS R5 GoPro Hero8 Black +11 more
William Woodruff Contributing Member • Posts: 970
R5.  100-500.  Done.
WLW
 William Woodruff's gear list:William Woodruff's gear list
Canon EOS M Canon EOS R Canon EOS R5
Occams Razor Senior Member • Posts: 1,252
Although I do not have one scheduled yet, on my next safari I will most likely go with RF 100-500 plus TC.  On my last safari, I took a Tamron 150-600 and found 600 was too short at times.  I also recommend a second body with a shorter FL.
Randy
 Occams Razor's gear list:Occams Razor's gear list
Canon EOS Rebel SL2 Canon EOS R5 Canon EF 100mm F2.8L Macro IS USM Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM +4 more
BirdShooter7 Veteran Member • Posts: 9,127
When I’ve visited Africa my main objective has been photographing birds so by far my most used lens was my 500mm f/4 and TC’s. I don’t think my trips are typical though. I’d imagine your best bet would probably be an R5 or R6 with the RF 100-500L. I’d definitely have two bodies with me. I know it’s not likely but I’ve been on trips where cameras have failed and having a backup is really important, especially because there’s rarely a camera store in the area, much less one with a camera that you probably would want. Since you have the 6d I’d guess that’s your backup camera so it might be a smart move to have a lens that can work on both of your cameras. Maybe something like the EF100-400 mk2 and 1.4x iii would be a good bet.
I don’t know how useful the 600 or 800 f11’s would be but the 24-70 or maybe 70-200 would be a good second lens to have, especially for the gorillas.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
evertdoorn Regular Member • Posts: 159
5
If you have the possiblity to rent; do that. You'll know if you like it and you can always buy it later.
So, from someone with a fair bit of experience shooting wildlife (insta: thewildsite) and having been to Rwanda eons back to see the gorilla's, here's what I think:
For a general safari lens, the 100-500 is great.
For gorilla's, you probably don't need the reach (it's on a densely overgrown vulcano and trust me - there might be a rule that you keep 7m distance from the gorilla's, but they might not listen to that; I had a silverback basically drooling in my neck..).
So you'll get close enough probably with something like a 70-200. The 2.8 aperture would work well here considering the fact there could be less light (often foggy weather, dense vegetation, etc. - plus in particular the younger gorilla's move a lot, so you might need the shutter speed). But considering the low light capabilities of the R6, and depending on the light, the 100-500 could do well here.
That wider lens will be useful as well, you'll want to show the surroundings of Virunga too.
Sports Shooter
Sports Shooter Senior Member • Posts: 1,648
Based on your current gear list I would buy the R6 + EF 100-400 + RF-EF adaptor... and a spare battery.
“There are always two people in every picture: the photographer and the viewer,”—Ansel Adams
 Sports Shooter's gear list:Sports Shooter's gear list
Canon EOS-1D Mark IV Canon EOS-1D X Mark II Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF 70-200mm F2.8L IS II USM +14 more
Doylestown New Member • Posts: 7
I spent 3 weeks in Sept. 2019 in Tanzania, Kenya, & Uganda primarily using a 5DS with EF 100-400 f/4.5-5.6. Never had the need to attach my 1.4 TC, especially on two gorilla treks in Uganda. Available light was fine. Actually got close enough to the gorillas that I used my EF 24-70 f/2.8 for some of my shots. Probably could have used my EF 70-200 f/2.8 but left it back at the camp. Going back in March 2022 and now have a R5. Expect to use my RF 100-500 without a TC for most of the time. Eye detection, IBIS, and lens IS will be a big step up.
tdbmd Senior Member • Posts: 1,546
I have done a photo safari in Etosha National Park in Namibia.  Probably a bit more open then the jungle areas for gorillas.  I had a crop body, Canon 7D with a 17-55 f2.8 and EF 100-400LII.  The 28-70 should be a good general use lens but on a full frame, you may wish for more reach than the 100-400.  In good light, the RF 600 or RF 800 will probably work but if it is dark forest, maybe not?
 tdbmd's gear list:tdbmd's gear list
Canon EOS 7D Mark II Canon EOS Rebel T8i (EOS 850D) Canon EOS R6 Canon EF 85mm F1.8 USM Canon EF-S 17-55mm f/2.8 IS USM +11 more
OP cculp New Member • Posts: 2
Thanks so much for all of the advice.  Always good to hear others opinions especially those that have been where I am going!
enjoy your trip! I'm off to Kenya this weekend, after a long break
User4286416121 Senior Member • Posts: 1,221
To repeat, rf lenses wil not fit 6d ef camera.  So backup...
mermaidkiller Senior Member • Posts: 1,450
Or get a (used) EF 100-400Lii with 2xTC III. I have both, works flawlessly, you get 200-800mm equivalent @ F11 and AF works very good. On the 6D the AF works only in live view mode.
The RF 100-500L is more expensive, and with RF 2xTC it is limited in the 300-500 range (600-1000 mmeq).
And if you want to travel light, get the RF 100-400 F8 and possibly the 800 F11. Together they cost less than the RF100-500 or EF100-400L each.
Ricoh KR-5 ... Pentax ME Super ... Canon T90 ... ... ... 40d ... 7d ... 6d ... r6
 mermaidkiller's gear list:mermaidkiller's gear list
Sony RX100 VI Canon EOS R6 GoPro Hero7 Black Canon EF 85mm F1.8 USM Canon EF 50mm f/2.5 Macro +5 more
Andy01 Veteran Member • Posts: 5,188
I lived in South Africa for 30 years and did plenty of safaris there, but none in Rwanda.
In general, open plains / light bush wildlife is often most active in early mornings and late afternoons - when light is not as good. So be cautious about taking very slow lenses. I don't think I have ever been on a safari where I was not wishing for either faster lenses or better high ISO performance.
My last trip back to South Africa was 5 years ago and I took a 70D and EF 100-400L. I generally limit the Canon APS-C cameras to ISO 1600, and there was SEVERAL times where ISO 1600 and f5.6 at 400mm (640mm FF equivalent FoV) was just not adequate.
Both your 6D and R6 are better at higher ISO than a 70D, but they lose the "reach" of the crop camera and if you whack a f11 lens on the front of the R6, you might be testing the high ISO ability to the max. The same may apply to the RF 100-400mm + TC.
I would think (but have no first hand experience) that your R6 + adapted EF 24-70 f2.8 might be the best option in dense jungle for gorillas - faster lens + better AF and eye AF.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
A 6d or 70d and an R6 makes a lot of difference which is more than I expected before I got the R6.
The first category does not AF at all with the OVF (which is rather dark as well), while the R series (regardless whether RF or EF lenses) do AF at F11, even in twilight. The higher sensitivity of the R6, even compared to 6D, allows ISO up to 12k5 and the (IB)IS allows razor sharp handheld shots as slow as 1/20 sec at 800mm equivalent F11. Admitted, not suitable for running impalas, but suitable for other game sitting or sleeping in the bush.
Moreover the 'more reach' of the 70d is nothing different than a cropped image. With the R6 you can also play that trick, enable APS-C mode, but you have than only 8MP left, far less than a 70d, but I consider that as adequate.
We are all too spoiled with the megapixel race.
Cristi CC Regular Member • Posts: 133
R5+100500RF & 1,4TC.
 Cristi CC's gear list:Cristi CC's gear list
Canon EOS R5 Canon RF 24-105mm F4L IS USM Canon RF 15-35mm F2.8L IS USM Canon RF 70-200mm F2.8L IS USM Canon RF 85mm F1.2L USM +2 more
aftab
aftab Forum Pro • Posts: 10,450
In Kenya, 100-400 focal range will cover at least 80% of wildlife. This should work well for the gorillas too. You will need a bit wider and a bit longer range for the rest. Yes, EF lenses work very well on R bodies with an adapter.
 aftab's gear list:aftab's gear list
Canon G1 X II Panasonic FZ1000 Canon EOS 5D Canon EOS 5D Mark III Nikon D600 +25 more
But then you have a dust problem as they are not sealed. Safaries are dusty.
actually, they might not be dusty at all
Really depends on the specific area you're visiting and time of year
