Sony a6500 can the shutter speed be set higher than 160 with the flash on?
yt1300 New Member • Posts: 4
Hi, for the Sony a6500, when the flash is open, the shutter speed can't go any higher than 160. Is there anyway to get around that limit and set it higher? I know that at a higher speed the flash will not sync with the shutter, but that doesn't matter for my purposes.
In short, I'm using an underwater housing (Sea Frogs) that uses fiber optic cables to trigger the external strobe, but I want the option of shooting with the flash or shooting without it (at a higher shutter speed). Because the camera is inside the underwater housing, once the flash is open it cannot be closed mid-dive. I can pull out the fiber optic cable to prevent it from triggering the strobe, but that still leaves me with a top shutter speed of 160 (which is rather slow). If anyone knows a way to get around this, I'd really appreciate it. Thanks
Sony a6500
theworstphotographerontheinternet Contributing Member • Posts: 580
Re: Sony a6500 can the shutter speed be set higher than 160 with the flash on?
To the best of my knowledge, the only way around this sync-speed limit is to buy a speedlight which is capable of HSS, and mount it to the hotshoe. Not sure how well this would work with your underwater camera housing though, given the increase in size.
