Canon EOS RP Battery Life in Sleep
Started Oct 23, 2021 | Questions
Spaceflight Photographer
Spaceflight Photographer Forum Member • Posts: 56
Hi -
I am considering making the switch from the Canon 6D to the Canon RP, but had concerns regarding battery life. With my 6D, I will sometimes leave the camera in situations connected to an external shutter trigger. It consumes next to no power when in sleep mode.
Does the RP do something similar? If I left the power on overnight, without shooting, on sleep mode, will I still have a fully charged battery the next day?
Thank you
 Spaceflight Photographer's gear list:Spaceflight Photographer's gear list
Canon EOS 40D Canon EOS 350D Canon EOS 450D Nikon D3200 Canon EOS 6D +5 more
Canon EOS 6D Canon EOS RP
Larawanista
Larawanista Veteran Member • Posts: 4,736
Re: Canon EOS RP Battery Life in Sleep
Yes. However, the battery on the 6D lasts longer than that of the RP's. I'd recommend at least one spare battery. Advantage is I can charge the RP battery in the camera using the USB Type C port, pretty much like how you're charging a mobile phone, provided you're using a PD charger / powerbank. Couldn't do that with the 6D (so I always had to travel with the dedicated charger in the past).
"Photography is therapeutic."
https://www.pbase.com/joshcruzphotos
 Larawanista's gear list:Larawanista's gear list
Canon EOS M3 Canon EOS R Canon EOS RP Canon EOS R6 Canon EF 100-400mm f/4.5-5.6L IS USM +10 more
SteveinLouisville
SteveinLouisville Senior Member • Posts: 1,586
Use Eco mode and set timers to their lowest setting.  My RP battery life has improved since I have done this.  Oh, and have a couple of spare batteries with you at all times.  Every time you shoot 50+ shots and get home, recharge the battery.
 SteveinLouisville's gear list:SteveinLouisville's gear list
Canon EOS RP Canon EOS R7 Canon EF 17-40mm f/4.0L USM Canon EF 40mm f/2.8 STM Canon EF-S 24mm F2.8 STM +9 more
