Airshows: video recording tips please
pawn Veteran Member • Posts: 3,079
Hi
For those who have made video recordings at airshows, can you please share your experience wrt the heads (ball head, gimbal head, fluid head, etc.) that were used when video recording the shows?  Is using a fluid head a must?
Duy
Off The Mark Veteran Member • Posts: 5,612
Re: Airshows: video recording tips please
pawn wrote:
Hi
Duy
A GOOD fluid head mounted on a steady tripod is going to be EXTREMELY HELPFUL at the least.
I've tried using ball heads in the past for some action shots and it was a complete and total disaster. (Of course, could be operator error.) Panning and tilting "worked" technically speaking (although very jerky), but I couldn't keep the roll axis steady at all with my heavy camera and lens. I gave up after about 12 minutes. None of the footage was even remotely usable. And it was mentally exhausting trying to balance it.
Depending on the internal stabilization of your camera, maybe a solid shoulder rig might work???
I don't have any idea if a properly balanced gimbal head would work (we are talking about a purely mechanical gimbal head that a wildlife photographer might use, right? Not electronic gimbals like DJI Ronin or Zhiyun Crane, right?) I could only imagine that even with a properly balanced mechanical gimbal head the footage still wouldn't be smooth when panning or tilting.
P.S. You have some great shots on your smugmug site. I encourage anyone seeing this to visit your site and check out your photos.
What Middle School Is Really Like:
https://youtu.be/Q1Xtz5EqMuo
 Off The Mark's gear list:Off The Mark's gear list
Sony a6000 Sony a5100 Sony a6300 Olympus E-M1 II Sony a6500 +16 more
OP pawn Veteran Member • Posts: 3,079
Off The Mark wrote:
pawn wrote:
Hi
Duy
Thanks Off The Mark
Yes, I am referring to the gimbal head that we wildlife photographers use.
Thanks for viewing images there.  Photography is a just hobby which I like a lot.  I am trying to expand to areas out of my comfort zone to learn more and try to improve.
DMKAlex
DMKAlex Veteran Member • Posts: 5,700
I agree that you need a good tripod and a smooth and steady video head.
I think you cannot do it with shoulder mount or gimbel because you probably going to use a telephoto instead of a 12mm lens. The long lens is going to exaggerate any minor movement of the camera which makes it impossible other than a tripod.
Practice the movement to increase your ability to follow the fast moving subject.
 DMKAlex's gear list:DMKAlex's gear list
Panasonic GH5 Panasonic Leica Summilux DG 25mm F1.4 Panasonic Leica 12-60mm F2.8-4.0 ASPH Panasonic Leica DG 50-200mm F2.8-4 +2 more
