32" 4k screen recommendation for new 14" M1 Pro/Max MacBook Pro?
Eyal Contributing Member • Posts: 562
Just purchased the new 14" MacBook Pro with M1 Max chip to replace a late 2015 27" 5k iMac
I was running the iMac with a second 25" monitor (Dell Ultrasharp UP2516D - 2560x1440 which does 100% Adobe RGB). Now looking to upgrade to a 32" monitor. Budget: under $2k.
First some basic questions:
1. Should I be looking at a monitor that does 99%+ Adobe RGB or be okay with 100% sRGB for the 'main' 32" monitor since I can use the Dell 25" for proofing in Adobe RGB for prints? If I understand correctly, the proper setup is to process the photos in the maximum color space (ProPhoto RGB) on an sRGB monitor for most of my images as they start off on the web and mobile devices. Then switch to processing on an Adobe RGB monitor for any prints.
2. Will I notice a big drop off in clarity moving from the 27" 5k iMac screen to a 32" 4k one?
3. Ideally, would love a single cable connection to the MacBook Pro that would then be able to connect to an OWC RAID, external SSD and the Dell 25" monitor.
So here is what I have as options so far including some Pros/Cons related to use with a MacBook Pro specifically. All are 32" 4k monitors with IPS screens:
1. Asus PA32UC - $1500
Matte screen
99.5% Adobe RGB; 100% sRGB
14 bit LUT; 10 bit depth
1 USB-C/TB3 input; Power up to 60W
2. Asus PA329CV - $800
I think this is their newest version
100% sRGB but NO MENTION of Adobe RGB anywhere
USB-C with 90W power delivery
Only thing going for the one (besides price!) is the promise of a single cable to connect to the MacBook Pro and be good to go with power, etc and (I believe) be able to send data to/from RAID, external drive and drive second monitor
3. Asus PA329C - $1150
I believe this is the older (2019) version vs the new PA329CV
Glossy screen with anti-reflective coating
100% Adobe RGB; 100% sRGB
1 USB-C 3.2 gen 1; Powers up to 60W
4. Viewsonic XG320U - $1000
Just announced as 'Gaming Monitor'
144Hz; IPS; 99% Adobe RGB; 99% sRGB
Inputs: USB 3.2 type B and HDMI 2.1
Unclear to me if can power MacBook Pro with single USB-C cable
10 bit color depth
5. BenQ SW321C - $2,000
60Hz; IPS; 99% Adobe RGB; 100% sRGB
Inputs: USB-C with up to 60W charging and data transfer up to 5 Gb/s
16-bit LUT; 10 bit color depth
BenQ seems to have better reviews than the Asus ProArt but also have read some 'horror stories'
6. Eizo Flexscan EV3285 - $1850
Limited to 100% sRGB
Thanks in advance!
robgendreau Veteran Member • Posts: 9,344
Re: 32" 4k screen recommendation for new 14" M1 Pro/Max MacBook Pro?
You just have to decide if the wider gamut is useful, and that depends in part upon the colors and results you want. But yeah, it seems that if you keep the Dell for proofing you've got the best of both worlds. Especially if you've already got it calibrated and tweaked to approximate print results. I'm guessing the M1 MBP is DCI P3, which is pretty nice too.
Clarity? not sure exactly what you mean, but the pixels will be much bigger on that 32", and it will hold a lot less content at once, 5k vs 4k. The iMac is 218DPI, the 4k 32" is only 138 DPI. But I assume you want lowere DPI by going with 32 instead of 27 or even 24, perhaps because it will be further away. Like a lower DPI print the jaggies won't be noticeable if sufficiently far from your eyes.
Of course that's impossible since each has its own cable. But I do use a CalDigit T3 for managing that more easily; YMMV. Nice for docking, and it can charge the MBP while connected.
Keep ergonomics in mind; swiveling your head all around gets tiresome, and you have to make room for the MBP, unless you're gonna use it in clamshell mode. Perhaps that's why you want the lower DPI monitor, so it can sit back a ways behind the MBP?
OP Eyal Contributing Member • Posts: 562
Thanks Rob!
By clarity I meant the drop in DPI vs the current 5k monitor. I sit 36" from the screen so may not be a big deal.
For the single cable, I assume that a single USB-C from the MacBook Pro could connect to a monitor with USB-C/TB3 and that monitor could then be connected to the Dell monitor, RAID, external SSD and feed all that data plus power back to the MacBook Pro.
I have an L shaped desk so plenty of room to put the MacBook Pro in either open or clamshell mode.
strawbale Senior Member • Posts: 1,946
Thanks Rob!
According to https://www.designcompaniesranked.com/resources/is-this-retina/
32" 4k becomes 'retina' over 25" viewing distance
 strawbale's gear list:strawbale's gear list
Nikon Coolpix P7800
rio_c Forum Member • Posts: 61
Perhaps but these days most mobile phones support wide gamut color (e.g. DCI-P3 for iPhones) so you may want to have a similar color space coverage as well.
I spent quite a bit of research looking into a photo editing monitors, as far as I can tell, the uniformity of backlight across the monitor as well as the uniformity of color are very much important. A lot of monitors will claim to support 99-100% of AdobeRGB but it's pretty useless if all those colors were inaccurate by 5~10% depending on where you look at the screen.
Also, you may already know this but it's extremely important to regularly calibrate your monitor using a calibration tool like i1 Display Pro or Datacolor SpyderX. Because LED monitors reflect some ambient light and your perception of color is affected by the ambient light, each monitor has to be calibrated at a given lighting situation before any color critical work is done.
macOS has something called TrueTone which tries to mimic color calibration based on ambient light, and you can toggle it in Display settings to see the effect of it. If you monitor it carefully, it changes throughout the day as light from a window, etc... changes its brightness, color, and other light sources in your room such as a lamp start or stop emanating lights. (Don't rely on TrueTone to calibrate your external monitor for obvious reasons.)
Matte screen
This screen seems to have an excellent uniformity at least according to this site:
https://www.color-management-guide.com/asus-pa32uc-monitor-review.html
Looks like this is 100% Rec. 709? The fact they don't mention Adobe RGB probably means it has less than 99% Adobe RGB coverage.
10 bit color depth
I wouldn't get a gaming monitor like this. The uniformity of backlight & color of gaming monitors are most certainly not calibrated & adjusted at the factory.
I have a BenQ monitor (SW270C) and I'm pretty satisfied with its color reproduction. The uniformity of backlight / color is pretty good as well. I can charge my laptop while I'm using the monitor and I can hook up a bunch of devices to the monitor so that's pretty convenient.
I wouldn't get a Flexscan for your budget & use cases. ColorEdge is what Eizo is known for. I used to own a Flexscan back when I was a student. It was an excellent monitor for what it was, but I wouldn't pay $2k for it.
 rio_c's gear list:rio_c's gear list
Sony a7R III Sony FE 70-200 F4 Sony FE 24-70mm F2.8 GM Sony FE 100-400mm F4.5-5.6 Sony FE 16-35mm F2.8 +1 more
Thank you very much for this. I actually purchased the Asus PA32UC just yesterday.
minimejdh
minimejdh New Member • Posts: 10
I am finding that this Asus display is discontinued
 minimejdh's gear list:minimejdh's gear list
Nikon Z6 Nikon AF-S Nikkor 70-300mm f/4.5-5.6G VR Nikon Z 24-70mm F4 Nikon Z 14-30mm F4
