Macro working distance 30mm vs 45mm vs 60mm and focus breathing
Started Oct 22, 2021 | Discussions
Interceptor121 Veteran Member • Posts: 8,691
I have had my Olympus 60mm since 7 years now and used it extensively underwater
There have been situations (not macro targets) where I felt the angle of view was too narrow underwater so I recently procured a Panasonic 45mm.
Finally this week I have also acquired the 30mm 2.8 macro for tabletop photography
Reading the specs you see that the working distance is respectively
19 cm for the 60mm
15 cm for the 45mm
10.5 cm for the 30mm
What is not that obvious is that this distance is from the focal plane not from the front of the lens so once you subtract the lens size the actual working distances are
87mm for the 60mm
65.6mm for the 45mm
24mm for the 30mm
The 30mm needs you to be on top of subjects and is clearly a good choice for things that do not move however is a bit surprising that the increased working distance between the 45mm and 60mm is only 21.4 mm
When you are far away from targets the difference of field of view is obvious however as you get close the benefit is somehow lost.
I believe this is due to the effective focal length dropping more for the 60mm than the 45mm as you get closer so the increased focus breathing and size of the lens eats out the working distance as you get to 1:2 or 1:1 reproduction ratio.
I thought it was interesting to share this as I have found that except for small bugs 45mm is more effective for close up work of flowers where you need more field of view
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
Chris DC Contributing Member • Posts: 805
Re: Macro working distance 30mm vs 45mm vs 60mm and focus breathing
You are making good observations.  I have noticed the same thing about macro lenses too.  I am sure there are a few on this forum that grasp the nuances completely but I am not one of them!
I have a few wide zooms (e.g. Oly 14-35mm F2 SHG) that focus close enough for me to get good environmental macro shots.  Each time I consider a true low focal length macro I find they offer me little benefit over my existing non-macro lenses.
I typically am looking for more working distance so as not to scare off skittish bugs.  This is another tough problem as most telephoto lenses don't focus very close.  I recently found an old 43rds mount Sigma 150mm macro.  It focuses about a foot or so in front of the lens at 1:1 magnification and is perfect for dragonflies.
Good luck on your hunt for a short wide angle macro and keep us posted on your progress!
Chris DC
Michael Benveniste
Michael Benveniste Veteran Member • Posts: 6,378
You can tell this is the case by the minimum focus distance.  At 1:1, a symmetrical 60mm lens would have a subject distance to sensor distance of 240mm instead of 190mm.  Designing focal length breathing into the lens allows it to be smaller, focus more quickly, and provide a larger effective aperture at macro distances, which is why almost all modern macro lenses are designed that way.
Samyang makes a 100mm macro in MFT mount, but it's manual focus.  My "solution," such as it is, is to use a Nikon 105mm f/2.8 on a Viltrox NF-M1 adapter.  My SIgma 180mm f/2.8, is, alas, not compatible with that device.
Light travels at 2.13085531 × 10^14 smoots per fortnight. Catch some today!
 Michael Benveniste's gear list:Michael Benveniste's gear list
Nikon Coolpix 995 Nikon D800 Nikon 1 V2 Nikon D7200 Panasonic Lumix DMC-GX85 +46 more
I currently own and use the Oly 60mm macro, the Sigma 105mm macro (43rds mount) and the Sigma 150mm macro (43rds mount).
Each has its merits and unique uses.  I love the extra working distance of the Sigmas and I love the in-camera focus stacking and auto focus bracketing of the Olympus 60mm.
The Sigma 105 and the Oly 60 extend when focusing close.  The Sigma 150 does not extend (at least externally the lens overall length does not change).
All three work very well on the EM1x which has capable PDAF focus.
I look forward to the Oly 100mm macro.
Chris DC
OP Interceptor121 Veteran Member • Posts: 8,691
Chris DC
Interesting to look at this
https://photonstophotos.net/GeneralTopics/Lenses/OpticalBench/OpticalBench.htm
The olympus 60mm goes from 60mm to 37mm when it goes from infinity to 1:1 ratio 61%
The sigma 150mm becomes a 78mm lens ratio 52%
The panasonic 45mm from 45mm to 33mm ratio 73%
So your sigma has more focus breathing than the Olympus 60mm which in turn has more than the Panasonic 45mm. At 1:1 distance the real focal length ratio between the olympus 60mm and the panasonic 45mm has increased from 75% to 90% so in effect there is very little left in it
The panasonic lens is also smaller so am not totally bought into the idea that more focus breathing makes the lens smaller. The Olympus lens is sharper across almost the entire field of view the panasonic instead drops at the edges
The 30mm lens is optically better than both but you are just too close for comfort
All lenses work fine with focus bracketing on my G9
Are you saying you have the Sigma 150 in the 43rds mount and that focus bracketing works on the G9?
On the Oly cameras, only a select few mFT lenses will bracket focus.
CDC
CDC
No the MFT lenses all work regardless of brand
43 lenses may work but don’t support CAF so I have not explored that route I have a canon 8-15mm EF mount that I use underwater in saf depth of field is immense so no problems
That is my understanding too.  I tried the G9 with my old 43rds lenses and the focusing was not consistent. I hope Panasonics new offerings include PDAF but I am not optimistic.
CDC
I would prefer a 100mm native lens so that all functionality works
DonBMichigan Junior Member • Posts: 38
CDC
Focus bracketing should work with any AF lens . In-camera focus stacking is limited to a certain set of lenses .
 DonBMichigan's gear list:DonBMichigan's gear list
Olympus OM-D E-M10 II Olympus E-M1 II Olympus M.Zuiko Digital ED 60mm F2.8 Macro Tamron 14-150mm F/3.5-5.8 Di III Olympus 12-100mm F4.0 +2 more
CDC
Do they need to be MFT though as it needs to be able to control the steps on the motor no just to get in focus?
CDC
I don't know! I've used 4 different MFT lenses and those have worked. Not sure if other adapted mounts work...
Interesting to know thank you
