Are step up and step down rings the same?
tizak Junior Member • Posts: 49
Looking to pair with a ND filter.
 tizak's gear list:tizak's gear list
Nikon D800
CameraCarl Veteran Member • Posts: 8,054
Re: Are step up and step down rings the same?
With step down rings you run the risk of vignetting. How much all depends on the design of your lens and how much you want to step down.
Travelerdave Forum Member • Posts: 89
No they are not the same. Step up allows fitting a filter that is larger than the size of the lens front thread. Step down is to fit a smaller filter.
 Travelerdave's gear list:Travelerdave's gear list
Fujifilm 16-55mm F2.8R LM WR Fujifilm X-H1 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +5 more
OP tizak Junior Member • Posts: 49
Thanks, that clears that up. I will be buying a ND filter for my biggest diameter lens.
Nikon D800
BBbuilder467 Veteran Member • Posts: 5,870
The step-rings should always be listed with the lens thread first, so 52mm on the lens to a 62mm filter is a "step-up".  A 62mm lens to 52mm filter is a "step-down".
Thanks, I assumed I needed step up rings. Checking before purchasing.
Thanks for commenting.
Nikon D800
