olympus ep5 dial skipping problem
Started Oct 21, 2021 | Discussions
dhuk New Member • Posts: 1
hello
i have a olympus ep5 which i bought secondhand for not very much and it has developed the dial skipping problem to the point of being borderline unusable.
the internet tells me that this is not a uncommon problem with the ep5 , and even sending it back to olympus for repair is not necessarily successful, as the problem can recur ,in my internet searching about this i came across someone with a different camera with a similar dial skipping  problem and they solved it by using a very small amount of non conductive electrical contact cleaning spray , !
I considered my ep5 broken and nothing i could do would make it more broken so i decided to try this , i used wd 40,,,,, ! and to be honest i expected it to do nothing at all or even damage the camera but ,,to my amazement ...  it worked ,,!!   no more skipping dials , the camera is working perfectly the dials are precise and feel better in operation than they ever have . now time will tell if there are any long term consequences in doing this as wd 40 is something i would normally  never allow anywhere near my photographic equipment ,but  it has worked for me the camera is a joy to use again .
now i am not recommending anyone else does this if you do its at your own risk , dont blame me if it goes wrong , i am not a expert ! all i am doing is putting my experience with this problem  out there , this worked for me and i have a fully usable camera again .perhaps ?  a very cheap and easy solution to this problem ?
cheers
david
Olympus PEN E-P5
traveler_101 Senior Member • Posts: 2,203
Re: olympus ep5 dial skipping problem
Yep, did the same after reading about on this forum many years ago. Many voices were raised against doing so but it worked for me after exercising the dial - but you must careful to use a very small amount of oil.
 traveler_101's gear list:traveler_101's gear list
Olympus PEN E-P1 Olympus PEN-F Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Panasonic Lumix G 14mm F2.5 ASPH Olympus M.Zuiko Digital 45mm F1.8 +3 more
