More 16 F2.8 comparisons: corrected vs. uncorrected vs. JPG
Started Oct 20, 2021 | Discussions
Alastair Norcross
Alastair Norcross Veteran Member • Posts: 9,874
13
I ordered my 16 F2.8 from Adorama a few days ago (Saturday), expecting to have to wait a while before they got it in, and, as expected I got an email saying it was backordered. A few people on this forum suggested that it might be easier to get at a local camera store, so I checked with my local store (Mike's Camera in Boulder) online and ordered it to pickup in the store. The website said it was 'coming soon', but I got an email 30 minutes later to say it was ready for pickup. So I picked it up today and cancelled my Adorama order. I've been playing with it, because we have some nice autumn weather right now. I shot RAW, and processed some of the shots in camera using the shot settings, which presumably gives me the same results as using DPP (which I hate for its clunkiness). I then imported the images into Lightroom and exported some downsized JPEGs (2000 pixels on the long side) both of the in-camera converted JPEGs and the RAWs with no lens corrections applied (but using the rest of my default processing settings for the R. Then I also applied the lens corrections for the RF 24-240 STM, as suggested by some people here, and added 130 distortion correction, as also suggested by someone. The results are interesting. As we know, the uncorrected RAWs are much wider than 16mm. Even the corrected versions (using the 24-240 profile and 130 distortion correction) are a bit wider than the in-camera JPEG conversion, and with only the 24-240 profile applied, they are significantly wider. Here are some examples, starting with the first shot I took with the lens, right outside the camera store:
This is the in-camera conversion using shot settings, giving the 16mm field of view
This is the LR conversion with no lens correction applied. See how much wider it is.
This is the LR conversion with 24-240 profile applied and 130 distortion correction. Still slightly wider than the in-camera JPEG conversion
Here's another set of 3, showing the in-camera conversion, LR conversion with no corrections, and LR conversion with lens corrections:
This is the in-camera JPEG conversion using shot settings. I framed this shot to exclude the porta-potty on the right (not seen here, obviously)
This is the uncorrected LR conversion. As you can see, there's a lot more on the side here.
This is the LR conversion with 24-240 profile and 130 distortion correction. As you can see, it's a little wider than the in-camera JPEG conversion
And here are a few conversions with the stated lens corrections applied:
I'm mostly interested in using this lens for landscape shots in good (or at least fair) light, so all these shots are stopped down to F8. I did take one closer to wide open (F4):
I'm very pleased with this lens. It's small, light, cheap, and pretty sharp (at least stopped down to the apertures I'll be mostly using it at). I have had several UWA zooms over the last 15 years, and used the wide end for more than 90% of my shots. Most of the other 10% were at the long end of the zoom. So, between this 16 F2.8 and my 35 F1.8, I have probably 99% of the shots I would have taken with an UWA zoom covered, and I'm much more likely to have this lens (and the 35) with me. The lens also seems to handle flare quite well. All in all, it's a great addition to the RF lineup for those of us without unlimited funds to pay for lenses and assistants to carry them for us.
As the length of a thread approaches 150, the probability that someone will make the obvious "it's not the camera, it's the photographer" remark approaches 1.
Alastair
http://anorcross.smugmug.com
Equipment in profile
 Alastair Norcross's gear list:Alastair Norcross's gear list
Canon G7 X II Canon EOS M6 II Canon EOS R7 Canon EOS R6 Mark II Canon RF 35mm F1.8 IS STM Macro +24 more
kristian1 Veteran Member • Posts: 3,035
Re: More 16 F2.8 comparisons: corrected vs. uncorrected vs. JPG
Thanks for posting those, it would be great too see full resolution images if you can post.
Kristian
 kristian1's gear list:kristian1's gear list
Canon EOS R Fujifilm GFX 100 Canon EF 500mm f/4.0L IS II USM Fujifilm GF 32-64mm F4 Fujifilm GF 23mm F4 +4 more
Alastair Norcross
OP Alastair Norcross Veteran Member • Posts: 9,874
Kristian
Which ones would you like to see in full resolution?
Alastair
Alastair Norcross wrote:
Kristian
Maybe this two, to see mostly edge performance.
Thank you.
https://www.dpreview.com/forums/post/65578998?image=7
https://www.dpreview.com/forums/post/65578998?image=9
If possible with default sharpening.
All the best
Krtistian
Alastair Norcross
A couple of full resolution versions
Kristian
Thank you.
All the best
Krtistian
Here you go. I'm not sure what default sharpening is. My default settings for the R at ISO 100 are: Amount-60, Radius-2, Detail-25, Masking-70. I have an ISO aware import preset for each camera I own, which applies different settings depending on the ISO level. The sharpening settings don't vary that much with ISO, though.
Alastair
Re: A couple of full resolution versions
Thank you for posting those , it looks decent specially for the lens that small and cheap.
All the best
Kristian
NormSchultze Contributing Member • Posts: 594
I'd really like some architectural views with multi-story buildings.
sportyaccordy Forum Pro • Posts: 20,562
This lens is a mixed bag for me
Good price, FL and spec.......... but corrections rob you of a good bit of resolution. Just guessing it looks like a 1.1-1.2x crop which is like 20-40% of your MPs. For a lens that I imagine will be used for landscapes a lot that's kind of a bummer
But I guess that's reasonable to expect for the price/size. Kind of seems like a missed opportunity like the RF 50 1.8
Sometimes I take pictures with my gear- https://www.flickr.com/photos/41601371@N00/
 sportyaccordy's gear list:sportyaccordy's gear list
Sony a7 III Sony Vario-Tessar T* FE 16-35mm F4 ZA OSS Tamron 28-200mm F2.8-5.6 Samyang AF 35mm F1.8 FE Samyang AF 45mm F1.8 FE
Tristimulus Veteran Member • Posts: 9,998
Just wondering.
Why would anyone skip digital correction when using a lens that is designed to be digitally corrected?
MaStErPsX
MaStErPsX Regular Member • Posts: 203
Tristimulus wrote:
Just wondering.
More wider and better corner quality, for landscapes it's maybe possible to skip lens correction
 MaStErPsX's gear list:MaStErPsX's gear list
Canon EOS R6 Mark II Canon EF 135mm F2L USM Canon RF 35mm F1.8 IS STM Macro Canon RF 24-105mm F4.0-7.1 IS STM Canon RF 85mm F2 Macro IS STM +6 more
Alastair Norcross
Tristimulus wrote:
Just wondering.
I don't know. The point of my post was to show how wide the lens is before and after corrections. It's clearly quite a bit wider than 16mm before corrections. The thing about corrections for this lens is that you actually have some choice about how much and which corrections you use, if you shoot RAW. I suppose you might really want a bit of extra width on occasion, and not mind the distortion. You might even welcome the distortion for effect. People apply all kinds of effects to their images. I don't think it's a bad thing to have the option to apply corrections or not (and which ones to apply). It's not as if anyone is forcing you to do it one way or another.
Alastair
Tristimulus wrote:
Just wondering.
To understand what compromises the digital correction introduces. If I'm a landscape shooter, I'd def like to know that correcting the geometry on this lens will throw away 20-40% of my resolution for example. Will that matter to everybody? Maybe, maybe not, but having that info will enable more informed decisions.
Alastair Norcross
As far as I can tell, applying the corrections I used is equivalent to about a 1.15 crop, which loses about 25% of your MP.
That would be more of a problem in the days of 8MP sensors. But even then it wouldn't have been terrible. I still have my 8MP 20D, which was an amazing camera in its day, and gave me lots of great landscape shots. This lens would have used 6 of those 8. My first DSLR was the 6MP 300D. I have several 30" X 20" poster prints of landscapes from the 300D on my walls. They look great. From a 6MP sensor. Now that we have megapixels oozing from every pore, it's even less of a problem. My R uses about 22.5 of its 30 megapixels to produce the corrected images from this lens. I can remember when everyone was waxing lyrical about the incredibly high resolution of the 1DsII, which had 17 MP. If you use an R5, you'll still be using about 33.5MP with this lens. I know that people (on these forums at least) keep insisting that they 'need' more and more megapixels. But they really don't. They're just trying to justify their lust for newer and newer gear. I prefer to not attempt to rationalize that lust. I just admit that I really like new toys (not that I can usually afford them). Need doesn't come into it. It's all about want.
Alastair
Alastair Norcross
There's not a lot of that around Boulder (the city has a height ordinance), but I'll see what I can do.
Alastair
Sittatunga Veteran Member • Posts: 5,406
That depends on the aspect ratio you use.  If you use 16:9 for example, and DxO PhotoLab (when they make a profile) you will lose a very small proportion of the pixels once the image has been stretched into shape compared with a 3:2 crop.  And the main reason people need a lot of pixels is for huge crops which rather defeat the purpose of a lens this wide.  Unless you're cropping to avoid converging verticals, in which case Canon would rather sell you a £2700 TS-E lens instead of this £320 job.   A lens this wide for half the price of a Sigma 50mm isn't a missed opportunity, it's a whole new ball game.
KEG
KEG Veteran Member • Posts: 4,909
Seems to outperform my old EF 20/2.8 (which kind of wasn't hard, it was awful in the corners but lovely on a crop camera).
KEG
 KEG's gear list:KEG's gear list
Canon EOS M6 Canon EOS R Canon EOS M6 II Canon EF-M 32mm F1.4 Canon RF 50mm F1.8 STM +21 more
davidwien Contributing Member • Posts: 572
Tristimulus wrote:
Just wondering.
The OP corrected that to 25%, which would reduce a 20MP camera (e.g. the R6) to 15MP.
I think this sideproduct is the major concern about this lens, and I imagine that as time goes by, more and more lenses will rely on on digital correction of this sort.
David
 davidwien's gear list:davidwien's gear list
Sony RX100 VA Canon EOS RP Canon EOS R6 Canon EF 17-40mm f/4.0L USM Canon EF 70-300mm f/4-5.6 IS USM +6 more
Tristimulus wrote:
Just wondering.
David
It's actually less than that, because stretching (warping) the image to get rid of barrel distortion elongates it.   If you lose 15% of the length cropping it back to 1.5:1 aspect ratio you don't lose any of the shorter dimension, so you only lose 15% of the pixels, not 25%.  I reckon that straightening out the distortion of this lens gives you an uncropped aspect ratio of about 1.65:1.  This is a lot closer to the Golden Ratio than 1.5:1 is, and cropping the whole corrected image to that ratio should give more pixels and a slightly wider field of view than an undistorted 15mm on FF cropped to the same aspect ratio.
Im not following your logic. If more MPs dont matter youd still be shooting a 6MP camera.
Plus I'm not even suggesting that people run out and buy super high MP bodies. But there are photography disciplines that leverage resolution. A lens that throws out 25% of the MPs it captures will be less desirable to a lens that doesnt, regardless of how many MPs are available. Having that info allows people to choose the lens that makes the most of their sensors if that is a priority.
Alastair Norcross
other things being equal, which they never are. My point, which I didn’t think was that difficult to follow, was that using 75% of the pixels on a modern camera still gives great results. More pixels provide diminishing returns. For many people, a small, light, cheap lens that uses 75% of the massive number of pixels we have available is a far better proposition than a big, heavy, expensive lens that uses all of them.
Alastair
