Recommended Workflow for DP1S in 2021
Started Oct 20, 2021 | Questions
Nick_Andrews Regular Member • Posts: 124
Hi all, I've read multiple discussions on this but just wanted to clarify as I'm new to the Foveon game.
I recently purchased a DP1S - I can load the files into Lightroom Classic just fine, but am I losing anything by not first processing them in SPP? And what's the "minimum" amount of processing that I can get away with in SPP (just really used to LR at this point)
Thanks in advance!
Sigma DP1s
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
Re: Recommended Workflow for DP1S in 2021
Hello Nick and welcome!
What you get is Adobe's conversion via Adobe Camera Raw which is part of LR's Develop Module. Adobe's conversion is different to that of SPP. For example, I once had a yellow flower that got gamut-clipped by ACR but not by SPP.
The cause of that problem was not obvious. Shortly thereafter, I parted with Adobe for ever.
For the DP1s I would recommend SPP 3.5.2 for it's simplicity compared with later versions.
And what's the "minimum" amount of processing that I can get away with in SPP? (just really used to LR at this point)
For important work, I usually adjust nothing * and export to my fancy editors ** as 16-bit ProPhoto TIFF. My editors do everything better than SPP.
The above assumes that I got the exposure and WB correct in the camera.
* I also leave the camera JPEG settings at default.
** RawTherapee, GIMP.
Just interested in the technology.
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
OP Nick_Andrews Regular Member • Posts: 124
Thank you, this is very helpful!
Excited to see what I can produce with this little camera, after my first photowalk with it I think I'll stick to ISO 100 (base). Maybe up to 200 if B&W is an option...
allineedislight Senior Member • Posts: 1,309
I would second to go with SPP rather than Adobe.
Here is an example, not from a DP1 but a DP2:
Abobe conversion:
https://cameraderie.org/attachments/5985994157_4433ff9e1a_o-jpg.1651/
SPP conversion:
https://cameraderie.org/attachments/5985994315_7bb86fb643_o-jpg.1652/
this is taken from a review of the DP2x by Jeff Damron on Cameraderie.org:
https://cameraderie.org/threads/sigma-dp2x-review-a-field-report.3618/
The difference between the two conversions is massive.  SPP seems to be able to impute/recover a lot of the clipped colors - this algorithm is apparently not available in Abobe.
 allineedislight's gear list:allineedislight's gear list
Sigma DP2s Fujifilm X-E1 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +1 more
Abobe conversion:
SPP conversion:
That is a stark difference indeed! I wonder if it has something to do with AFE...
Roger Veteran Member • Posts: 3,293
SPP
Thanks in advance!
Greetings Nick
Use SPP only, it works the best for the Foveon. Other programs try to make the Foveon look like a Bayer sensor. Other programs are generic, they work with all cameras except the Sigma/Foveon so if you want the best from the DP learn and use SPP. Some say it's slow or it's this or that, but it isn't. It depends on your computer, don't listen to people. SPP can do a lot you just have to learn it and what it can do. I use two programs SPP and PhotoScapeX You can do a search for PhotoScape X  on the web. Both programs are free and are excellent, PhotoScape X has a lot inside it, I use it for my DNG files and for my S1 files.
So stick to SPP to get the best out of your DP.
Have fun and enjoy
Roger J.
Re: SPP
Thanks in advance!
Greetings Nick
Thanks, Roger! I will stick to SPP. I don't mind extra workflow steps as long as i'm maximizing output quality
tohereknowswhen Regular Member • Posts: 483
I use lightroom for my dp1 files since it's fast, works well and has a lens correction profile. I haven't noticed any huge difference in output compared to SPP.
I do use spp for my dp2m and dp3q since those files have more options in SPP.
Hope you're enjoying your dp1s!
digi2ap Contributing Member • Posts: 887
I have an SD15 and I import and adjust the X3F files in Lightroom first.  This is a good way to do a first edit.  Then with the files I like, I open them in SPP and adjust and save as a TIF.  I will then import the TIFs alongside the X3F’s and filter the view depending on which I want to work with.
Try it and you can compare the X3F and TIF files side by side in Lightroom,  You will then see if you prefer adding this step of using SPP.
 digi2ap's gear list:digi2ap's gear list
Sigma SD15 Panasonic Lumix DMC-GH3 Sigma 10-20mm F3.5 EX DC HSM Sigma 18-35mm F1.8 DC HSM Art Sigma 50-100mm F1.8 DC HSM Art
I would say it is partly due to AFE (especially the fur of the dog) but if you look at the grass - it is much greener in the SPP version.
Definitely SPP has a trick or two that is not implemented in Adobe stuff...
whisky
whisky Senior Member • Posts: 1,965
Thanks in advance!
HI Nick,
I misread your camera DP1s but expect it is much the same as the SD15 X3F files I get.
FWIW I set my SD15  in camera exposure to --3 and work from there.
I use SPP initially for a start and then Affinity Photo to fine tune if I feel like it.
I don't spend a lot of time on post processing and don't get bogged down playing around.
Keep it simple and easy, that's for me.
Hope you enjoy your 'new' camera.
Cheers.
Plockton.
 whisky's gear list:whisky's gear list
Sigma SD15 Fujifilm FinePix 6900 Zoom Olympus OM-D E-M5 Sigma 10-20mm F4-5.6 EX DC HSM Sigma 70-300mm F4-5.6 APO DG Macro +5 more
xpatUSA
Thanks in advance!
HI Nick,
...but the DP1s is 'iso-less' whereas the SD15 has an AFE and the conversion meta-data are quite different.
Out of interest, is that -3 or - 0.3? Presumably to avoid the AFE clipping?  I'm thinking -0.3EV because -3EV would be a bit much, noise-wise ...
Me too, Stuart!
whisky
xpatUSA wrote:
Thanks in advance!
HI Nick,
Me too, Stuart!
Hi Ted,  glad to see you are still 'hanging in'  Trust Texas is kind to you.
Sorry, it is --0.3EV.  I have found that helps with 'blown' highlights and just leave the SD15 set at that.
Not done much with the camera for a long time, seem to have lost my 'Mojo' with it ☹️
All this lockdown etc cramps opportunities , real drag.
Take care and best wishes.
Stuart.
