Canon Rebel T7, Sigma 150-600 C micro adjustment
Started Oct 19, 2021 | Questions
Rakeshg New Member • Posts: 10
Hello - I took my lens into a dealer because I thought it was front focusing and they adjusted all the settings to +5 (for all focal lengths/distance). It looks like it fixed the problem at the long focal lengths but now it lappears to be back focussing at the mid-range.
Pic 1: Focal length 420mm, distance > 15m, f/ 6.3 - this looks pretty sharp
Pic 2: Focal length 190mm, distance 5m (15ft approx), f/ 6.3
In the second photo, the branch behind the bird is sharp while the bird itself appears to be soft. I am pretty sure I focused on the bird (tried to get the eye).
Would setting the adjustments back to 0 for the mid-range (150 and 200mm focal length, 6 and 15m distance) help? I have the Sigma dock and the software so I can make the changes if it appears to be right thing to do.
Any help/guidance would be really appreciated. Thanks!
 Rakeshg's gear list:Rakeshg's gear list
Canon EOS Rebel T7 Canon EF 28-80mm f/3.5-5.6 II Canon EF 75-300mm f/4.0-5.6 III Sigma 150-600mm F5-6.3 | C
Canon EOS Rebel T7 (EOS 2000D) Sigma 150-600mm F5-6.3 | C
Digirame Forum Pro • Posts: 41,857
Re: Canon Rebel T7, Sigma 150-600 C micro adjustment
I don't have that lens, but I am using a Tamron 150-600mm lens.  I would suggest looking at a depth of field chart.  Because at the long end of the lens, the depth of field can be only a few inches or less (depending on many factors), I usually take pictures of birds at F9, F10 or F11.  Why do you use F6.3?  Also it depends on where it is focused on.  If I want two things to be in focus (that otherwise could be a problems with the depth of field), I'll focus in between them.
OP Rakeshg New Member • Posts: 10
The soft focus was not at the long end of the lens but the mid-range (190mm vs 475mm). At the long end, the picture was pretty sharp. Both had the same aperture (f/6.3). Also, I'm pretty sure I focussed on the bird as there are a few more pics of the same bird with the same focus issue.
I keep the aperture as wide as possible but will see if narrowing it helps. I would not want to lose the bokeh though. Thanks.
Sue Anne Rush
Sue Anne Rush Senior Member • Posts: 6,285
Hello...
Beautiful photographs - thank you for sharing.
Sue Anne Rush
 Sue Anne Rush's gear list:Sue Anne Rush's gear list
Canon PowerShot G9 Panasonic Lumix DC-FZ1000 II Canon PowerShot Zoom Canon EOS 7D Canon EOS Rebel T7 +4 more
