Joy Stick not working
codepoet_tx Junior Member • Posts: 33
The Joy stick on my D850 is no longer moving the focus point.  I have it set for single point autofocus.  When I press it, it still illuminates the focus point but I can no longer move the focus point.
Is there any setting that I might have inadvertently changed that is causing this?
Any suggestion on something I can try to fix this?
If I must send it to Nikon for repairs, is there any preventative maintenance that I should have done at the same time?  I have ~61K exposures on the camera,
 codepoet_tx's gear list:codepoet_tx's gear list
Nikon D800 Nikon D850 Nikon AF-S Nikkor 16-35mm F4G ED VR Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Nikkor 24-120mm F4G ED VR +3 more
Nikon D850
Wahrsager
Wahrsager Senior Member • Posts: 2,783
Re: Joy Stick not working
Maybe this switch is on "L?"
 Wahrsager's gear list:Wahrsager's gear list
Nikon D4S Nikon D500 Nikon D5 Nikon Z6 Nikon Z50 +27 more
JohnnyLuddite Senior Member • Posts: 1,641
Had these symptoms on my D750, turned out this was the cause. Had been tearing my hair our, resetting, taking battery out, whatever! Woops!
Hope it's this anyway.
 JohnnyLuddite's gear list:JohnnyLuddite's gear list
Sony RX100 Fujifilm X-E1 Nikon D750 Nikon AF Nikkor 50mm f/1.4D Nikon AF-S Nikkor 24-120mm F4G ED VR +2 more
David Lal Forum Pro • Posts: 12,781
Been there ...
Done that, read the book, bought the T-shirt!
Robert Cohen
Robert Cohen Veteran Member • Posts: 4,475
If it’s not the switch on lock and you do send the camera to Nikon for repair, they’ll check it out thoroughly and will look like a new camera when you get it back.
--Bob
 Robert Cohen's gear list:Robert Cohen's gear list
Nikon D300 Nikon D700 Nikon D500 Nikon D850 Nikon AF-S DX Nikkor 18-200mm f/3.5-5.6G IF-ED VR +5 more
